Just pulled a record-setting drive
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Western Digital Expert 100BA
    10GB IDE, Manufactured 25 Sep 1999
    According to SMART, 75,944POH (that's 3,164 days, or over 8.66 years of power-on time). Of course, also according to SMART, it has 7 reallocated and 14 pending sectors. Machine wouldn't boot any more and I couldn't Ghost it either. I was, however, able to hook it up as a slave and pull all the important files off.
    It was pulled from the system it was originally installed in, a Compaq Deskpro with a PIII 500mhz. Up until last week, it was used in our QA lab during all 3 shifts, 6 days a week.
    Ludicrous gibs!
  • mariushm
    • May 2011
    • 3799
    Re: Just pulled a record-setting drive
    The shared hosting company I first used (have moved since to dedicated servers) has servers running since 2002:
    https://www2.suresupport.com/network.php
    SERVER ON SINCE DAYS MINUTES DOWNTIME-MIN. UPTIME STATUS DESCRIPTION
    Machine36 2002-09-09 3432 4942080 0 100.00% OK Operational
    Thehosting123 2002-06-25 3508 5051520 0 100.00% OK Operational
    That's 9+ years...
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      That's quite impressive... but this is a desktop drive, that was installed in a computer that's been used in some of the hottest places in our manufacturing facility. The case of the computer itself is sticky with grease and oil buildup... Bit different than what you would hope is a climate-controlled datacenter. Not to mention all the supporting hardware is enterprise class.
      However, this drive might've been quite advanced for 1999, since it's actually a 7200 RPM drive.
      Ludicrous gibs!
      • RJARRRPCGP
        • Jul 2004
        • 6304
        IIRC, the "Expert" is a DeskStar with a Western Digital badge slapped on it!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Retire that one with honors!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • toastygoodness
            • Jul 2005
            • 813
            also machine uptime =/= hard disk uptime. we have hundreds of machines with 24/7 uptime of almost ten years now, but disks have always been failing. that's why there's raid and hot-swap. as long as less than two disks fail at a time, the system can keep running while the disks are replaced. but realistically, the mean hard disk time in a datacenter is near 4 years (since they're usually forced to be tossed by then).
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              She deserves it... the spindle bearings are just about seized, I think. Whines like a mofo!
              Another good point!
              Ludicrous gibs!
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Hungary-made DeskStars are known to whine like a mofo.
                And that's even when not used a whole lot.
                And the "Hungary" ones appear to be inferior to the "Philippines" ones.
                (Because the SMART of a "Hungary" tends to report trouble with the "Spin Up Retry" attribute.)
                Arc A770 16 GB
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  This old WD100 was made in Malaysia
                  Ludicrous gibs!
                  • Toasty
                    • Jul 2007
                    • 4171
                    Remember when we thought going from a 10 MB drive to a 20 MB was the cat's meow?
                    veritas odium parit
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Typical with most Western Digitals of that gen. Have you seen one of those where Western Digital slapped its name on a DeskStar?
                      Arc A770 16 GB
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Not me... my first computer had a 540mb seagate drive in it. I did run across a 30 mb drive in a Tandy 3000 later on, though. One of the big double height, 5.25" drives that took about a minute to get up to operational speed
                        Not that I know of, but this could be one?
                        Ludicrous gibs!
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          My Windows 2003 server drives have been running 24/7 since 2003 two Seagate Barracudas SATA 150GB mirrored for redundancy they're about eight.
                          They're in a cool basement, rarely powered down, and in a well ventilated case so that probably plays a factor.
                          I wish they made drives as good as these just got a replacement WD 1TB in the mail. I seem to average at least 2-3 drives a year with all of my PCs. These newer drives drop like flies.
                          I wish solid state storage would get out of its infancy already.
                          I still have an 8088 with a double height 10MB drive. Man those things are bulky they've got a stepper motor to move the heads too. It's not a hard drive its a bigger floppy drive . Truly a coarse piece of machinery by today's standards.
                          I use the top platter cover of a double height MFM that crashed for storage to hold screws and stuff I can store a lot in it .
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            blue? black? green? RE?
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              It was a Green I bought it under duress in 08 since the store was out of Blues. The Greens are slightly slower but this is a P4 3.2 rig I figured it wasn't worth the trouble driving to another store to find a Blue.
                              The comp was randomly BSODing on boot up WDs drive diagnostic tool confirmed it was circling the drain so I backed up the data.
                              This is my first and last Green. 7200RPM Blues or Blacks only.
                              • Scenic
                                o.O
                                • Sep 2007
                                • 2642
                                ^ if you still have it, check the smart value for "load cycle count". I bet it's far beyond 200k
                                Regular greens park their heads after 3-5secs of inactivity, which ultimately kills the drives (out of head alignment).
                                No other WD series (blue, black, RE, AV, AV-GP) has this timer. Only the regular greens.
                                The head parking timer is fine for a storage/backup drive, but a lot of people use it as a system drive, which is about the worst thing you can do with one of those and gives them a bad reputation.. a bad reputation because the owner used it for something it was never designed for.. *facepalm*
                                My AV-GP (a 1TB WD10EVDS .. "AV Green" version of the WD10EADS) only has 706 load cycle counts after about 2 years of use (power on hours).
                                If it has to be a Green WD, it's AV-GP series or nothing.
                                • Krankshaft
                                  • Jan 2007
                                  • 2328
                                  I had to send the drive out first so I don't have it anymore. Should have checked it I'm curious now.
                                  I'll definitely take a closer look at the drive I'm buying next time. I figured the low power consumption was only the result of a lower RPM spindle motor not also a stupid head parking timer.
                                  No need for a specific model drive I found this command line app from WD:
                                  http://forums.whirlpool.net.au/archive/1367904
                                  With it you can disable the idle timer to prevent parking or increase the time till the heads park in the firmware.
                                  I disabled it on mine. To do that type wdidle3 /d
                                  If you type wdidle3 /r it will report the idle time in seconds. Use /s to change the value.
                                  For example wdidle3 /s9.00 (no spaces) would change it to 9 seconds. Over 12.6 seconds enter the raw value in seconds the max is 300 seconds (5 minutes). Above 12.6 for example wdidle3 /s30 for 30 seconds.
                                  Type wididle3 /? to display the program command line parameters. My first PC had Windows 3.1 so I'm right at home with Dos .
                                  I'm not getting caught with my pants down again I don't need WDs intellicrash .
                                  Unfortunately it only works under Dos here is an ISO boot CD the file already has been bundled so you can run it straight off the CD through Freedos.
                                  • Shocker
                                    Banned
                                    • Dec 2011
                                    • 635
                                    WOW!!!!!!!! Remember when PCBONEZ said to perpendicular recording??? Thank god I still have my old ST380011A...
                                    • larrymoencurly
                                      • Oct 2004
                                      • 960
                                      Were those the WD Expert drives? I vaguely remember their motor connections being 90 degrees from the location IBM used.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Which time?
                                        I've been saying that for years and the same people that lined up to tell I was full of crap come in here with drive problems a year or two later...
                                        PRM pushes the mechanical [and electrical at the disc surface] limits of a drive.
                                        If you're going to push the limits of the technology then you'd best be buying the high end high quality [precision built] 'Enterprise Class' parts or you are virtually guaranteed to have more problems.
                                        - It's really a no brainer...
                                        With PRM there is less area/mass to store the charge in and less distance to neighboring charges so charges are going to be less stable with time.
                                        The 'target' the head has to 'hit' is much smaller so not only is a 'miss' more likely, the head has less time to store the charge as it flys by the target.
                                        Mann-Made Global Warming.
                                        - Dr Seuss
