Most Expensive 360W PSU?
  • mariushm
    • May 2011
    • 3799
    Re: Most Expensive 360W PSU?
    It's a Seasonic - I'd never put them in the same category as those Chinese power supplies.
    My own computer shows these:
    Code:
    Voltage Values
    CPU Core	1.040 V
    +2.5 V	1.472 V
    +3.3 V	3.376 V
    +5 V	4.973 V
    +12 V	12.288 V
    +5 V Standby	3.602 V
    VBAT Battery	3.200 V
    GPU Core	1.082 V
    It's a Seasonic X-650. Of course the 5v standby is not 3.6v ... the sensor reading is simply stupid.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      mariushm: Oh I would never say anything bad about Seasonic, best PSU manufacturer there is, atleast nowdays IMO!
      Originally posted by shovenose
      It's using a 500W Cooler Master Extreme that I'm aware is not so great but it's better than nothing!
      Did you check for badcaps? Crapcon...
      http://alfredoblogspage.blogspot.se/...0w-inside.html
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Oh shit you know what's funny? Guess what I have: an identical 400W Zumax that I used to use to power my main PC LOL
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Really?
          That's pretty impressive, that PC must have a very good VRM
          How long have you had it?
          Post some pics of it here:
          https://www.badcaps.net/forum/showthread.php?t=8490
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            That heatsinking method is quite clever...
            • Robin21
              Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
              by Robin21
              I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
              I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
              All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
              I've replaces both buck regulators already (AOZ1212)...
              09-25-2025, 03:24 AM
            • ChanHa
              Help me Resistor on FSP Hexa ATX 500w
              by ChanHa
              My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
              06-04-2025, 08:44 PM
            • anikin73
              Cooler Master 500W atx psu repair. Total cannot start at all
              by anikin73
              I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
              5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
              What other pin should I check such that it will result in no start up at all ?
              07-07-2024, 07:06 AM
            • Hondaman
              OCZ Mod X-Stream Pro 600
              by Hondaman
              I have an OCZ Mod X-Stream Pro 600 (semi-modular). One transformer is dated "1215" and one is dated "1210", and the largest capacitor (slightly bulging 400V TEAPO) is labeled "03/12", so yes it's pretty old. A few nights ago it caused the circuit breaker to cut off the power. It was plugged into an APC UPS, that appears to be undamaged.
              When I reset the circuit breaker, the power supply fan did not even twitch. When I got a low-hour Seasonic PSU out of my basement, my system started right back up, so the rest of the system was not damaged.
              04-17-2023, 08:25 PM
            • прямо
              Micronics Cyclone II 500W
              by прямо
              Came across this famous Korean brand PSU (but made in China) with a strange problem that I have never encountered before.
              It can start, and aside from 5VSB which is spot on, the rest of the output voltages are off the chart.
              12V is 11.2V
              5V is 5.9V
              3.3V is 300mV (or you could also say no 3.3V)
              primary caps (2x 820uF 200V connected in series), one reads 68V, and the other one reads 34V.
              any idea what to look? obviously primary side has an imbalance and under voltage issue.
              I wonder why the protection (GR8313)...
              01-12-2024, 09:46 PM
