Ratdude's Main rig V3.5
  • ratdude747
    replied
    Re: Ratdude's Main rig V3.5
    Originally posted by thesloc
    Report your license and card asap
    You ever actually tried to bypass Windoze activation?? Or are you really optimistic they're gonna come out with more support for your machine in the future???
    The former- I'm working on that, I know.
    The latter- they're legit upgrade discs, since I have a valid student ID (I am a student at the college) I can get win 7 upgrade discs for $20 a pop. The reason I don't just use another disc and skip activation till I find it is since it's an upgrade, the COA key won't work (you have to have had xp/vista on the hdd used for the install when windows setup begins). Not like XP and 2K, when the upgrade disc was a different image and one could be prompted to insert a previous windows disc to prove the upgrade.
  • thesloc
    replied
  • ratdude747
    replied
    Speaking of 7 x64, it seems that I misplaced my copy of 7 ulitmate upgrade for this thing... I bought a 3rd upgrade key from the college bookstore so I didn't have to scuttle V2 (as it's still a complete and running rig), but I may have to buy a 4th as I can't find it even if my life depended on it.
    side note- been a bad day for losing shit... lost my debit card and DL today as well. F***ing perfect
  • ratdude747
    replied
    Originally posted by Topcat
    Just a hint with this board, if all DIMM's are populated, you can not run the RAM at full speed (400MHz), it will crash (BSoD0, fail MEMTEST, and cause all kinds of havoc. Its a bug in the chipset, and no fix. I had to turn the RAM clock down to 266 when I had 16gb in mine, 8x 2GB sticks. Removing 2, and it was fine at full speed.
    I owe you big time. Good call. Stepped it down to 266, all is well with all 16gb.
    So, I can pick either Faster RAM or more RAM.
    Thoughts and ideas?
    Edit- tried 333 and 366, no dice. I wonder if that's partially why V3.0 never ran well (I ran all 16GB at 400)... But given the AGP issues on all but Xp x64, It wasn't viable in the long run.
  • gg1978
    replied
    Yup, that's a limitation of the Opteron's integrated DDR controller. If you have a board with 8 slots per CPU, it's limited to 266 so even slower.. Although it should auto drop the speed to 333 if all 4 are populated.. If you only have 4 working DIMM's i would put two per CPU, so you get the most speed at least for testing!!
  • ratdude747
    replied
    There be my issue i bet.
    I may bump it to 333 and try agian.
  • Topcat
    replied
  • gg1978
    replied
    maybe do a test install of Win 7 x64?? you don't have to enter a product key, it'll let you run for a while without one, that way you could test stability before you buy any more RAM.. I did have 8 1G DIMM's in it, so i know all 8 DIMM slots should be good.
  • ratdude747
    replied
    It uses PC3200 ECC DDR1. I know, old and freaky, but it works and is low cost.
  • thesloc
    replied
    Wait, mine is DDR2 PC2-3200 (IBM)
    There's 2 2GB sticks, for a total of 4GBs.
    Your machine uses ancient DDR, no?
  • thesloc
    replied
    It has the latest BIOS, 1.06, 11/'08
    Memtest failed like crazy around 42%... just a constant string of failed addresses when I got back from work.
    So yeah, the RAM is hosed, at least one module.
    Also, one of the HDD's died today. it was the one with 26 Bad sectors (or so it was the last time I checked). Won't show up at BIOS. tried different controller ports, the onboard SATA, and different power connections and SATA cables. Dead as a doornail.
    Not sure if I'll replace the dead drive or stick with the 3 and call it good. As for the RAM, I'll see if I still have an ebay seller warranty on it. edit- no such luck. Looks Like I'm stuck at 8GB unless I justify $$$ for another 8gb. I may have mishandled a couple modules when I was seeing if a board could do ECC, so this one is on me. I hope 8GB is enough.
    Any feedback on whether to replace what died or to do without?
    I have a couple of ECC modules, I can send them to you if you want since I'm pretty sure I'm not making much of use of them.
    I *think* have them around somewhere, they're 2gb sticks, I think.
  • mariushm
    replied
    Get some isopropyl alcohol, dab an plain unscented paper handkerchief in it and rub the memory module contacts to clean them.
    Get a piece of A4 paper, bend it two or three times then drag it between the pins in the memory slots to rub away some oxides. Inspect the modules to make sure each pin is in the proper position and can flex a bit when you insert the ram, to make good contact.
    If you have time, test each module one at a time to see which one fails... well, one on each cpu.
  • ratdude747
    replied
  • thesloc
    replied
    You're probably running an outdated bios if that much ram isn't supported, if at all.
    Or check the configurations.
  • mariushm
    replied
    You could just open the power supply and measure the current taken out of 3.3v ...
    If there's an inductor for the 3.3v rail (pi filter at the output) just desolder one of its legs and put the multimeter in series with the inductor.
    With such a motherboard, I kinda doubt they're using 3.3v to power the ram - it makes more sense to just use 12v for everything, for better efficiency.
  • ratdude747
    replied
    I think I found the issue, kinda. It will run with 4gb or 8gb of ram, but with 16gb it doesn't get far. Memtesting all 16gb while I'm at work for an hour, I'll see what happens when I get back
    As for the 3.3v issue- any psu suggestions?
  • Pentium4
    replied
    I still think the 3.3V rail on the PSU might be getting overloaded, those old high voltage ECC sticks use a lot of power, especially in memtest
  • ratdude747
    replied
    Originally posted by shovenose
    Did you install sli bridge? If so remove it maybe it will work then?
    Tried it already, no dice.
  • mariushm
    replied
    Windows xp 64bit is basically using the Windows 2003 kernel, so anything validated/certified for Windows 2003 64bit should run on Windows XP 64bit as well.
    But I don't understand why you'd HAVE to use Windows XP... I basically had Windows 2000 on my home computer, then skipped straight to Windows 2003 Standard Edition and now I'm using Windows 7.
    Up until a couple of weeks ago, I still had a dedicated server in a datacenter with windows 2003 web 64bit and it was working fine.
  • RJARRRPCGP
    replied
    Reseat the RAM. And your may need a VDIMM bump.
  • Dobrowol
    Dell Latitude 3520 help with bios build/repair
    by Dobrowol
    Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
    Steps i done and results:
    I exported a clean bios from update file via pfs extract.
    1. Build clean bios with clean ME, PMC, PCH in flash image tool.
    Result: Dead
    2. Build clean bios with no changes in ME, new PMC, PCH
    Result: Dead
    3. Build old bios with clean ME, new PMC, PCH
    Result: The same
    09-22-2023, 02:43 AM
    ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
    This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
    09-12-2024, 03:28 PM
  • iotaa
    How to build this little device please for my campervan security
    by iotaa
    You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
    I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
    For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
    The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
    This sound can be manually triggered by me if I'm inside the van, or played automatically...
    09-18-2022, 09:52 PM
    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    by sam_sam_sam
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
    04-23-2025, 05:50 AM
