Broken Ribbon Repair
  • Time2Retire
    • Aug 2012
    • 256
    I have a ExoPC tablet that I got cheap on fleabay. There were problems with the battery charging (which I fixed), but I had to open it up to fix it. I read through the ExoPC forums, and found warnings to be careful of the touchscreen ribbon when opening the tablet. I was VERY careful, but still managed to tear the ribbon off of where it was attached to. I did not realize just how fragile this connection was.
    I found one How-To on repairing a ribbon on an Apple mouse, using conductive epoxy:
    http://stcwk.blogspot.com/2010/03/ho...bon-cable.html
    I thought that I could do the same procedure with this ribbon. I have bared both sides of the connection, but have yet to finish the job. The ribbon is very tiny, so the possibility of bridging the traces is very real, even with using conductive epoxy.
    My plan was to do this:
    1) Tape the connections in place using clear packing tape on the backside.
    2) Use an X-acto knive to cut spaces between the traces, leaving gaps between traces.
    3) Then apply the conductive epoxy to the traces, fixing the severed connections. The gaps I cut would prevent the epoxy from bridging the traces accidentally.
    4) Use more packing tape, on both sides, to reinforced the fixed cable.
    Anyone see any problems with this solution? I was wondering if the packing tape may be conductive, and not a good choice. Opinions would be greatly appreciated.
  • sofTest
    • Aug 2008
    • 361
    Re: Broken Ribbon Repair
    Might work. I would probably try soldering, and use liquid tape to insulate and strengthening the work.
    Be a mensch
    • Time2Retire
      • Aug 2012
      • 256
      Soldering plastic??
      It would melt before the solder even got to a flowable state.
      • sofTest
        • Aug 2008
        • 361
        The traces is not plastic. It's delicate work, but like repairing traces on a circuit board.
        Be a mensch
        • Time2Retire
          • Aug 2012
          • 256
          You cannot heat up the traces without the heat transferring to the plastic. I don't want to make things worse, I want to fix it. Have you done similar repairs? Not on circuit board, as that is a different animal.
          • Time2Retire
            • Aug 2012
            • 256
            I see there is something called "kapton tape" that may work to hold the two pieces together. When I googled it, I see some is just film, with no adhesive. Anyone have any recommendations on a good kapton tape to use?
            • larrymoencurly
              • Oct 2004
              • 960
              I don't know if it's good, but DealExtreme.com sells kapton tape with adhesive on it:
              http://dx.com/s/kapton+tape
              If you don't need heat resistant tape but can apply it after doing any soldering, ordinary Scotch tape or plastic packaging tape ("poly" tape -- polypropylene) is just as good.
              • Time2Retire
                • Aug 2012
                • 256
                Thanks for the info, and looks like good prices too. I just ordered some from DigiKey, but at three times the price! Is DealExtreme a good place to get stuff from? I have never heard of them before.
                • larrymoencurly
                  • Oct 2004
                  • 960
                  I wouldn't expect high quality for no-name stuff (circuit boards for products can be incredibly bad) or even branded stuff (counterfeit, as mentioned in some threads here about caps, like the Teapos disguised as Sanyos), but the service is really good, and they're the place to go if you want to buy a Rigol oscilloscope, underwear, violin rosin, fish food, and NSW products all from a single source.
                  • Time2Retire
                    • Aug 2012
                    • 256
                    What are NSW products?
                    • larrymoencurly
                      • Oct 2004
                      • 960
                      NSW = Not Safe for Work, or items of an adult nature. Deal Extreme really does sell everything.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Blow up dolls, pron, dill rods, adult toys, etc. Anything you can find at the XXX store and half of what is found at Spencer Gifts.
                        sigpic
                        (Insert witty quote here)
                        • Time2Retire
                          • Aug 2012
                          • 256
                          I always saw this as NWS, but same meaning.
                          • Duncanbest
                            • Jul 2012
                            • 81
                            • Taiwan
                            FYR
                            http://www.youtube.com/watch?v=E49tv...eature=related
                            • Time2Retire
                              • Aug 2012
                              • 256
                              Originally posted by Duncanbest
                              Thanks, that looks interesting. I guess I could just bare both ends of the ribbom and just stick them on top of each other.
