Poing, chipset cooler gone.
  • pinobot
    • Mar 2006
    • 14
    • Netherlands
    Got another interesting story today to tell my grandchildren in about 40 years or so.
    Opened my case and saw that my chipsetcooler (Asrock P4i45PE) came loose.
    Pics:
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Poing, chipset cooler gone.
    That would be an issue... did you have any general instability?
    Ludicrous gibs!
    • pinobot
      • Mar 2006
      • 14
      • Netherlands
      No, i only wanted to install a cardreader and found it like that.
      It runs fine without the cooler but it only has a Celeron 2400/400MHz, the chipset can handle 800Mhz bus. It's my Windows MCE tower so not not much is going on apart for the mp3/tv.
      • tiresias
        • Feb 2006
        • 489
        Are you absolutely certain that it didn't pop off when you moved/opened the case?
        Underclocked or not, I find it unlikely that the MCH chip would draw so little power that it wouldn't heat up out of control in minutes, particularly considering you have an exposed core there with not even a metal heatspreader or plastic package around it.
        • pinobot
          • Mar 2006
          • 14
          • Netherlands
          I opened the case and gently pulled it back, i wasn't planning on taking out any plugs, it was then when i saw it was loose. It can be that when i put the computer there it made a small bump (it fairly heavy) but the chipset cooler is very lightweight so stores very little potential energy.
          It's been running for 12 hours now without a glitch, been playing mp3's, watching/recording tv and dumped a few gigs of mp3's from the other computer to the Media Center. The computer is on 24/7 and acts as a internet gateway for my other computer.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            You know, it would only take about a minute or less to resolder those anchors back onto to the board. I've seen a lot of those over the last couple years. When the anchor has been lost, thats when it gets fun, and you have to find somehting to improvise a replacement.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • Fatal0E
              • Jan 2004
              • 252
              I use the Arctic Silver epoxy stuff, holds them in place forever.
              • arneson
                • Sep 2005
                • 1267
                My machine, Gareway Profile, did the same thing and ran for a while.
                Result was no boot and all major caps bulging.
                I reseated those clips and recapped board, been good for about a year now.
                Wish I'd thought of glueing on...
                Jim
                • pinobot
                  • Mar 2006
                  • 14
                  • Netherlands
                  Bougth Zalman Adhesive today. This stuf came with no manual but in an on-line manual of a Zalman cooler i found that you have to put compound A on the chip and compound B on the cooler and put those two together and push, weird. Anyhow it's glued on now.
                  • MD Willington
                    • Sep 2004
                    • 702
                    Bubble gum PCM... goodstuff... lol
                    At least it isn't the good old PCChips/ECS "double sticky tape" method...
                    Replaced that "Orange blob" with this:
                    Ya'll think us folk from the country's real funny-like, dontcha?
                    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                    • tiresias
                      • Feb 2006
                      • 489
                      That's the really smelly one, isn't it? The one with the green "A" part and the pink "B" part (I do find that the strong distinctive smell can be useful though, since you know that when the "vaag geurtje" disappears, the epoxy is truly dry)
                      I just usually treat it like any other epoxy, so just place a small amount of both A and B on some non-permeable surface and mix them together thoroughly with a matchstick.
                      MD Willington: Heh - that's a socket 370 stock cooler on the SIS735, right? Should do the job all right, but isn't it a little overkill to use the fan as well?
                      • MD Willington
                        • Sep 2004
                        • 702
                        The fan was from a K6 II... worked okay.
                        • pinobot
                          • Mar 2006
                          • 14
                          • Netherlands
                          Yes it really smells, but it's also dry in the claimed 15 minutes.
                          You get a lot of the stuff, i've been franticly looking for other items to glue coolers on.
                          • DynaxSC
                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                            by DynaxSC
                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                            06-10-2023, 11:30 AM
                          • gabrieljma1
                            Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                            by gabrieljma1
                            I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                            The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                            I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                            Yesterday, 03:32 PM
                          • Exim
                            ASRock N100M, no picture no boot, but semi-alive
                            by Exim
                            Hi guys,
                            I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                            ASRock N100M special features:
                            - CPU soldered to board, small Intel 12th gen
                            - iGPU
                            - four POST LEDs
                            Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                            I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                            Symptoms:
                            - no picture/signal on any of the display connectors,...
                            04-01-2025, 02:36 PM
                          • MasterCap
                            What IC does AsRock usually use to make the PWM signals for GPU fans ?
                            by MasterCap
                            I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
                            Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
                            But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
                            12-28-2024, 08:42 AM
                          • BleedCap
                            OLD Socket 478 custom bracket + NEW generic cooler
                            by BleedCap
                            I already posted this on vogons.
                            Its a 3d printed custom bracket for socket 478.
                            I used this AM4 bracket as a base design.
                            Its to be use with cheap generic clip based cpu cooler.
                            Reason for doing this is:
                            - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                            - New generic cooler is cheaper and can use bigger fan (less noise)
                            I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                            The processor that I was using is P4 2.4Ghz prescott....
                            11-05-2023, 08:09 PM
