USB Hub Code 10
  • luke10050
    • Mar 2013
    • 209
    USB Hub Code 10
    so my computer is being a real ass. the ICH7 USB controller seems to have decided to quit on me under windows, well the driver anyway. all the basic windows USB drivers are not loading and device manager gives a code 10. i have been accessing the pc using remote desktop from my server box which is far from ideal... any ideas why this happens? i can get the ports working for 1-2 reboots by uninstalling them in device manager... to me it almost sounds like malware or a script kiddy... any advice what to do bar reinstalling windows? today is not my day haha...
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: USB Hub Code 10
    Check to see if it is loaded on your system any version of USB driver by Prolific.
    By uninstalling it, your system will return to normal.
    • luke10050
      • Mar 2013
      • 209
      Re: USB Hub Code 10
      no dice, i tried reinstalling drivers, updating them etc. best i can get usb working for is 1 reboot. after which it screws up again
      • luke10050
        • Mar 2013
        • 209
        Re: USB Hub Code 10
        can you guys really please help, i need this computer badly, if i dont resolve it in about a week ill have to format it D':
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: USB Hub Code 10
          have you tried a pci usb controller card?
          • Sparkey55
            • Jan 2010
            • 1523
            Re: USB Hub Code 10
            Have you looked at the caps near the USB ports? Bad caps can have this kind of effect.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Re: USB Hub Code 10
              re-installing won't fix it, its a problem with the driver. have you tried installing a different version?(older)
              Follow the white rabbit.
              • cashkennedy
                • Aug 2011
                • 668
                Re: USB Hub Code 10
                Have you tried running hitman pro to see if there is any malware / rootkits your regular av isn't finding?
                Kiriakos was referring to other drivers that interfere with the usb, you have to look at more then just the ich7 drivers.
                Why are you having to reboot this computer so often that you know it goes bad after 1-2 boots?
                Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                • luke10050
                  • Mar 2013
                  • 209
                  Re: USB Hub Code 10
                  no i have not tried hitman pro. long story short mother was complaining about slow internet and decided to turn it off... its never been the same since, first a fan bearing quit and then the USB ports wont work under windows. any linux distro they are fine
                  i can update to the latest drivers or uninstall them and they will work/reboot will make them work, but after that dead again. the reason for massive reboots is looking for virii/spyware
                  would the reboot potentially indicate a cap issue? (but then again everything works perfectly in the bios, bootloader and linux
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    Re: USB Hub Code 10
                    its a driver incompatibility the drive could be colliding with a driver for say a broadcom chip or a card reader or etc that wouldnt have an incompatibility with an older driver, or it could be an older driver on the system causing it.
                    strip the drivers that aren't used anymore, update ALL the drivers and it may fix your system and may give it a speed boost.
                    take it from somebody who has read the winNT source code, the way windows is built opens it up to a very high potential for conflicts between drivers. other os's only have a fraction of the potential for driver conflicts that windows has..
                    • luke10050
                      • Mar 2013
                      • 209
                      Re: USB Hub Code 10
                      okay, could have been the ramdisk drivers... it installs a driver when it starts, ill uninstal that and see how i go. thanks for the help its just i installed that over a week ago so :/
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        Re: USB Hub Code 10
                        it could very well be that. i have installed a webcam driver that made my SCSI drivers not work before
                        ramdisk drivers? oh thats right you need 3rp party ramdisk software with windows [/end MSFT mocking]
                          LCD LED TV Service Menu Codes
                          ALL LCD LED TV SERVICE MENU CODES
                          Service Menu Code with Board Name
                          China Universal Board / Jumper Board Service Menu Code
                          Changhong Ruba Service Menu Code
                          Ecostar LED TV Service Menu Code
                          Orient LED TV Service Menu Code
                          Haier LED TV Service Menu Code
                          TCL LED TV Service Menu Code
                          Samsung LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          Videocon LED TV Service Menu Code
                          Supra LED TV Service Menu Code
                          Toshiba LED TV Service Menu Code
                          Symphony LED TV Service Menu Code
                          Veste/ LED TV Service Menu Code...
                          10-31-2024, 03:58 AM
                        • Curtissimo
                          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                          by Curtissimo
                          Hi everyone.
                          I have a HP Elitebook 850 G8.
                          Serial: 5CG2324XM0
                          ProdID 6L8D5EC#ABA
                          It has a Winbond W25Q256JVEN Chip.
                          I need to remove BIOS Password.
                          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                          Attached my dump.
                          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                          What I did:...
                          Yesterday, 04:42 AM
                        • Sorrow1
                          Intergraph TDZ 2000 mainboard post code 2F/2E
                          by Sorrow1
                          I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                          It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                          When I recorded video of POST card and played it in slow...
                          01-03-2024, 04:13 AM
                        • DynaxSC
                          MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                          by DynaxSC
                          Hi Folks
                          I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                          Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                          09-29-2024, 04:27 PM
                        • cloo
                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                          by cloo
                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                          After doing a factory reset this problem was gone and the picture was back to...
                          01-06-2025, 06:02 AM
