small 3-pin fan connector
  • hkivan
    • Mar 2006
    • 122
    Help me guys ,
    I brought a VGA copper HSF with only HKD$15 , a few weeks ago. It is the same type as the attached image. It was so cheap that I just brought it before having any idea to use it for.
    It comes with a small 3-pin fan connector. The wires are red, white & black respectively. Now, I wanna make it a standard 3-pin fan connector. Can you guys tell me which is 12v, speed sense & ground ?
  • linuxguru
    • Apr 2005
    • 1564
    Re: small 3-pin fan connector
    Usually black is ground, yellow is +12v, and green is the speed sense on a regular HSF. You can easily test yours by taking pairs of wires at a time and checking DC resistance. Of the two minimum resistances you find, the common line in the two pairs is ground (probably black). You also should have fairly low resistance between the +12v and GND lines on the fan. You can check them by momentarily touching the two candidates to +5v/GND. If the fan spins, your guess is correct, otherwise repeat with each of the other pairs.
    • hkivan
      • Mar 2006
      • 122
      Linuxguru,
      Thank you so much. I finally made it.
      I measured the resistances between wires as fellow :
      - between red & black = 9.6KΩ
      - between red & white = infinity
      - between black & white = infinity
      So , the red is for 12V , the black is GND & the white is speed sense.
      I soldered them with a 3-pin connector. Wow, it spins at 4500 rpm which is quite noiseful. I think this is the only draw back. For the price of this HSF, I have no complaint at all.
      • arneson
        • Sep 2005
        • 1267
        This is not a dig of any kind and meant only as a respectful correction.
        You meant to say in english, the fan is quite noisy.
        Jim
        • Baron
          • Sep 2006
          • 24
          I think 'quite noiseful' sounds rather good
          Tt Armor+ black case--Corsair HX1050--Intel i7 920 (default)+Noctua U12-Gigabyte GA-58EX-Extreme--6GB tri-ch. Corsair Dominator+ Corsair Dominator memory cooler--2 X Gigabyte 6870OC CF -2 x 300GB WD V-Raptors--1 X 500GB WD Green--1 x WD 250GB--1 X 1TB Samsung F3--8 case fans--Samsung T220 22" + Dell WFP2408 24"--Logitech G15 keyboard-Logitech G500 mouse--Onboard sound--plus other bits.
          OS-Vista-64bit+Win7-64bit+Win 8 64bit.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            if you have no speed control you could use a resistor
            • hkivan
              • Mar 2006
              • 122
              Yeah, I have some controllers sitting around but the copper HSF does tailor made to certain models. It doesn't likely to be fit on my winfast and I already have a copper HSF installed.
              Maybe, I will tailor the copper block to small heatsinks for chipset , MOSFET...etc
              • hkivan
                • Mar 2006
                • 122
                Take a look on the images and guess which one is better !
                Well, the copper one has a small & slower fan with red , blue , yellow blinking LEDs. The aluminium FSH has a higher CFM, over 3000 rpm fan and much larger surface area for heat dissipation. AFAIR , they cost around CNY¥65 and CNY¥4x to 5x respectively.
                • corrize
                  Where to find a very small fpc connector 0.3mm between 2 pins ?
                  by corrize
                  Hello, I search this connector (oxydated).
                  It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                  I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                  I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                  Do you know how to find this connector please ? What is the exact name for find it ?
                  08-06-2024, 05:25 PM
                  HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                  This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 03:44 PM
                  HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 03:36 PM
                  HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
                  This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                  09-12-2024, 03:28 PM
