stupid Linux shit... please?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    So, I WANT to use Linux, I WANT to stop using Windows.
    But it never fucking works!
    /endrant
    Trying to get Ubuntu 12.10 64-bit running on my secondary PC.
    Intel Celeron G540, 8GB RAM, Radeon HD 5770 1GB, Dual Dell 20" LCD.
    It installs fine, but it's a bit laggy with the default X driver or whatever it's called.
    So I went to Additional Drivers, selected the fglrx or whatever it's called. Rebooted, tried to login, I'm stuck at a blank desktop.
    If I right click I get the menu, but that's all it will do.
    PLEASE help me fix this... thank you.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: stupid Linux shit... please?
    For a server? for a desktop? for browsing beastiality porn?> What do you want to do with it?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      I use Ubuntu on my main laptop.
      But I wouldn't recommend others try, unless they want to mess around.
      Once you mess around with setting it up: Clean, smooth, stable, fast, and you never need to reinstall or concern yourself with average security flaws.
      To fix your problem enter the grub menu on boot (I think F10?) then select "recovery mode" or whatever it's called now, and select the option, when it appears, to get a basic X desktop (failsafex I think.) From there, reinstall fglrx, or install the open drivers (I forget what they're called but they're supposed to work for most basic 3D better than fglrx.)
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Thanks to I did this http://ubuntuforums.org/showthread.php?t=2073193 and now everything is fine:
        OK, I 'found' the fglrx driver, figured out how to remove it, and then to make sure everything was cleaned up from my earlier fumblings I removed the ati driver and the radeon driver, then reinstalled the radeon driver.
        Maybe it was some earlier error of mine, but it seemed that I could not remove fglrx until I navigated to /usr/share/fglrx.
        Then:
        sudo apt-get remove --purge fglrx fglRx_* fglrx-amdcccle* fglrx-dev* xorg-driver-fglrx
        sudo apt-get remove --purge xserver-xorg-video-ati xserver-xorg-video-radeon
        sudo apt-get install xserver-xorg-video-radeon
        sudo reboot
        the desktop came up looking good, but the display was slow until I also added the ati driver
        sudo apt-get install xserver-xorg-video-ati
        and rebooted.
        Things look snappier but system settings > details shows the graphics type as 'unknown'. That doesn't seem right, am I missing something?
        thanks,
        -- John
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Now... to try it on my laptop I've been meaning to re install the OS, so now's as good of a time as ever. It's painful copying 20GB of stuff to a shitty old USB 2.0 external drive before I wipe my SSD and re-install.
          If it doesn't work, I'll take the SSD out, sell it, and then sell the laptop, and then buy a new one... have to sell my iMac and my tablet first though!
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            hit it with a hammer.
            but in all seriousness, desktop use. replace windows.
            for servers? nothing beats centos (or debian, if you're not running cpanel or solusvm)
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              12.10 has been hit and miss (I run the gnome remix on my D630). Took an unusually high amount of work to make the graphics work... and it does have a current binary (unlike my main rig).
              I too like linux but due to the higher amount of bull puckey lately I'm down from 3+ linux rigs to just a headless file/print server (no GUI, debian stable) and a single partition on my triple booted D630 (I do use the linux third most of the time).
              sigpic
              (Insert witty quote here)
              • katzcaps
                • Feb 2012
                • 48
                To me, Linux means a lot of "hand holding" and patience. I used it steady on a bench pc for a couple of years, but decided that the limitations outweighed the advantages. It's fun to play with & if you are a techy geek you can learn a lot.
                At that time I was big into audio/video editing, and I ran into snag after snag in my quest to get it to function correctly.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  100% in the consumer market. You still can't top a good linux server though. Win servers are tolerable, but its the typical microshaft bullshit of licenses, fees and nonsense to make things work.....Linux = none of that!! You just can't beat a *nix server! Back in the old days of winservers, I cheated....to get vhost. Win2k A/S + apache made for a decent entry level or quickie server with the best of both worlds....IIS with FP extensions if needed and vhost for all that cheap shared hosting.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Shared hosting on Windows? ugh!
