Sorry, old mobo, it powers up, but theres no spining (in all connectors) i read 0v from the 12v pin, cpu vrm input voltage seems ok measured in caps, but no output Vcore. Any idea? somethin is badly open?
Mobo powers up, but no spins, no 3.3 no 12v
Tags: None
Re: Mobo powers up, but no spins, no 3.3 no 12v
The thing must be old if it runs the VRM from the 5v... Anyway, the VRM probably won't start without a PWR_OK signal from the power supply, which shouldn't come up unless all rails (including 12v) are in spec. 0 volts is not is spec for the 12 volt rail. Try testing with a different power supply.
by zlr8rHey all, my first post here ..yay...!
so , lets kick off with the problem I have with this mobo.
-= Asus ROG Strix Gaming x99 =-
Background info - bought 2 different boards from eBay to try and fix, one i think i can fix, the other ... not so much (which is why im here).
There is no obvious damage or signs of previous tampering. in fact, i could swear the board is brand new, its that clean...
Motherboard symptoms:
(with no peripherals attached).
Motherboard does light up and looks to be functional (but isn't).... -
by elfelvinAs per the description, there is some life but it seems like the important power rails are not getting any juice. How can I test that the power management chip (UH1) is not at fault? My tests show that I get power to the various power chips but then the enable triggers are not there to switch them on? Are there any other tests I should be doing to pinpoint the issue?
Board: VAL91 LA-9932P Rev 1.0 (A00) 2013-09-11
PJP101/103 = 5.04v
PJP100/102 = 3.32v
PJP200 = 13.5v
PJP201 = 0v
PJP202 = 0v
PJP203 = 0v
PJP204 = 0v... -
by WVUfanhello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by malogroHello all,
I'm stumped on this guy, so wanted to see if anyone has any further ideas:
Intro:
This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,... - Loading...
