Win XP or Win 7 ?
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Win XP or Win 7 ?
    Currently I'am running Win XP 32, with 4GB RAM, Intel i3, 3GHZ.
    I main use the machine for browsing/Word+Excel and run some test machines
    in WMPlayer.
    I have really thought about goint to Win 7 64.
    But do you guys think it will be worth it ?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Win XP or Win 7 ?
    Unless you need it for hardware/software compatibility or the like or already have a legit copy of 7, keep it at xp. for what you are doing, the system is overkill anyway... any performance gain by going x64 won't be really noticeable. Given the cost of win7, its not worth it.
    if you had a copy of 7 already, then I'd go for it.
    sigpic
    (Insert witty quote here)
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      you can if you want, won't make any real difference though.
      I run both.
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        Ok, thank mates!
        I don't have Win 7, it will cost about 100£ (1042 DK KR) here in DK. I also had doubt about the gain, will not spend money on it then.
        • Krankshaft
          • Jan 2007
          • 2328
          Windows XP 64 is very hard to come by and the people who are selling it are charging ridiculous prices. I considered XP 64 when building my current Quad Core rig after seeing the prices I just said screw it and put the money towards Windows 7 Pro.
          Since I game on this thing I figured I'd be set for the inevitable Windows XP phaseout for games since the OS is getting long in the tooth.
          No way was I going to pay close to the same price for an older OS.
          They also include the 32 and 64 bit versions when you buy it unlike XP where they released 64 bit years later then double dipped the end users who wanted 64 bit forcing them to buy XP again instead of letting them use their 32 bit keys on 64.
          Unless you want to surpass the 4GB limit or you have applications that's require RAM over the limit or are 64 bit only it's not worth it.
          • colormebad
            colormebad
            • Dec 2010
            • 114
            Problem with windows xp 64, is that it only came with sp2 only....I have good copy's of 64 ' but it wouldnt install on my asus board...Would always crash' but works perfect on any other system that had xp on it before..
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              x64 never got a SP3, it just got a bunch of updates after that. it was modeled after server 2003, and followed a similar update path. It also never got that retarded genuine advantage notification that you always had to be careful to uncheck on winxp32....
              I run XP x64 on several machines.....no probs, sees the buttload of RAM these machines have, and I have no plans to downgrade to 7..... win8? Forget that!
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • colormebad
                colormebad
                • Dec 2010
                • 114
                XP x64 running ok with 12-16 gigs of ram ok ? I started to install it on another 64bit system but didnt know how well it would work with more ram..And a I7 processor...
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Windows 7 can better utilize multi-core CPUs and a lot of RAM than old XP can...
                  And it's shiny.
                  And performance with 7 surpasses performance on XP in some cases.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Better performance in 7?
                    Unless you have a Hex-core with 8GB of RAM
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      or a core i5 with 6GB RAM
                      • severach
                        • Aug 2007
                        • 1055
                        Windows 7 x86 handles the same amount of RAM as Windows XP x86 unless you have the "RAM Sperre" PAE RAM patch. Without cheating the ability to handle RAM is the same. Windows 7 offers Superfetch which I turn off ASAP.
                        The only core management improvement I've seen in Windows 7 is that it doesn't assign affinity to the HT cores until the real cores are getting full. This allows the non HT cores to clock faster.
                        Anandtech: Intel's Core i7 870 & i5 750, Lynnfield: Harder, Better, Faster Stronger
                        Homework: How Turbo Mode Works
                        Other than that the core handling is too similar to say one is better than another.
                        x64 is a slug. The speed you gain from the disk cache is more than lost in x86 emulation. It will be better someday but we're a long ways off from that.
                        The shiny part is why everyone heaps praise on Windows 7 where it's not due. If it looks good no one cares that it is slower.
                        sig files are for morons
                          Copy DMI info easily with Hex editing software and Macro script
                          by SMDFlea
                          Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                          Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                          02-28-2023, 02:14 PM
                        • Caimano
                          Need to copy DMI info for HP ProBook 650 G2 Bios
                          by Caimano
                          UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
                          Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
                          01-03-2024, 05:19 AM
                        • m0seba
                          how to block copy from network access
                          by m0seba
                          hi
                          there is a small company have 4 computers and server with windows server 2016
                          all computers are entered into the server by local users, and there is shared folders on server with limited access to every computer
                          my question is there any method to disable copping form all shared folders on this server, but jest disable copy form server not paste on it.
                          my client want his team copy from their computers and paste on any shared folders on server, on the other way can not copy anything from shared folders to their computer.
                          or any way to disable copy on windows...
                          03-16-2021, 03:35 PM
                        • Hondaman
                          Windows 11 buying advice needed
                          by Hondaman
                          My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                          She does not want to switch to Linux. And she does not want to use a laptop because...
                          04-14-2025, 11:35 PM
                        • madyoyo
                          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                          by madyoyo
                          Hi
                          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                          12-01-2023, 09:28 AM
