Super! I just tweaked my Asus P2B-F motherboard! It now has a slot 1 Coppermine!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    I found a web site of how I can take out my Katmai 450 Mhz and put in a Coppermine 850 Mhz!
    I decided to first check the Vcore regulator chip and the code indicates I have a late revision P2B-F. Then I flashed the BIOS in DOS to 1013.
    Then I cleared the CMOS and swapped the processor.
    Turned on the power... It's POSTing!
    I just put the motherboard back to use, because I have another slot 1 motherboard, an Intel, that isn't looking so good in comparison:
    1: There's an odd looking cap, it looks like it wants to bulge, lol. Looks like it may be a silver Nichicon.
    But I can't confirm it's bulging. It's a cap with no vent. Between PCI slots.
    2: That board has mostly Nichicon PWs next to the processor.
    3: But unfortunately, it's looking more like the Intel motherboard is from the PRC, so I decided to junk it.
    Even though it has OSCON caps, (blue) but, there's only 3 of them.
    So I decided the Asus P2B-F is the winner! ROC goodness! Which, it's loaded with United Chemicon LXZs, IIRC and Rubycon YXGs.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Super! I just tweaked my Asus P2B-F motherboard! It now has a slot 1 Coppermine!
    Remind me, what exactly is wrong with nichicon PW?
    My Intel CuMine slot 1 board (a VC820) has PW and PW IIRC is a good series. Since you can't overclock, I don't see whats wrong with PWs.
    If you were going to OC, you might have a point, but you didn't mention an OC.
    Edit- Your intel board is made by foxconn... Yeah, PRC (I think), but it's not a mark against the quality given the era in which it was made.
    sigpic
    (Insert witty quote here)
    • RJARRRPCGP
      • Jul 2004
      • 6304
      I actually didn't think there was anything wrong with PWs.
      I almost kept the Intel board going, but, there's an odd looking cap between PCI slots. That made my score go down enough to junk it.
      Arc A770 16 GB
      • c_hegge
        • Sep 2009
        • 5219
        There is indeed nothing wrong with PW series, and there never has been.
        At least during this era, ASUS gear was actrually very good. Not like some of the stuff they come out with nowadays.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Pics coming soon.....
          Arc A770 16 GB
          • mockingbird
            • Dec 2008
            • 5484
            Why not go full Tuallatin PIII-S on this? You can take it to 1.4Ghz without any overclocking. You need a Tualatin adapter. There were two made. The first was the one from Powerleap, which had its own VRM. These are quite rare, and I saw one being bidded on for over $100 somewhat recently. The second is the much more common Upgradeware Slot-T. I think I bought mine for like $20 more than 10 years ago.
            The only thing to keep in mind when running the FSB on the BX chipset at 133mhz is to set the PCI multiplier to 1/4, and that you use an AGP card which is not so sensitive to the AGP frequency overclock. The AGP runs on either a 1/1 or 2/3 multiplier (i.e. it's meant to run at 66mhz on either the 1/1 or 2/3 ratio setting). At 133mhz, it's running at 89mhz.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              My Asus P2B-F has this regulator:
              http://html.alldatasheet.com/html-pd...IP6019BCB.html
              Arc A770 16 GB
              • glovecaps
                by glovecaps
                11-25-2024, 04:23 PM
              • Docus
                Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                by Docus
                Hi everyone 😀,
                I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                1. I already own the exact same model, but its plastic chassis is badly damaged.
                06-10-2025, 04:24 PM
              • Archimedes
                HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                by Archimedes
                Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                Fans are spinning. Blindly could install windows11 and got the device manager...
                07-30-2024, 05:14 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
