19v on 18.5v input rail
  • stevo1210
    • Oct 2006
    • 4156
    Ive been getting a batch of various HP and Compaq laptops here for refurbishing. They are usually rated at 18.5v 3.5A or sometimes 4A.
    Now im not in the mood to buy chargers for every laptop that goes through here, would it be okay to use a 19v adjustable universal laptop psu by seasonic to power these units, install OS and do burn in tests? I havent had a problem using 19v on 18.5v laptops, but just wanted to be sure
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: 19v on 18.5v input rail
    Nope, no problem. The difference is insignificant. As long as it supplies the required current (4A) it'll be fine.
    A working TV? How boring!
    • b700029
      Banned
      • Sep 2010
      • 640
      Agreed, a 2.7% higher voltage isn't going to do much.
      Probably all laptops these days have an internal DC-DC converter that takes a pretty wide input voltage range (from battery voltage, which is usually in the 14v range, up to ~20v.) The upper limit isn't going to be the converter itself since that's rated for ~30v, but things like 25v caps in the circuit.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        You're fine.
        A half volt is no problem there as long as the amps are good too.
        A whole volt probably wouldn't be a problem either.
        If you could get your hands on the Engineering docs....
        ... That 19v is probably actually something like 19 +/-1 volts.
        ... That 18.5v is probably actually something like 18.5 +/-1 volts.
        Mann-Made Global Warming.
        - Dr Seuss
        • stevo1210
          • Oct 2006
          • 4156
          Originally posted by PCBONEZ
          You're fine.
          Okay, cool. Looks like I won't need to spend some extra cash on a new power brick designated for 18.5V then :P
          • japlytic
            • Oct 2005
            • 2086
            I got away with 19V on a Compaq Armada with an 18.5V input, and I don't know of any universal notebook adaptors which have a "half volt" option.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              I have one that does. Although, it does go from 16v straight up to 18.5v, and then 19v. Also, since a lot of the laptops coming in ask for 18.5v, i'm too lazy to flip the switch so i run my old Fujitsu on 18.5v too, and that thing is rated for 16v. It hasn't complained yet and it's been more than an year.
              • ugamazing
                820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                by ugamazing
                So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                04-10-2024, 08:06 AM
              • Victor Moreira Silva
                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                by Victor Moreira Silva
                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                Well, my decice specs are the following:
                Model: Acer Nitro 5 AN517-54-55T5
                CPU: Intel Core i5-11400H
                GPU: NVIDIA GeForce GTX 1650
                Motherboard: GH51G LA-L181P Rev:1c
                The symptom:
                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                05-26-2025, 10:49 AM
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
              • lefetylorant
                Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                by lefetylorant
                Hello Everyone,
                Long story short, I got this unit for very cheap.
                I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                I've performed some measurements:
                - 20V rail perfectly...
                09-14-2023, 05:05 AM
              • bimole
                Weird behavior on 3.3V rail of a CORSAIR CX600
                by bimole
                A colleague gave me an apparently ill CORSAIR CX600.
                He told me that he heard a banging noise, and smelt the magic smoke.
                After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                It's another story on the 3.3V rail...
                I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                02-13-2025, 04:49 AM
