Change hard drive letter path after clone?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    My Samsung 1TB drive was getting slow and making weird sounds so I cloned it to a Seagate Constellation ES 2TB drive. The Samsung was my secondary data drive and was labeled F:/ The new one is E:/ so none of my paths are correct anymore. I tried changing it to F:/ in Disk Management but it isn't an option. I tried looking for the original drive driver and couldn't find that. The program I used was HD Clone 3.8 Anyone have any ideas?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Change hard drive letter path after clone?
    Okay I got it to work but now almost every steam game I have has disappeared even though they're all on the hard drive with the original path, and all the data is the same
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      anything here any help
      https://support.steampowered.com/kb_...7418-YUBN-8129
      • federalhouse
        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
        by federalhouse
        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
        **Background:**
        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
        **What I've Tried So Far:**
        1. I accessed
        08-01-2024, 07:03 PM
      • tmcw
        PC case - Hard drive rails
        by tmcw
        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
        Now, the case is a CiT Gaming Case, and...
        05-22-2022, 12:04 PM
      • ash91
        Hp pavilion 15 not detect hard drive
        by ash91
        Hello gentelmen .... this is my first post and sorry for my bad english,
        so my proplem is my laptop keep losing hard drive even if i but the
        hard disk in the cady (the box that can replace the dvd rom with hard disk)
        when i turn the laptop on the massage that said no boot media found pop on
        the hard disk is fine and to be sure i try another hard
        i also update my bios to the last update
        the 5 volt is present on the hard connector on the motherboard
        the dvd rom work fine when i but a windows dvd in it
        also when i boot from flash...
        06-07-2023, 01:45 PM
      • ChaosLegionnaire
        bug of the month: write caching setting for the hard drive in device manager
        by ChaosLegionnaire
        i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
        so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
        10-06-2019, 01:39 PM
      • karto95
        Repairing a Seagate hard drive with damaged logic board
        by karto95
        I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
        I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
        If anyone has any suggestions or experience with this...
        03-21-2023, 04:05 AM
