Force charge laptop battery?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    What I'm really asking:
    Is there a way to force charge or jump start a lithium ion battery?
    The battery is
    as07a31
    made by sanyo.
    Long story:
    I have a acer 4520, the DC jack was broken and was run on the battery til it was dead. The woman didn't have a critical need for it because she got a Mac Book. She gave it to me to repair, but I never got around to it and she never asked about it.
    You see where this is going don't you?
    1 year later, the mac book died, and no money to give to those con artist at the mac store to fix it. I figured I do the nice thing and repair the acer for cheap. Turn out the jack was expensive to get. 2$ jack 15$ for S+H. I looked around, found some for cheaper but the sites were questionable. I tried to remove the old one but I needed a higher wattage iron because my heat was quickly disperse over the pcb and components and was not melting the solder. I worked on it for awhile then gave up.
    Then I decided to look for the actual assembly and found the whole powerboard for 25$ + 7 for S+H on amazon. I figured by the time I get a hotter iron and pull the jack and place the new one and the uncertainty of heat damage and I might end up buying it anyway, seem cheaper to get the board.
    So I ordered it. Got it today, installed, LAPTOP NOW WALKS AMONG THE LIVING!
    Everything is working....
    except the battery.
    It seems to have a small charge for about 1 minute and then goes dead, then you plug it in and it charges for 1 minute then the light goes out. I don't remember if the light changes to green if it's fully charge or not.
    I figure the battery is good it's just got that memory effect from not being charged for so long.
    Therefore I want to exhaust my options before I order a new battery.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Force charge laptop battery?
    Huh... I use it for 2 days no charge light. I go and take a nap and turn the thing off but plugged in. Woke up to see the charge light is on. I wonder what changed.
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • razenxd
      How can I charge that battery pack?
      by razenxd
      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
      Now, I have noticed a few things.
      The "dead" battery, while connected to charger and NOT Charging will...
      12-05-2024, 06:11 AM
    • guruji
      samsung galaxy book 3 np940xfg battery charge
      by guruji
      hello
      I have a samsung laptop galaxy book 3 np940xfg board is BA41-03013a venus3-14.The laptop turns on when connected with battery but the battery has random charging it charges till 70% and then it starts going in reverse the percentage.removed the board and disconnected the battery and attached the 65watt adapter the boot rom for tbt 3v is absent and the laptop does not power on. another strange issue in both the usb-c ports when you reverse the cable the power indicator light does not glow.they using a common dual port CYPD6228-96bzxi and 2 thunderbolt chips intel JHL8040R.
      my...
      Yesterday, 08:12 AM
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
    • Klevjetack
      Charge a L19D3PDA battery externally from the laptop
      by Klevjetack
      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
      03-05-2024, 07:26 AM
