How far can i push that ram?
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Ok, so I want to overclock my E6320. My board is a Gigabyte P35-DS3L and memory modules are both Hynix ddr2 667mhz. For some reason I can't choose multiplier 1 or 1:1, the lowest I can get is 2. So I have the CPU at 2.62 and memory multiplier 2, memory speed 755 I think. I want to push the CPU even higher, but that means changing the memory speed. Is it safe to go 800? I think it is, but i am not sure. I am going to buy 4gb of ddr2 800 ram soon, but for now I have to deal with that 2gb 667 crap. The cpu can do a lot better, these things can hit 3.6-3.7 Also, should I leave the voltage at auto, or go +0.1 or +0.2?
    I can put text here?!
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: How far can i push that ram?
    Are the memory chips on a heatsink? If not I wouldn't go that high, you are pushing them pretty hard and they might cause a blue screen under load. I'd wait for the 800 RAM
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      No heatsink Currently CPU at 2.8 and memory at 800. Not afraid of BSOD, since cheap shit no name modules can hit 850-950 http://archive.atomicmpc.com.au/foru...s=2&c=27&t=116
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        Yeah, this is stabile, Orthos has been running for 8 hours now, all tests passed.
        • mariushm
          • May 2011
          • 3799
          What does it say on the ram chips ... you can trace that and determine what frequency the hynix chips were designed for.
          You should get more Hz by dropping the latency and other parameters and slightly raising the voltage... but I personally wouldn't raise the voltage until I would no longer be able to raise frequency just by lowering timings.
          • mariushm
            • May 2011
            • 3799
            You can use OCCT to test the whole system's stability... often you get memory issues only when cpu is also stressed out: http://www.ocbase.com/index.php/download
            edit: f@$k if i know how i did two posts... sorry
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              Orthos tests both memory and cpu at the same time.
                The Raspberry Pi's mobile SDRAM is rated at 400MHz IIRC, but I've had it stable up to 600MHz with a 0.2V over volt. SDRAM does have a fairly good overclocking capability.
                • DJduck
                  • Dec 2012
                  • 229
                  • Estonia
                  Going to push the thing to 3ghz on air cooling And the memory is also going higher. Can't wait for the new memory, just one more week
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Is it a Wolfdale? Wolfdale is 45nm. Wolfdales easily hit 3.6 and probably 3.8.
                    A Conroe (65nm) probably requires 1.4+ V for 3.6. Likely 1.5 V for 3.7 or 3.8.
                    Intel's spec is max at 1.5 V for Conroe and max at 1.36 V for Wolfdale.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3264
                      • Singapore
                      this shud be his cpu here. its a 1.87 ghz conroe with 4mb of l2 cache.
                      this kinda reminds me of the ol' ddr1 days as well when almost all ddr333 modules could overclock to ddr400 easily and without problems.
                      regarding the use of heatspreaders or lack thereof, it has been said in numerous articles around the web that ram heatspreaders are just for aesthetics and dont really affect the overclock or reliability of your ram. ddr2 rams only have a tdp of around 4 watts so they shud be fine.
                      also, do note that 2gb sticks *might* be less overclockable than 1gb sticks since u intend to push the cpu to 3ghz which requires at least running the ram at 858mhz.
                      but why are u afraid of overclocking your memory as far as it will go? overclocking is not for the faint hearted. u have the tools to actually test if your overclocked ram is stable so why not? tho actually, u shud run a few passes of memtest #5 FIRST to see if the ram is stable. in rare instances, corrupted ram can brick your os. so u shud run a memtest off optical or external storage that doesnt need booting the hard drive os... if it can pass test #5 for several passes then its usually safe to boot the os and run orthos to double confirm stability.
                      there might also be another tool u can use in windows to test your ram. its called HCI Memtest. u can also use that to test your ram inside windows.
                      • DJduck
                        • Dec 2012
                        • 229
                        • Estonia
                        Well, since i have had the new OCZ memory for a while now, and it runs at stock 800 with the cpu @ 2.8 with 1.35v, all stabile. One thing that kind of bugs me is that the old memory clocked to 800 and ran cool without any heatsinks, but the new ones run at 800 stock with heatspreaders and get pretty toasty under load for some time. But its not a big deal, i just put a 120mm fan to blow over the memory and the chipset heatsink, keeps the thing running cool
                        • TuanTongbadcaps
                          Change CPU multiplier through BIOS editing
                          by TuanTongbadcaps
                          Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                          07-22-2024, 07:57 PM
                        • ongobongo
                          Ram Modules with undderfill - tricks for desoldering
                          by ongobongo
                          I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
                          I tried with a lot of heat on the donor board but the modules won't come loose.
                          Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
                          Ongo
                          06-02-2024, 02:18 AM
                        • Natob82
                          Micro Momentary Push Switch?
                          by Natob82
                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                          12-21-2022, 05:22 AM
                        • gabrielA7
                          Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
                          by gabrielA7
                          Hi guys!!
                          I have this video card on my bench, it turns on and the screen goes black!
                          I used MATS but it showed an error in all memory modules, when writing!
                          I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
                          Remember that I have all the debts ok, 1.35 Vram and such!
                          Could the problem really be in the GPU?
                          Could it be the BIOS?
                          Thank you in advance!​
                          06-05-2025, 09:04 AM
                        • didi79
                          will GPU work with missing memory modules?
                          by didi79
                          I'm looking at a RX480. When testing with dmgg.py script, it shows multiple possible faulty memory modules.
                          I was thinking of removing the modules one by one.
                          Will the card work with one or more modules missing? Just for further memory testing of course.
                          05-02-2022, 01:53 PM
