SATA > IDE converter?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    No, the arrow is not reversed, I need a SATA to IDE converter, because I want to to do a crazy project, connect a Gigabyte i-RAM drive to a Dreambox DM7000 satellite receiver
    And the reason is that I have run out of memory on it, it only has 30MB RAM and I'm right now having to do swapping on a USB 1.1 memory stick, not the fastest operation as you might imagine... It also has the problem that flash based devices have a limited number of writes they can handle, and we are not talking about years to use them up but days... (when used like this as a swapfile that is)
    So, the Dreambox has a IDE interface, it also has a NIC interface but I do not wanna go that route because it does not do proper checks to see if the mount is alive before using it; thus hardlocking if the remote machine is not available...
    Just FYI the i-RAM only uses it's PCI interface to get power, nothing else... So I'm gonna desolder a PCI slot from a dead mobo and then connect 5v at the proper places to drive it...
    Of course the idea is crazy and I could just use less mods on the Dreambox or get a DM7025 (has 128mb RAM) but where would the fun be in that
  • toastygoodness
    • Jul 2005
    • 813
    Re: SATA > IDE converter?
    Where did you get that i-RAM drive? I've been looking all over the web for one and can't find a store that sells it!
    • gonzo0815
      • Feb 2006
      • 1600
      Yes this i-ram is a very interesting thing for us hw freaks.
      But unfortunately i haven`t seen a reverse adaptor in the way your looking for. Probably this isnt`t even existant.
      The only thing i have is the normal IDE HDD >SATA adaptor and thopse usb sata kables. But if those devices are only some media hubs and the commands are the same (as far as i know there is now differenz on the instruction set between IDE and SATA), those adaptors could be working in the other direction too. But i doubth that my bad guess could be real.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        gonzo; yea, I had the same thought as you... That they can work in reverse, however my only SATA drive is a Raptor 150GB and I'm not gonna risk setting it on fire
        toastygoodness; I have not bought it yet, however if I buy it it will be from eBay, they go for great prices there and shipping worldwide... just search for i-ram...
        I did some more research and saw that this i-RAM does not support Reg ECC memory, got a bit bummed by that since I have 2G's just laying around...
        So I did a fun test; put it in my Epox 9NDA3+ that does not have a single mention in it's manual about ECC, it worked just fine, passed memtest86+ 4 times and has been up for 24 hours now... I find it odd since the only difference between the Socket 940 and 939 CPU's was that the 939 would not require Registered memory; like the 940 pin CPU's does... Oh well, live and learn I guess
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Two links for your reading pleasure
          http://www.gigabyte.com.tw/Products/...ame=GC-RAMDISK
          http://www.anandtech.com/storage/sho...spx?i=2480&p=1
          • toastygoodness
            • Jul 2005
            • 813
            Thanks, Per. I found a few links on eBay.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Found it for 120$ here...
              http://www.ewiz.com/detail.php?name=MB-RAMDISK
              found the linkeh on storagereview...
              • arneson
                • Sep 2005
                • 1267
                http://www.cyberguys.com/templates/s...productID=2381
                PCI to IDE, common device may be reverse engineered.
                These guys also offer a PCI to PCMCIA card that's interesting.
                Just for FYI.
                Jim
                • arneson
                  • Sep 2005
                  • 1267
                  http://www.cyberguys.com/templates/s...productID=4668
                  This may be more appropriate.
                  Jim
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I already have 2x IDE > SATA converters...
                    I do not have any SATA harddrive I am willing to test them on though, it could go very wrong...
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      I have just got the new Cornad elektronik katalog, one of Germanies bigger elektronic component sellers, and guess what i have senn there? yes an retail Sata> IDE converter. It is sligthly more expensive than the Ide> Sata convertes, but with 29€ i think it is reasonable.
                      • DynaxSC
                        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                        by DynaxSC
                        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                        The board is generally working now, all PCIe ports are working, Windows installs normally.
                        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                        03-10-2025, 12:27 PM
                        HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                        This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-12-2024, 03:28 PM
                      • clabr
                        Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                        by clabr
                        Need help to solve some problems with this laptop.
                        After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                        After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                        Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                        Before this had happened I observed some other problems:
                        When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                        12-02-2021, 08:09 AM
                        Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                        by momaka
                        Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                        11-28-2020, 11:08 PM
                      • playit
                        psu sata power wires thinner - does it make a difference ?
                        by playit
                        hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                        i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                        any explanation on this ?? thank you ,soon i am planning to buy some branded...
                        10-12-2023, 05:25 AM
