Really really weird!!!
+ More Options
Posts
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    First, a little story:
    OK so I plugged my Minecraft server in (it's been unplugged for a few days), and turned it on...
    The Foxconn splash screen, then: DISK BOOT ERROR ENTER SYSTEM DISK AND PRESS ENTER
    I was worried that my HDD was bad, but then I remembered that I had removed the two extra 250GB Seagate ES disks in there... Turns out I had unplugged the power from the IDE drive that's the boot drive and never plugged the power plug back in...
    So I fixed it, and tried to turn it on again.
    Shit!
    Went into the BIOS, did Restore Optimized Defaults, saved, tried again. Same thing.
    So I went back into the BIOS and went to boot settings thingy, and found that IDE0 master was the CD drive and IDE1 was a "Laxtnr 91GB"...WTF???
    I have a MAXTOR 100GB!!!
    So I closed BIOS, and let it sit and the DISK BOOT ERROR screen for a few minutes. Then I restarted, and this is the first time I've been happy to see Windows say that a boot file was corrupt and fail to start up. Why? Because that meant my hard drive wasn't a total goner! I rebooted and this time... SUCCESS!!!!!! Windows Server 2003...
    Great, I logged in, got to the desktop, and proceeded to plug my iomega 320GB USB hard drive (internally a Samsung drive) into the USB port.
    It didn't show up. WTF?
    so... it shows up in Computer Management>Disk Management but it has no drive letter assigned. Strange.
    Ejected it and tried it in another computer, it popped up fine!
    Dug out my 8GB SanDisk USB flash drive, plugged it in (it worked and showed up as E: and I copied my Miencraft files to it.
    Now I have backups.
    Now, the Question:
    WHAT THE HECK IS A LAXTNR 91GB DOING IN MY COMPUTER??? surely my Maxtor didn't take any laxatives?
    Seriously, what the heck happened?
    I'm going to try to restart this thing now and see what happens...
    Update:
    Upon shut down a cold boot it shows up in BIOS as a Maxtor 100GB like it's supposed to... and it boots up fine...
    OMG how weird
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Really really weird!!!
    Check your drive cable.
    'M' = 4d = 01001101
    'L' = 4c = 01001100
    'O' = 4f = 01001111
    'N' = 4e = 01001110
    Data line 0 is not working.
    http://pinouts.ws/ata-ide-pinout.html
    Check pin 17 of the cable for continuity.
    Edit: might be data line 8, it's 16 bits wide (2 bytes at a time) and I don't remember the order. Check pin 4 too.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      How the heck am I going to get my multimeter probes in there?
      A paperclip didn't work; I'm going to ask my mom for a needle
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Update: with the help of 2 sewing needles, I have come to the conclusion that pins 4, 17, and a few other random ones, check good for continuity (my multimeter beeps)
        • severach
          • Aug 2007
          • 1055
          All the leads you cut from capacitors and threw away... those fit in really well.
          sig files are for morons
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            You have a failing drive. Corruption of the text displayed in the BIOS is common when the drive is on its last legs. Given that it's a Maxtor, i'd just throw it away.
            A working TV? How boring!
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I set up my MC server so that every time a player goes on it asks them to donate money for a new case & HDD (the two things the server needs)... when I have those I'll be good to go
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                More likely you jostled the cable and made a bad connection when you were in there screwing around.
                Unplug the data cable on both ends that then put it back in...
                ... or try a different cable.
                Mann-Made Global Warming.
                - Dr Seuss
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  image it now.
                  thats the type of symptom reported before these eat their firmware.
                  i can rewrite it but is not even worth the postage both ways to save it.and i repair just to recover data.the bearings get worn and oops a miswrite.got one here to recover from an anliam 3300mk.
                  its got the hdd death scream from hell!
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    I hate Maxtor
                    I put in a new cable so it's working fine (even though it seemed fine with the old cable after I got it to boot. The tricky part was to get it to boot)...
                    I'll wait for somebody on the server to donate a hard drive or some $$ for one... as it's running OK right now...
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Originally posted by shovenose
                      "Laxtnr 91GB"
                      Wow, definitely looks like a bad IDE cable!
                      And unless it's a Maxtor whose model code is "6Exxxxx", they're good!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        http://www.youtube.com/watch?v=2-Bwks3u5C0&t=0m5s
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Yup.
                          Bad connection at a pin or one of the wires inside the ribbon broke when you flexed the cable moving it around.
                          #1 suspect when you've just worked inside the case and a drive starts screwing up.
                          Either test or get rid of that cable so if it's bad it doesn't find it's way back into something.
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Originally posted by Uranium-235
                            Yeah, that was along the lines of: "If it ain't broke don't fix it.".
                            - Dr Seuss
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Yup.
                              The cable tested good but I'm going to get rid of it anyway.
                              • dood
                                Deputy dood
                                • Mar 2004
                                • 2462
                                The cable tested for continuity... it did NOT test good...
                                Ludicrous gibs!
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  What do you mean lol?
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    well, you tested form point A to point B.
                                    that is only half of it.
                                    what you didn't test was continuity to nearby wires. if it is shorted to another wire, then that could be an issue
                                    on that note, also make sure that there is low resistance where it should be connected... the controllers can be picky about signal strength...
                                    sigpic
                                    (Insert witty quote here)
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      Or, just chuck the questionable cable... I haven't had to buy one in years, and I still have a plentiful supply of them
                                      Ludicrous gibs!
                                      • DynaxSC
                                        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                        by DynaxSC
                                        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                        The behaviour is also really very strange, i.e.:
                                        • The disk shows always up in BIOS - so it is recognized, so far so good
                                        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                        02-23-2025, 01:33 PM
                                      • lukkihapsi
                                        Asus Vivobook X515JA Weird Boot Issue
                                        by lukkihapsi
                                        Asus Vivobook X515JA Laptop
                                        Issue :
                                        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                        Tried :
                                        Cleaned inside for dust, applied fresh thermal paste. No Change!
                                        Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                        Removed Internal SSD. No Change!
                                        Updated BIOS to latest version. No Change!
                                        Removed battery and pressing power button for 1 minute. No Change!
                                        Weird Part :
                                        Upon turning laptop ON, screen lights up - stays black,
                                        I...
                                        07-07-2025, 12:07 PM
                                      • privato89
                                        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                        by privato89
                                        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                        Let's begin:
                                        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                        03-26-2024, 06:37 AM
                                      • PainThonNen
                                        Dell E5440 no boot and disk led blinking
                                        by PainThonNen
                                        Hello guys how are you?
                                        I'm facing a Dell E5440 who don't to boot. When I push the power button, the power shows up for some seconds and goes down. After that, wireless and battery led show up (solid white) and the disk led start flashing. No short to ground detected, Tried to flash both U1 et U2 but nothing.
                                        Thank you for any help
                                        11-27-2023, 07:03 PM
                                      • hinisa
                                        Xiaomi router freezes at boot after re-capping
                                        by hinisa
                                        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                        07-08-2023, 05:58 AM
