Re: Got a brand new dead motherboard, don't know what to do with it
I'll check out the slots when I get home, but the chances of both of them having some pins blocked are pretty strange. Especially being brand new out of the box. I'll also try a Pentium 4 in there, it may have one of the first versions of the BIOS. Thanks for the replies guys! I don't think I do have a PCI video card around but I know a shop where I could grab one for like $2...
The only thing that comes to my mind would be to carefully examine that PCI-E slot, maybe there's something stuck in it that's shorting out or blocking a few pins.
Also, if you have such a dinosaur lying around, try it with a PCI video card.Leave a comment:
if its beeping at you, its alive. Try a different CPU.Leave a comment:
Sounds like a VGA output issue.Leave a comment:
Yeah, it's in the supported list on Intel's website. Even if it didn't, it would probably have a rage of continuous beeps. Or at least you would think. I tried a Pentium 4 530 that was stated to work with the very first version of BIOS and still got no video.
EDIT: Thanks for the replyYeah I guess I could try that again
Just noticed that the pentium d is supported from bios version 2015.
That bios revision was released in 2008, your board has been sitting there since 2005 so i am guessing it wont have that bios in it.
You will have to put a pentium 4 in for now and update the bios to the latest one. Hope that helps you.Leave a comment:
Does it support the pentium D?Leave a comment:
So my buddy gave this motherboard for free to me from his work because it has strangely been sitting in inventory since 2005 and was lost since then....they were just going to throw it away but my buddy grabbed it for me. It's an Intel D955XBK and it was brand new in the box. I put it in a case and put in a Pentium D 940 3.2GHz with a Cooler Master Hyper TX3. Put in 2 sticks of RAM, a video card, and for the life of me could not get this thing to display video.
It was beeping continuously and I discovered one of the RAM sticks wasn't in all the way, after that it would give a single beep but no video...I tried 4 different graphics cards and even one in each slot and every DVI port one by one. Never got video. I had a 8 pin plug in for the CPU, so I know that was getting enough juice, and I had the molex plugged in above the top PCI-E slot just to be sure. I wonder if the slots are dead? This thing would be a great server board....supports ECC memory up to 8GB, has gigabit, and 8 SATA ports with RAID support...
Any hope for this thing? Or sure I just desolder all the beautiful Rubycon and UCC KMG caps off it?
by tk3000My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few... -
by DrvLikHellGreetings and sanitations! Several years ago I received some really awesome help on this forum for fixing my monitor (which is still working) so I figure maybe someone can help with this laptop issue.
I have a Dell E6540, motherboard 9411P, DP/N:VWNW8. A year ago it died a strange death where at first it wouldn't turn on all the time, but would turn on when it felt like it, then it got worse where it wouldn't turn on at all and I would just get a flashing light. So I replaced the motherboard with a matching part number board. (I still have the old motherboard) Now a year later this... -
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by SavaBogdanHello. I am having some trouble with a X299 motherboard. I did some searches and I found very little info about these X299 chipset motherboards. It's a bit strange because they are known to be unreliable and I expected to find lots of posts. So I decided to make a thread and ask the experts for help
Ok, here is the info I have.
The board is completely dead, nothing happens when I try to start it up.
I stripped it down and started measuring. I have 3.3v on the power on switch pin, so that is ok. I also found 1v on a coil near the sata ports and 3.3v on the coil next to the... -
by HerbssatHello guys. This motherboard has no signs of life after turning off one day. Disassembled the machine and took the bios battery out then pressed the power button for 30 seconds. Board turned on again momentarily but was short lived and didnt turn on again. Flashed bios with a 341a programmer and no change. Board has no shorted power rails and is outputting 3.3v and 5v alw. No other rails are present when pressing the power button and the voltage is there. Also no voltage drop at the power switch when pressed like its not even there. Running out of ideas on this one. Any help is appreciated.
- Loading...
