  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: !$!@$!@$!@%!^$^^%@$!$@!$!@!@$!!!!!!!!!!!!!!!!
    Originally posted by Uranium-235
    well I opened it up. No burn marks, no burn holes on any mosfets, fuse is ok. Ugh, no way to tell what the fuck is bad
    I think the graphic card might be at fault. It could have been that card all along too.
    The resistance of the pins at the mobo power connector could have been just high enough to keep the graphic card from frying, but when you added a new 12v connector, there was now much less resistance, causing the graphic card to go kaput.
    Do you know what smoked on the graphic card? Was it the graphic chip or one of the vrm mosfets or diodes?
    Muh-soggy-knee
    • Agent24
      I see dead caps
      • Oct 2007
      • 4952
      • New Zealand
      Maybe I missed it but did no-one think to blame the PSU for this?
      -David VanHorn
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        no actual smoke, just a burning smell from around one of the vrms near the connectors
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          See, I think you stressed out the VRM causing it to fail, usually they don't fail under normal operating conditions. I think its just a coincidence that it happened right after you did the mobo connector mod.
          Of course you could try to replace the VRM components to try to fix it
          Muh-soggy-knee
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            I was thinking. I checked the fuse, its ok. so yeah. I'll post a pic
            it was probably the power supply. Probably fucked up enough to overvolt that line, though hmmm the motherboard wasn't damaged. Still refused to stay on tho. doh well. hey whats that goop they use to insulate joints on boards?
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              #26
              boy computers really fucking hate me today
              my laptop has been having this issue where I pull the screen forward a little bit the inverter will shut off. I hit the lid sensor quickly enough and it turns it back on without initiating sleep mode
              well I decided to fix this, as it did some thing similar a few months back, taking the screen off and jiggling around the wires fixes it. This time, it did not. Infact, it worked, until I put the screen cover back on. over and over. Then I smelled something burning. the fucking pink wire to the lamp had burnt in half :O
              I stripped the insul off the sides and hooked it back together, worked fucking fine. soldered it, put some electrical tape over it, and put the cover on. fucking works great
              only real problem is the where over the inverter is dosen't go all the way down. its annoying as hell but oh well
              • CapLeaker
                Crimping CAT7 connectors high failure rates
                by CapLeaker
                I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                11-09-2024, 04:11 PM
              • Eniaro
                Are USB C connectors standard
                by Eniaro
                I have a number of laptops with damaged USB-C connectors.
                I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                07-24-2023, 03:07 PM
                RJ45 Block Diagram / Schematic
                RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
                The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
                10-31-2024, 04:18 AM
              • corrize
                Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                by corrize
                Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                I have :
                - hot air, and a
                ll stuff around
                - true kapton tape
                - 140 and 180 degree soldering paste
                - bismuth
                - little hot plate 250 degree max
                - the new BGA chip with probably
                05-20-2025, 01:26 AM
              • Jackching
                Intel PC hooked to X90L television picture cut-off
                by Jackching
                I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                10-27-2024, 11:43 AM
