Burning 24 DVDs, how long to wait between each disc?
  • Hondaman
    • Sep 2008
    • 1089
    Re: Burning 24 DVDs, how long to wait between each disc?
    Yeah, wait at least as long as it took to burn the disc. That's what I have heard. Longer is nice too.
    I've had bad luck with burners. Last fall I went out and got like 7 of them (far beyond my needs, I don't know what I was thinking). I have used a couple of them for like 15 burns each, no problem at all.
    I think I just had bad luck years ago. (And I still have a SCSI CD-R/RW and a PCI SCSI card if I need it.)
    • larrymoencurly
      • Oct 2004
      • 960
      Doesn't it take much longer to burn the DVD than for the laser and its power circuitry to heat up completely?
      I've had only one DVD drive fail, a BenQ DQ-60 (TEAC design), but it was its CD portion that went bad, not its DVD part.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        They should be designed not to burn out the laser diode. But, I've never seen one with a proper heatsink for the diode. I dont know how much power the diode is run at.
        Muh-soggy-knee
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • Junior††
          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
          by Junior††
          Good Afternoon fellas,
          Issue:
          Disc is showing as not supported when a disc is put in.
          Here's what I've done, you can skip this if you just wanna know the question:
          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
          - reflowed the disc drive connector
          -reflowed the chip in question (shown on image)
          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
          Question:
          I...
          02-19-2025, 12:48 PM
        • stormanimal83
          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
          by stormanimal83
          Hey....
          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
          01-18-2024, 02:15 PM
        • Sojke
          IT8585E Programming
          by Sojke
          How to program IT8585E on RT809F (H) programmer?
          It wont work on ITE_ADAPTER_V1.5 board (IT8580, IT8586, IT8587 work when soldered on board)
          Please help.
          I tried with cable for keyboard it does not work either (Laptop is G750JZ)
          005: The currently selected:IT8585_ISP @PEB-1, capacity: 1Mbits, 128Kbytes.
          006: http://www.ifix.net.cn/thread-47221-1-1.html
          007: >------------------------------------OK---------------------------------------<
          008: Wait for the chips enter into the ISP status, please wait...
          009: Wait...
          10-28-2021, 01:35 PM
        • ignacio.ino27
          Vaio DA0HK1MB6E0 MBX-247 Burning any EC
          by ignacio.ino27
          Hello to all.
          I have this Sony Vaio QUANTA HK1 DA0HK1MB6E0 MBX-247 that is burning the NUVOTON EC when you connect it to power supply.
          1) The +3vpcu line is going to a direct short after connecting the motherboard to power supply.
          2) I discovered the EC NUVOTON was shorted. After removing it the short gone out on that line (+3vpcu) but... (If i quit the EC the 3.3v are pressent on +3vpcu because the shorted component was quited)
          3) There were no shorts after soldering the new EC NUVOTON. But after connecting the board to power supply the EC keeps burning...
          05-07-2022, 05:24 PM
