Things you can find on that dead motherboard in the closet
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I was pulling random stuff from a Gigabyte 865 chipset board i had lying around. I had already stripped all the big things and was going for the more interesting SMDs.
    After pulling a bunch of 1N4148s and schottkies, some FETs, and a couple SOICs i thought i'd need, my attention focused on the 1206 ceramic capacitors around and in the middle of the CPU socket.
    I was expecting them to be 100nF, maybe 1uF. But when i measured them... 10uF. I didn't even know they made 10uF ceramics in 1206. They're definitely gonna come in handy. And they were more than a dozen. I'm off to look on the other dead boards. Edit: Found 22uF on a LGA775 board... yay!
    A working TV? How boring!
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Re: Things you can find on that dead motherboard in the closet
    I always face the dilemma of recovering components from a board, or just leaving them on the board.
    I usually end up removing items that protrude quite a bit off the board, like heatsinks or big caps, and either desolder or break off a FBT if it's near a corner and the board already has cutouts around the FBT, which they often do. After that, the fairly intact boards go into large plastic container boxes.
    Besides, if I was to be recovering individual items, it would mean having to get sorting trays or bins, and possibly worsening an already mild OCD illness!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      I was going through some dead laptops work gave me last year and found a Socket 478 desktop P4...3.4 HT in one
      don't see many of those, at least I don't
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        I don't want to know how hot that thing got!!
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Th3, be careful how you use those caps. They are probably rated for 16V, and the tempco is probably Z5U or Y5V, which means the value probably changes 5% if you warm it for 2 seconds with your finger. I'm not sure that's an exaggeration, BTW. Also, if you apply more than 3VDC across it, you've changed its value significantly.
          Those are two of the reasons I consider SMT monolythic cerammic caps eeeee-vile ... necessary, but evil.
          PeteS in CA
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Will check with my hot air gun about the tempco. I don't intend them to be anything else than standard bypass caps, and for that they should do okay.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              I usually leave them on the board and keep the board - makes it easier to find the part and to see what it is, especially if it's SMD. SOIC-8 MOSFETs are a prime example of this.
              At work, we have a big crate full of dead Xbox 360 boards. Most of them have had their GPUs and CPUs removed and many of them have dead caps so they are not very useful for that. However, each board has about 20 or so D^2PAK MOSFETs, most being in the 60-80 Amp range. Also many coils and toroid inductors on those.
              My main source of parts at home is a dead Radeon 9500 Pro/9700 video card. It seems to never run out of parts, and I've pulled stuff from it for my other 7 Radeon 9500Pro/9700 video cards. Also fixed many LCD monitor t-cons with it by pulling random ceramic caps like Th3_uN1Qu3.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                I have a bunch of hospital vials complete with holder. The type normally used to store blood samples and such. They are made of plastic and have an airtight cap. I use them to keep screws, washers, and other small parts. Like SMD devices for example.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  You should use them to keep good caps separate from bad ones so that the good ones don't catch the "badcaps" disease .
                  • villiam
                    • 16
                    Hi, I just recently came across these large value ceramics. I believe they are a pretty recent development intended as alternatives to some polarised electros. They are called MLCCs. Multi Layered Ceramic Capacitors. I think they top out at around 50uF 50V. They vary pretty wildly in price from small quantity price per cap of say 50p up to > 30GBP! Lots of the ones I was looking at were X7R.
                    • tk3000
                      Dead Laptop Motherboard, then refurbished one installed...
                      by tk3000
                      My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
                      Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few...
                      08-20-2022, 08:45 AM
                    • DrvLikHell
                      Dell Latitude E6540 - 2nd dead motherboard
                      by DrvLikHell
                      Greetings and sanitations! Several years ago I received some really awesome help on this forum for fixing my monitor (which is still working) so I figure maybe someone can help with this laptop issue.
                      I have a Dell E6540, motherboard 9411P, DP/N:VWNW8. A year ago it died a strange death where at first it wouldn't turn on all the time, but would turn on when it felt like it, then it got worse where it wouldn't turn on at all and I would just get a flashing light. So I replaced the motherboard with a matching part number board. (I still have the old motherboard) Now a year later this...
                      01-30-2021, 02:36 PM
                      ASUS P5GC-MX motherboard recap
                      by momaka
                      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                      So here is what the motherboard looked like with its original caps:
                      CPU VRM area up close…...
                      01-27-2021, 11:59 PM
                    • Bob_Crachet
                      Some help with troubleshooting a HP ProDesk 400 G2.5 SFF motherboard please
                      by Bob_Crachet
                      I am experiencing the following symptoms:
                      With the device fully assembled when I press the power button, nothing happens at all.
                      I pulled the power supply from the computer and stuck a paperclip into pins 16 and 17 on the connector causing the power supply to turn on and the fans to start spinning. All of the voltages checked out ok.
                      With the power supply outside of the case, I plugged it back into the motherboard and tested it again. No change. PC did not turn on.
                      I put my multimeter in continuity mode and put the black probe on one...
                      05-09-2023, 06:28 PM
                    • phantomEVO
                      [help] a2141 motherboard 820-01700 completely dead
                      by phantomEVO
                      history "suddenly dead"
                      no water damage, motherboard seems perfect.when i try to power it on, i have no activity at all..no fan spin...
                      https://vimeo.com/718664957
                      06-09-2022, 05:11 AM
