Received by error
  • Phaihn
    • Jan 2009
    • 842
    Received by error
    A 400v 560uf cap today anyone got any good ideas of what i can do with it i am think of a wind up flash light or something along those like that.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Received by error
    For a flashlight I'd prefer a low voltage high capacitance unit, these high voltage low capacitance units you'd have to use for something like xenon flash or something.
    • c_hegge
      • Sep 2009
      • 5219
      Save it for when you need to replace a PFC Cap
      • Phaihn
        • Jan 2009
        • 842
        right now its still sitting on my desk. on another note does anyone know what or whare i can get a <ph>3w1r2k?
        My Computer.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Is that a fusible resistor - picture of it ?
          Forget that it is your other post - dont know why you did not just ask there?
          • Phaihn
            • Jan 2009
            • 842
            i hadnt created that thread yet at the time i asked the question.
            My Computer.
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
            • Curtissimo
              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
              by Curtissimo
              Hi everyone.
              I have a HP Elitebook 850 G8.
              Serial: 5CG2324XM0
              ProdID 6L8D5EC#ABA
              It has a Winbond W25Q256JVEN Chip.
              I need to remove BIOS Password.
              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
              Attached my dump.
              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
              What I did:...
              Yesterday, 04:42 AM
            • Maalobs
              Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
              by Maalobs
              I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
              The relevant service manual for the chassis is available here.
              The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
              When I short the SDM to ground I get the layer-2 error code 53.
              The inside of the TV has no damaged components and no swollen capacitors.
              In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
              04-02-2019, 01:15 PM
            • medinfo
              Mac T2 after update(There was an error activating your device)
              by medinfo
              Macbook Pro 2019 T2
              iCloud OFF
              MDM unlocked by changing Serial Number
              worked fine but after latest update see (There was an error activating your device. Please try again).
              Erased and boot in internet recovery, same error.
              changed to original serial number (iCloud OFF & MDM ON), same error.
              tested with others serial number, same error.
              tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
              Revived and restored by Apple Configurator and same error.
              Any help ?
              12-31-2023, 02:04 PM
