Hitachi RMA
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Hitachi RMA
    had a custs's sons hd go bad, he got a brand new WD black, and as it turns out his hd is under warranty, but he can't wait for the rma
    I decided to RMA it and got this surprising agreement. I guess this means north korea can't use HGST/Hitachi/WD in military computers. Or they could just click 'I agree' and lie, why not
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Hitachi RMA
    seagate has that notice on their invoices or did.
      Re: Hitachi RMA
      I am imagining a certain Kim Jong-Il sitting at his computer (a few years ago)
      Originally posted by iTunes User Agreement
      You also agree that you will not use these products for any purposes prohibited by United States law, including, without limitation, the development, design, manufacture or production of nuclear, missiles, or chemical or biological weapons.
      "Dammit!"
      "Our nuclear program was doomed from the start!"
      • severach
        • Aug 2007
        • 1055
        Re: Hitachi RMA
        So name a country in which that drive can be used.
        sig files are for morons
        • BigTroll
          • Sep 2010
          • 1317
          • LAMBDA SOND
          Re: Hitachi RMA
          Kim Jong has a stash of Connor Peripherals and Miniscribes to hold him over along with a HUGE collection of AM286 machines with token ring network cards.
          My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
          • larrymoencurly
            • Oct 2004
            • 960
            Re: Hitachi RMA
            It only stops the honest nuclear, biological, and chemical terrorists.
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • wolf1976
              hitachi 50hk5600 problem with display
              by wolf1976
              hi
              i have the above tv and the display starts distorts the display at only in applications like you tube
              after and on the didital channels
              now without connect the antenna only the image of itsselfs tv i have the image i have in attach
              i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
              can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
              09-13-2025, 02:26 PM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno può averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
            • dragometin
              Hitachi 40HYC42
              by dragometin
              TV Model: Hitachi 40HYC42
              Power Supply: 17IPS71
              MainBoard: 17MB95M
              Panel: VES400UNDS-2D-NO3
              When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
              I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
              Is there any variants on 17IPS71 power supply's?
              UART output pins 10 and 12 on scart connector:
              Code:
              12:24:04.595
              08-08-2024, 05:53 AM
            • sotodefonk
              Help finding the correct model of a T-Con board on my Hitachi TV
              by sotodefonk
              Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
              I opened the tv to access the board and took the shared pictures of the T-Con board.
              I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
              I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
              Inspecting...
              06-28-2024, 04:39 PM