                              I found a USA seller, with the shortest/cheapest piece:
                              http://www.ebay.com/itm/3M-9703-Cond...item337a048045
                              • sofTest
                                • Aug 2008
                                • 361
                                This is not my work, but you'll get the basic idea and technique.
                                http://www.youtube.com/watch?v=n1Lve6lHeOw
                                Be a mensch
                                • soramarforever
                                  • Jul 2013
                                  • usa
                                  Time2retire. How did you fix the problem with your battery not charging? can yiu share that information? thank you.
                                  • Time2Retire
                                    • Aug 2012
                                    • 256
                                    I found the spec sheet for my battery, and it said that there was a low voltage threshold. If any of the cells dropped below this voltage, charging would be prevented on all the cells. One of my tablets cells had dropped below this voltage
                                    I had a battery from netbook that had a bad charging board. I soldered leads onto these cells and piggybacked them onto a good netbook battery and charged them. I then took one of the charged cells and hooked it onto the low-voltage tablet cell. The effect was that they tried to equal each other in voltage. The low-voltage cell sucked the power from the charged cell. It increased the voltage enough that I could then charge it normally.
                                    The two batteries were of different size. One was a flat Li-ion for the tablet, the other was a cylindrical Li-ion common in laptops and netbooks. But, they both were Li-ion rated at 3.7 volts. Still, I did it outside behind a sheet of plywood. I have heard of Li-ion batteries exploding!!
                                    EDIT:
                                    I found my posting of this on the ExoPC forums. In case I left anything out, here it is:
                                    I purchased an ExoPC off of eBay for only $176 total. It has a bad battery, in fact it doesn't even recognise that it had a battery in it.
                                    I opened the unit and removed the battery pack. I then peeled back the covering surrounding the battery pack. Inside is a circuit board and two Lithium-ion polymer batteries 3.7V (see the previous post for the attached pdf file for details). When I checked the cells, one was 3.12 volts, and one was 2.76 volts. According to the battery document, there is a circuit cut-off, if a cell goes below 3.0V, it will not charge it.
                                    I looked all over on-line, and could not find a cell that would work for a replacement. So I decided to see if I could somehow charge the battery I have.
                                    I have some standard Lithium-ion laptop cells (cylindrical), also 3.7V. I decided to try connecting one to the tabs of the low-voltage cell, and see if I could trick it to begin the charge cycle. I did this with alligator clips, and with the battery still disconnected from the tablet, I decided to check voltage once again. I found that the good/bad cell was now reading 3.25V. I disconnected the alligator clips, and found that the bad cell was now reading 3.12V!
                                    I reconnected the battery, and was able to charge it!
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • AK_777
                                      Sony KD-65A1 Repair – 4 Red Blinks Error
                                      by AK_777
                                      Hi everyone!
                                      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                      02-20-2025, 04:15 PM
                                    • chth96
                                      Is it possible bridging tiny broken trace
                                      by chth96
                                      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                      cutting tiny trace.
                                      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                      12-03-2022, 11:32 PM
                                    • pctravel
                                      Gigabyte GV-N3070Gaming OC-8GD Powers on- Device manager sees it but "error 43 stopped"
                                      by pctravel
                                      I don't know the history on the card but at the key there is a small chip, see below. Looks like trace B10 3.3v and B11 React, A1 12v and A11 Reset is a little short but looks like it could still make contact. Here is exactly what it does. I was installing windows on a test PC to use with this, the card did put out video at that time uing the standard GPU (was an old version of Windows 10- v1510). Nvidea driver update said that op was too old for the latest driver so I updated to the latest windows 10 version. After fully updated Windows 10 was finished it doesn't put out video at all now. Using...
                                      03-15-2024, 11:40 AM
                                    • ngodatvd5
                                      Micro not detected and db board Asus UX325E
                                      by ngodatvd5
                                      My computer does not detect the microphone. When I opened the laptop, I discovered that the sub-board was missing screws, and the keyboard had been replaced by plastic welding (the keys came loose because it was not secure). On the board, I found that a part of it was broken (I am not sure whether it was broken by the person who replaced the keyboard or if the loose keys caused the damage, but I could not find the broken piece inside the laptop). In the broken area, I saw some circuit traces, but I am not sure where they were connected to. If anyone has this board, could you please help me identify...
                                      09-10-2025, 06:03 AM
