BBS POPUP Error massage
  • alihomee
    • Dec 2012
    • 1584
    • malaysia
    i have a ecs mother board with a error. when i start it ,display comes and a massage appear on first screen[press f8 for bbs popup].and when i press f8 then nothing happens but it shows[go-!> boot menu]. what is that means i need help
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: BBS POPUP Error massage
    It's not an error. It's a boot selection menu, allows you to choose what device to boot from.
    • alihomee
      • Dec 2012
      • 1584
      • malaysia
      so when i press f8 no boot menu appears it just go-! > boot menu
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        check your boot settings in the bios, it usually reflects your boot priority.
        If you have hard-drives, optical drives or USB flash drives hooked up it should be listed in the boot menu. Enable your onboard lan pxe rom and see if it shows.
        If it doesn't, sounds like a bad bios, reflash with the lastest bios from ecs for your board.
        You can try clearing the cmos before flashing to see if it's just corrupt settings causing your issue, it will be a jumper on your board, refer to your motherboard manual for location.
        • alihomee
          • Dec 2012
          • 1584
          • malaysia
          so how can i flash bios
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            go to ECS website
            www.ecs.com.tw
            Select download, type in your model and revision of your board, go to bios, download the latest version, and there will be instructions on how to flash. Be sure it's the correct one, and don't turn off the computer or lose power during a flash otherwise you'll brick it.
            • alihomee
              • Dec 2012
              • 1584
              • malaysia
              how can i flash biose because it does not boot on error screen it helt and no other screen comes
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                can you get into the bios? del, f2?
                • alihomee
                  • Dec 2012
                  • 1584
                  • malaysia
                  no i cant access to bios
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    Do you have any drives connected to the motherboard ? - for example hard disk, CD/DVD or floppy
                    If none of those are connected, may explain why you cannot access BIOS
                    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                    • alihomee
                      • Dec 2012
                      • 1584
                      • malaysia
                      no drives are connected to mobo.and i cant understand your last words
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        You've mentioned BBS Popup, which is related to media (drives) from which it can boot
                        If, like you've said, you've no media connected from which it can boot, it may be getting hung up in firmware (aka BIOS) before it gets to process you pressing the (presumably) Del key to get into BIOS setup
                        Try connecting some known working drives
                        • alihomee
                          • Dec 2012
                          • 1584
                          • malaysia
                          i have been tried it but nothing.it only stucks on first screen and when i press f8 i does nothing only the changes to[go-!> boot menu]
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            If it "changes to[go-!> boot menu]" sounds like it wants to display a boot menu, but cannot find device(s) it thinks are capable of booting from, hence cannot display a boot menu
                            Are they known working drives that you have tried ? - in other words, drives that function properly with other motherboards
                            Do you wait after "changes to[go-!> boot menu]" ? - perhaps there is a time-out interval after which boot menu appears
                            Have you tried forgetting about F8 and pressing only Del, assuming Del is the appropriate key for access to BIOS settings ?
                            If all else fails, try clearing CMOS - there may be a jumper which does that, or for 100% certainty remove the CR2032 BIOS battery and leave it out overnight
                            Then next morning replace battery, start motherboard, and press only Del to access BIOS
                            If you do manage to access BIOS, load Default settings, then see if it co-operates
                            • alihomee
                              • Dec 2012
                              • 1584
                              • malaysia
                              thanks for answer i have been tried all that you all talking about but fail to enter the bios settings
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                What machine is the motherboard from?
                                Have you actually tried it with a bootable source connected?
                                When you press F8 and get the message {go-!> boot menu]
                                have you tried pressing Esc.?
                                • alihomee
                                  • Dec 2012
                                  • 1584
                                  • malaysia
                                  ya ihave been tried it .it is a nonbrended mothedbord made by ecs
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    ECS?
                                    Sure all the caps are good?
                                    Could be a fried chipset or the like... ECS doesn't exactly scream "high quality"...
                                    sigpic
                                    (Insert witty quote here)
                                    • alihomee
                                      • Dec 2012
                                      • 1584
                                      • malaysia
                                      ya surely no bad caps.it is a 775 socket mobo with 2 ddr dimm ,2 sata,1 agp ,and 3 pci slots with a 20 pin power supply connector
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        When it flashes on does it say which bios it is using Amibios of megatrends or something. Can you post a good picture of the board? showing any board numbers.
                                          LCD LED TV Service Menu Codes
                                          TCL LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          10-31-2024, 03:58 AM
                                        • claws77
                                          FX553VE-DM318T(FX553v) not POSTING
                                          by claws77
                                          Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
                                          Gpu - nvidia geforce 1050ti
                                          Ssd orion o700
                                          Hdd hgst721010A9e630
                                          See images
                                          What's not working right?
                                          The system does not even POST, display is black,
                                          LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
                                          When did the problem happen?
                                          My laptop had dual boot setup, ubuntu and windows 10.
                                          It already had a moklist error, that would occur when i tried to boot ubuntu.
                                          05-17-2025, 04:09 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • eltano4i20
                                          [HELP] SAMSUNG NP270E4E-K01AR
                                          by eltano4i20
                                          1) Error trying to enter the BIOS
                                          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                          BOOT PRIORITY ORDER (img-05)
                                          1- Windows Boot Manager
                                          2- SATA HDD
                                          3- NETWORK
                                          4- Debian
                                          2) Error trying to access the BOOT MENU
                                          --> I restarted the notebook and pressed [F10] but the BOOT...
                                          07-04-2025, 12:39 AM
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