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      uhg what? Works the same as any other. Apache doesn't hate windows. We know who the server nubb is around here.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • opamp
                        • Dec 2012
                        • 160
                        • united states
                        I also think the same way, I installed fedora 18 a few weeks ago to try it out but it kept crashing, it took me back to 04 trying to run redhat. Don't get me wrong I liked redhat and I still have all my installation cd's from back in the day but since I'm not running a server I prefer to run windows.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Yeah, this is NOT gonna happen. Trackpad doesn't work well
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Would be f'ing hilarious to try run Windows as a VPS node...
                            • everell
                              • Jan 2009
                              • 1514
                              I have loaded earlier versions of Ubuntu on several "older" computers and had great results, very few problems. But....I just attempted to load Ubuntu 12.10 on an old pullout mother board from a Gateway - an Intel D865GLC board. Ubuntu loaded and looked like everything was OK. Started it up after loading, logged in as user, and got the desktop picture.....nothing else. Nothing to click on. Not sure if it is because the mobo is a propriety board, the video is not supported, or maybe bad cd with the Ubuntu file.
                              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16959
                                Nope, never tried that...
                                Team : 49813
                                Join in!!
                                Team Stats
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  All we have to do is partition the Windows filesystem as such:
                                  / 10GB
                                  SWAP 2 times RAM (if RAM ⇐2GB otherwise RAM + 2GB is plenty)
                                  /vz remaining space (templates & virtual servers will be stored here)
                                  and then run this:
                                  wget http://soluslabs.com/installers/solusvm/install chmod 755 install ./install
                                  For some reason I don't think that will work
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    That's because your graphics driver is running in VESA mode. Right click on the desktop, you should get a menu, go to change desktop background. This will get you into the settings program (albeit, without a title bar or anything lol)...
                                    then go to Details and then to go Graphics.
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      Got to graphics. It says:
                                      Driver Unknown
                                      Experience Standard
                                      There is no button for changing anything. All I can do is return to settings.
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Hmm...
                                        • tsavpyn
                                          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                          by tsavpyn
                                          Dear all,
                                          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                          Now I have a problem that I am unable to dump my BIOS into bin file.
                                          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                          I searched for FPT but there is no Linux version and none of them work.
                                          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                          I would really appreciate it if anyone...
                                          05-28-2024, 11:18 PM
                                        • mr.malcom
                                          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                          by mr.malcom
                                          this is a very strange Problem:
                                          Notebook hang instantly on Boot. BIOS is accesable.
                                          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                          i have tried:
                                          - only one RAM Stick, another working RAM, both RAM channel
                                          - BIOS Flash to newest Version F.50, BIOS Reset
                                          - Memtest86 hang instant at Test 2
                                          - HP UEFI Diagnostic wont find...
                                          02-26-2022, 05:19 AM
                                        • mkdj
                                          Acer Swift won't boot after a Linux install
                                          by mkdj
                                          Dear all,
                                          I have an issue with an Acer Swift laptop which won't boot (Acer Swift SF113-31-C7UK)
                                          History and symptoms:
                                          A friend of mine tried to install Linux on this laptop. After the installation, the PC did not reboot. When pressing the power button, backlight is working, capslock is working. But screen stays black.
                                          What I have done so far:
                                          As I suspected a BIOS issue, I tried to clean the TXE region, following the winraid guide for CSE TXE 3.1. I managed to do all the steps, including the steps involving the signing process with OpenSSH. The...
                                          10-30-2025, 04:31 AM
                                        • Hondaman
                                          Japanese language -- Win7 or Linux Mint?
                                          by Hondaman
                                          I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                                          Does anyone have experience...
                                          09-12-2025, 04:32 AM
                                        • survivalbloke
                                          MS Surface Book 3 - Keyboard works only in UEFI/Linux
                                          by survivalbloke
                                          This is a very weird issue which I'm having trouble finding a common thread.
                                          The keyboard is registering keypresses in either the UEFI, or a live Linux USB environment - I used Ubuntu for testing. The keyboard backlight is lit.
                                          The keyboard is registering keypresses in Windows or any Windows-related bootable device. For example, it does not work in Hirens Recue or a Windows 11 bootable installer.
                                          When booted to Windows, not only is the keyboard not registering keypresses, but my USB keyboard is not either!
                                          USB mouse and integrated trackpad...
                                          07-14-2025, 03:17 PM
