How to RUIN a really nice case fan
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I managed to destroy a brand new Arctic F12 CO (120mm PWM 2BB fan by arctic)... and draw blood at the same time!
    What happened was I was testing a pair that was to go in a supermicro case (to replace the single 120mm PWM san ace) at full speed... and somehow my left pinky got in the blade. BAM! Ouch! The tip of the blade impaled the finger and drew some blood... and the blade was almost entirely cracked off the hub.
    I tried to glue it back together, but I can't get the blade to set in position... so to the scrap pile goes a brand new fan
    Lesson: be careful around fans w/o wire grates!
    sigpic
    (Insert witty quote here)
  • cheapie
    null
    • Jul 2010
    • 849
    Re: How to RUIN a really nice case fan
    I heard about somebody that was playing with some 240CFM Delta fan at full speed, and it sliced a piece of skin off of their finger and blew the blood onto the wall.
    • c_hegge
      • Sep 2009
      • 5219
      You must have tougher fingers than me. The last few times I've got my fingers into a fan, the blades didn't get damaged, but it bit into my finger hard - and that was with a small 70mm fan (it was running at about 5000RPM, though).
      Ouch! That would really hurt. I still have the two I got for my old load tester. I never power them on without grilles installed - specifically for this reason. I've had one ingest a few sticks and leaves before - which just got turned into sawdust. I'm sure it could easily do a similar thing with my finger.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Lol, how on earth would the fan blade(s) break from that? I say cheap plastic/design!
        I did get a finger sliced from a fan before, it is this "PFC Select" brand. Amazing fan, it will knock itself over if not supported well enough!
        Now, if you havent seen the fans firefighters use to ventilate buildings, you need to see them! Talk about gigantic CFM, and a high power motor ... i bet they'd chop a whole arm off!
        Muh-soggy-knee
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Ouch!
          Chegge and Ben7- I think it's the small hub of the fan and the fact I got it by the pointy end of the fan blade that made it crack (leverage). It was running at about the 2200RPM (max rated RPM of the F12).
          I did once have the same result with a 3K AMD 940 cooler, but no fan damage. Or worse, a PWM 5K Delta 60mm cpu fan running full blast, also had no damage. both had pointy blade tips. OUCH!
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            I did similar once when cleaning a really cruddy one with my air compressor. It was spinning really fast from the air flow and I accidentally got the air nozzle into the blades.......every blade sheared off and became a projectile. Fan obviously destroyed.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • lti
              • May 2011
              • 2557
              I found out that these have sharp blades. I think I might have posted about that before. It took a chunk of skin off, and I only had it running at 9V. It's inside my computer's PSU now where it can't hurt anybody.
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                Ouch! I have to be careful of things like that as clumsy as I am. So I always have fan guards on mine. I ordered a pair of 50mm from amazon. The package said Hong Kong and had regular 60mm in it. I had to order from someone else. It would have cost more to send back than they cost in the first place.
                sigpicThe Sky Is Falling
                • Sweet & Spicy
                  Techie's Wife
                  • Apr 2013
                  • 281
                  Ouch! Getting your finger sliced on one of those sounds really bad. Never done it myself. I have twice required stitches for scissor slices before though, and those were moving a lot slower than those fan blades. You all be careful!! I hope the fan wasn't too expensive.
                  I'm curious as to why RD was up so late/early, but that's not really my business to be poking my nose into.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Couldn't sleep. Nothing less, nothing more
                    sigpic
                    • Logistics
                      • Apr 2007
                      • 721
                      I'm gonna go home and wet-sand+polish my fan blades.
                      • Elysarian
                        • Mar 2013
                        • 200
                        My idiot brother managed something similar (without the bloodshed)...
                        He was taking pictures of the inside of his "modded" PC when he dropped his camera into the CPU cooler
                        One fan destroyed, upside is it was only a stock AM3+ cooler & got replaced with an Arctic Cooling A30.
                        I did ask after the event why he was taking pics with the thing running...
                        • luke10050
                          • Mar 2013
                          • 209
                          i managed to do something like that yesterday with an air compressor as i was cleaning out a PSU fan, shoved the compressor nozzle a bit too far in and the blade went flying. i was amazed when a bit of loctite 406 instant adhesive solved all my problems and rendered the fan as good as new.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            I broke my Zalman heatsink with 92mm fan's blades with an air compressor as well, broke two blades off. Hesitant to use glue as it'd upset the balance of the blades. I just ripped the rotor/blades off another (unfortunately, 80mm) fan -- worked well enough.
                              master hoarder
                              • May 2008
                              • 12175
                              So just break off the blade, do some cleaning/sanding in the areas that make it no go back in place, and glue the blade back.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Some fans have 9 blades. On those, you can just snap two other blades off to balance it again
                                • cheapie
                                  null
                                  • Jul 2010
                                  • 849
                                  That's what I did with my old OCZ power supply. It had 8 blades on the fan (120mm Globe, for those that care). At this time, the computer was just a pile of parts on the floor. I came into the room one day to find the power supply making a rumbling noise. It turns out that a lamp had fallen off the desk and broke a blade off of the fan. I just broke off the blade across from it and it ran fine.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Nah, any removal of material will unbalance it... it was a jagged break. If anything the jaggedness provided a way to align it. Not to mention that smooth sufaces are WORSE for gluing (less surface area, single plane of contact). Even with all that, I couldn't get the blade to stay... maybe super glue gel would have worked. IDK.
                                    It is a 9 blade fan... I thought about that, if anything I'd remove 5 blades and the stub of the broken one to make a 3 blade fan. too bad it wouldn't be high enough RPM for such a layout to be even remotely optimal.
                                    sigpic
                                      ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 10:50 PM
                                      ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 11:05 AM
                                      ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                      This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                      This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 07:07 AM
