  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    as an extention to this: thread: https://www.badcaps.net/forum/showthread.php?t=16939
    I came up to a dead computer today. Cleaning the connectors usually worked if it the under voltage triggered the overcurrent, but it has never just NOT WORKED. No pre operating light, hooked it to another motherboard, same thing. Hooked my TR2 430 to the board, got pre-op light (didn't turn it on cause 12v cpu wasn't hooked up)
    I thought the connectors have finally burned to the point where there was connectvity, so I salvaged some from a crappy PSU, soldered them in place, same thing.
    tried other power cables, disconnected all other psu cables from everything. nothing. shorted 4-5, nothing. FUCK.
    and I bet cutting the burnt connectors off and soldering good ones in there voided my warranty.
    seems i'm going to be working on the cap db more cause no more gaming for me for a long, long time
    :cry:
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: !$!@$!@$!@%!^$^^%@$!$@!$!@!@$!!!!!!!!!!!!!!!!
    heh. maybe if business is doing well I can talk TC into buying a new PSU for me in exchange for the several, and going to be hundreds of hours working on the capdb
    I just got finished with Acon. ~5000 more datasheets to go
    • c_hegge
      • Sep 2009
      • 5219
      It's probably the motherboard if replacing the connectors doesn't help.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        no its not the MB. not exactly. The problem is my two GTX 285 black editions draw too much from the 12v1's which the extra currents causes them to get hot, and burn (as mentioned in the aformenteioned thread). However, I would clean the pins on the atx connector out and the temp would drop and it would work fine. what would happen is if it got too hot, that would mean there is too much resistance cause of some kind of corrossion caused by the heat, voltage drop, and to compensate, amperage would go up, tripping the overcurrent and turning the computer off. These last few weeks the connector has been hot, but cleaning has not worked, however it never turned off. I think what happened is the overcurrent protection failed, and just blew the damn thing. I'm only going to open it up if corsair turns my warranty down. has a lifetime warranty
        I plugged a 430 into my computer and it had the pre operating light.
        If I can get another PSU, i'm going to get a atx extention, cut the v1's and solder them right into the 12v's on the other side of the board (with pooky to keep any shorting. Then just plug the psu connector into the adapter.
        board is fine. its been through some insane OC's and chugged along beautifully.
        I still wonder if corsair will take this back. the warranty sticker is not voided or broken, just some...juryrigging on the connector (I may post pictures later). Would be great if I could get another one, but this would be my second TX850 replacement and i bet they will start to call BS on me
        • c_hegge
          • Sep 2009
          • 5219
          What I meant is that the connector on the board could be toast (pun very much intended).
          I'd probably remove the 285s, and use a low end card, and then see if it will boot up with the 430W.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            yeah, it probably is, which is why I'm considering the soldering option. i'm not the only one who has done this before
            EVGA actually makes this neat little adapter that takes a molex connector that plugs into x1 PCI-E to provide addition 12V support to the PCI-E bus power system, which is the problem here
            • c_hegge
              • Sep 2009
              • 5219
              If you're no longer going to be using the plug to provide 12V power on the ATX connector, then I'd try to get 3 or 4 wires and connectors coming off the bottom, otherwise, it's just gonna melt the adapters. AFAIK, molex connector pins have a slightly lower current limit than ATX conector pins (5A vs 6A).
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                but you see it doesn't SUPPORT it by ITSELF, it provides ADDITIONAL support to the 12v1s by providing additional amps directly to the PCI-E from a different rail.
                this is what i'm talking about
                http://www.techpowerup.com/136908/EV...Stability.html
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  How big of a PSU do you need? Would you mind paying shipping? I might have a spare PSU for you.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    850 minimum, good quality
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Sorry, I wasn't talking about the PCI-E power boost card. I was talking about modifying the ATX connector. I meant that if you're going to be relying only on the wires you solder on the bottom of the board to provide power, then you should have 3 or 4 wires there.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        I guess 550w wouldn't be good enough. Nevermind then, sorry.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          can't handle 2x XFX factory OC GTX 285's
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            You could always give them to me my 750W PSU in my main pc can handle them for sure :P
                            jk
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              hey question for everyone. do you think that in some PSU units, the shutoff from overcurrent can be based on heat? cause that psu had a large low flow fan on bottom...and I had a med flow usb fan practically attached to the back, blowing out the hot air
                              • Mad_Professor
                                A Mech Warrior
                                • Feb 2011
                                • 1587
                                Quite possible, I wouldn't see why not, as it would prevent the thing from catching on fire.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  WELL !!#$@$#WR@#%#!$@#$@!#$@!#$@!#$@#$~@!$~$@!!!!!!!!!!!!!
                                  I shorted the on pins on it and it worked now, put it in my motherboard, the pre-op lights came on. I turned it on. it turned off a few seconds later
                                  smelled something burning. My GTX 285 is now dead
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    I wonder if your card could have been dying all along...
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      nope. I think I got the 2 12v1's switched around when I redid the connector, thats the only thing I can think of. Or the power supply is just so dead it put too much juice to it. Motherboard still works though. Managed to get a Thermaltake 430 and a gf6200 in there to prove that. All I need to do is fix the fucking atx connector, and try to rma this power supply. I'm tried looking into XFX rma but have found nothing but missing pages on thier website. Even if I were to I bet they could not send me this model, been too long
                                      right now all I have is a box to play tribes ascend. C2D 6750 @ 2.9, 4gb ddr2, the living twin of the aforementioned video card. Thermaltake TR2 430. 160G sata I had stashed away in my media box. And win7. not gonna activate it since all I use it for is T:A, i'm just going to use easeus to make a small additional partition and copy the drivers and stuff and just do a fresh reinstall when the license runs out
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        well I opened it up. No burn marks, no burn holes on any mosfets, fuse is ok. Ugh, no way to tell what the fuck is bad
                                        • CapLeaker
                                          Crimping CAT7 connectors high failure rates
                                          by CapLeaker
                                          I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                                          Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                                          11-09-2024, 04:11 PM
                                        • Eniaro
                                          Are USB C connectors standard
                                          by Eniaro
                                          I have a number of laptops with damaged USB-C connectors.
                                          I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                                          I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                                          I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                                          07-24-2023, 03:07 PM
                                          RJ45 Block Diagram / Schematic
                                          RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
                                          The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
                                          10-31-2024, 04:18 AM
                                        • corrize
                                          Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                                          by corrize
                                          Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                                          There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                                          I have :
                                          - hot air, and a
                                          ll stuff around
                                          - true kapton tape
                                          - 140 and 180 degree soldering paste
                                          - bismuth
                                          - little hot plate 250 degree max
                                          - the new BGA chip with probably
                                          05-20-2025, 01:26 AM
                                        • Jackching
                                          Intel PC hooked to X90L television picture cut-off
                                          by Jackching
                                          I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                                          10-27-2024, 11:43 AM
