Microsoft's Biggest Blunder
    Which OS do you think was the worst M$ made? Personally, I'd have to say Windows Mistake Edition, mainly because of how notoriously buggy and unstable it was. At least vista and 8 are fairly stable.
    48
    Windows 8
    0%
    19
    Windows Vista
    0%
    10
    Windows ME
    0%
    16
    Other
    0%
    3
    Re: Microsoft's Biggest Blunder
    Vista is fine after lots of updates. You know I like Windows 8 so I vote ME... BUT WAIT! Zune was worse, so Other
      Wow, 1 vote in each category so far I voted Vista, a big factor was the fact that Microsoft tried to force feed it to everyone
        I had so many problems with Vista. Never had to use ME, thankfully. I probably shouldn't vote, since I'm not well-informed. Perhaps another poll should be started asking for the best OS's from Microsoft?
          I skipped the 98/ME era on my own systems, but I worked on tons of them....both sucked, but weren't the worst thing in the world. Vista was just a major resource hog, but otherwise functioned ok. Win7 is what Vista should have been, and 7 is actually pretty good. Win8 will do a bellyflop worse than vista and ME combined. Nobody likes it.... Steve Ballmer should have been fired after Vista.....but wasnt. Wanna start a bet pool whether he's working at the end of this year?? FWIW, win8 will suck bad, but if MS follows tradition, win9 will be pretty good.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            Agreed 150%. ME's error was trying to use the win 9 hybrid 32/16 bit kernel to do things that required the power of the NT kernel... hence Windows XP, which did that to a point.
            sigpic
            (Insert witty quote here)
              For what it's worth, I happen to like Windows 8 overall. Sure, navigation is difficult and I'm not really impressed with the idea that you can't close out the metro apps, but overall its benefits outweigh the disadvantages. It took me a couple days to get used to it, and the first thing I did was create a shortcut to the shutdown and restart .exe's and pinned them to the start menu. I didn't like where they hid the normal button. I first installed 8 in a partition on my machine running 7, just in case I didn't like it. I was actually blown away at how fast 8 was booting up and shutting down. The task manager is also loads better and overall it's more efficient than 7 or other predecessors.
              I'm actually looking forward to Windows 9, if they make it. Ideally, in win9, I'd like to see the efficiency and speed of windows 8 with the windows 7 UI and layout.
              Just my $0.02
              Matt
                95C and the first edition of 98.
                Why?
                Simple. Bill-the-living-Nazi got away with the integrated Internet Explorer lie. First, it set the "I can get away with it" precedent. Second, it opened the door to half-assed "programming" that fails back to/depends on IE/ActiveX with everything that goes with them. The ramifications have been further-reaching than we may ever know.
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                  Windows 8 is more intrusive and I hate to say it, Vista and 7 are, too. It's hard to get a sense of control with Vista and later.
                  Also, someone at Microsoft should have been fired for making the default permission settings deny administrators access to temporary file directories. (Vista and later)
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    I had a great deal of control over 7. It was one of the best OS's for the modifications I try to make on my machines. Better than XP, especially. 8 didn't allow as much control though, so in that sense I agree with what you say.
                    I nevere liked the windows default permissions either. Luckily they were easily changed....
                    Matt
                      Microsoft famous "plugged and play" sometimes PLUGGED AND PRAY! Hoping that some devices will work hah!
                        I hear ya there!
                        I think I had that problem back when 7 was still fairly new, and the driver support for USB devices wasn't as extensive. It's come a long way since then.
                        I had similar problems with 8 recently (right after it came out), so that supports my assumption.
                          Why?
                          I agree with that, but must go further....in that Vista, 7, and 8 are VERY intrusive, constantly phoning home. Win2k was the last of the OS's that didn't require activation (and hacks to get around it), and was the last great flagship OS under Billy Gates before XP came with required activation except for VLK's...and then Steve Ballmer took over and its been a downward spiral since for MS.
                          win8 though, the worst abomination we've ever seen from MS. I say again, looks and functions like it was made for a 2yr old by a 2yr old...
                          Team : 49813
                          Join in!!
                          Team Stats
                            win8... was made for a 2yr old by a 2yr old...
                            I thought you said before made for a 3yr old by a 3rd old.
                            Moot point, I know . Or perhaps the inconsistencies in Windows 8 are starting to get catchy for you?
                            I still haven't voted since I don't have much exposure with those OSes. Vista I've troubleshooted a few times, and although somewhat different from XP and a little bloated, I still think I can work with it if I had to. As for Windows ME, I didn't know much about computers back then when it came out. I remember my friend's family's computer had a Dell Dimension at the time with Win ME. We played a lot of games on that computer and did a lot of Word typing and whatnot. Other than crashing a few times, I think ME didn't give us any other problems either.
                            Windows 8, though... not having things organized properly and having the Shut Down button hidden I know will drive me nuts. So I too have a feeling this one is going to be a belly flop. And NO, I am NOT looking forward to Windows 9! This is exactly what Micro$oft wants you to do - they create a crappy OS so that anything they release after that will seem like a step forward, thus making people switch from 8 to 9 with joy. FUCK THAT! We already have seen this scenario with Windows ME and Vista. I'm sticking with XP until it's completely dead and unsupported.
                              uh oh a heap of XP lovers...
                                Uh oh, a Win8 Lover
                                (and next, somebody will say the same about a Linux lover. Proud of it!)
                                sigpic
                                  Originally posted by ratdude747 View Post
                                  Uh oh, a Win8 Lover
                                  +1. That's a real problem
                                    ...about a Linux lover...
                                    *pointing at self* Here's one!
                                      they should of made a windows 7 "touch" edition for tablets, phones and just kept windows 7 for PC's. There will be no Win7 SP2 cause of win8
                                      they're going to shove it down our throats, till we choke
                                        Windows 2000: Initial release February 17, 2000
                                        Windows ME: Initial release September 14, 2000
                                        Windows XP: Initial release October 25, 2001
                                        I'm sorry but what the fuck where they thinking?
                                        Windows 9x was dead when Win2K got released which is based on the NT kernel.
                                        Releasing another 9x based OS after Win2K was madness at it's best, not even the stupid Metro interface can match that in stupidity!
                                        And fuck me how unstable that POS was, ME is the worst OS Microsoft ever made.
                                        Vista is a nice runner up and Win8 an even better one, but still not even close in the "shittiest POS ever made" race
