Can I use 800MHz RAM in a board rated at 667 MHz
    Another thread on my DG965WH
    The manual for my board has the following supported memory configurations:
    • Four 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
    • Support for DDR2 800, DDR2 667, or DDR2 533 MHz DIMMs
    • Support for up to 8 GB of system memory using DDR2 667 or DDR2 533 DIMMs
    • Support for up to 4 GB of system memory using DDR2 800 DIMMs
    I have quite a bit of spare DDR2 800MHz, and I'd like to put 8GB in the system. But from the look of it, I would only be able to use up to 4GB? If I put more than 4GB in, will the RAM be clocked down to 667 MHz? Or will it not work at all?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Can I use 800MHz RAM in a board rated at 667 MHz
    it will work, it just won't run at its full speed.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yeah it will probably just clock it down to 667MHz. Although there might be an option in the BIOS for you to select manual RAM speed, and you could just change it to 800
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        yes
        Follow the white rabbit.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Yeah the other posters are right... now if you try to put 8gb in a 4gb supported board the system will only show and utilise 4gb of it
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            should work just fine on desktop boards. Have had some issues with old ThinkPads using too fast memory, causing no POST.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              if it has SPI profiles and the board supports them, it might take the CL down too
              • newtothis
                • Mar 2013
                • 1556
                • england
                Indeed, a lot of motherboards are not set to use low CAS Latency though unless they are built for overclocking, Yes it may be underclocking the RAM but same applies.
                • lti
                  • May 2011
                  • 2555
                  I haven't seen any problems with RAM that was faster than the computer was designed for. All of the RAM manufacturers tell you that faster RAM won't work and you'll need to buy slower RAM (which almost always costs more, for some reason). Unless the board manufacturer did something stupid like trying to match the FSB to the RAM speed, it will work.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    this is the reason I put DDR3-1600 in ivy-bridge desktops. Its just about the same price (sometimes cheaper) than 1333, and most ivy-bridge motherboards will see the SPD profiles (GSkill is great for having SPD profiles). So if they have a Celeron or PDC ivb, it will run at 1333/7 and if they upgrade to i3 or above, it will be 1600/9 ready
                      Well, I got a decent deal on some 667 MHz anyway. £56 for 8GB in four 2GB sticks. PC works great and bios shows 667 MHz. But when I memtest86 it (passes fine) it shows it as 233 MHz. Why? Is it a bug?
                      Server build worked first time, I am using my broken 32 GB memory stick to run FreeNAS as it only requires the lower 2 GB or so.
                      • mariushm
                        • May 2011
                        • 3799
                        Bug in memtest, don't worry about it.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          was it memtest86 or memtest86+?
                          always use 86+
                            86+
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              What version? My favorite is 4.0a
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                I pretty much try to stick with the latest, usually more accurate
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  For some reason I've had a lot more issues with 4.2 but it may have just been a bad disc
                                  • larrymoencurly
                                    • Oct 2004
                                    • 960
                                    The only case where faster RAM didn't work for me was with an ECS mobo that supported PC2100 speed but wouldn't boot if PC3200 was installed AND the BIOS had been configured for the "safe" defaults instead of the regular defaults.
                                    MemTest86 and MemTest86+ are supposed to use the same testing algorithms, but I've gotten different results with them, with MemTest86+ missing errors found by MemTest86. I also use Gold Memory because it did better than MemTest86 in RealWorldTech's evaluation of memory diagnostics, and sometimes it's found errors that the other tests missed. One person had no luck by running MemTest86/86+, but Gold Memory found the error in about 76 minutes but then needed another 9 hours to find that error again.
                                    • Perry Babin
                                      Operating caps well below rated voltage
                                      by Perry Babin
                                      I think this has been answered but I couldn't find the thread.
                                      Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                                      So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                                      If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                                      Or would it require reforming?
                                      05-23-2024, 05:43 PM
                                    • Phil289
                                      Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
                                      by Phil289
                                      Hi
                                      Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
                                      Is there any reasons why they shouldn't be used?
                                      I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
                                      If I can't find any Panasonic what would be any other good makes to consider?
                                      Thanks 🙂
                                      09-25-2022, 03:02 PM
                                    • UserXP
                                      Transformer producing higher voltage than rated
                                      by UserXP
                                      Hello, people.
                                      i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
                                      So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
                                      09-02-2025, 12:42 AM
                                    • eccerr0r
                                      "amd" ddr2...
                                      by eccerr0r
                                      So what's with the "AMD" DDR2?
                                      My (Intel) board "officially" supports 4G DDR2's (four slots, 16G total) but this "AMD" deal is kind of scary recalling back to the old SDRAM deal. In fact I have a few 512M SDRAM modules now but they don't work in my 440BX board, which is too bad, would rather run this board with 2GB RAM through its four slots, else have to use the VIA boards with only 3 slots is the best I can otherwise do.
                                      But anyway I heard these "AMD" DDR2 still "work" on an Intel board but cannot clock at PC6400...
                                      03-09-2021, 02:57 AM
                                      FUJITSU ESPRIMO P2550 ESPRIMO P E5300 Specification for Upgrade or Repair
                                      This specification for the FUJITSU ESPRIMO P2550 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO P2550 boardview and ESPRIMO P2550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                                      09-12-2024, 03:44 PM
