What I learned about BIOS Flashing
  • bigbeark
    • Jan 2010
    • 661
    To the tune of "I flashed the BIOS, but i did not screw the Motherboard"
    (apology to B. Marley/E. Clapton)
    I have been on a flashing jag, upgrading several old motherboards using
    a floppy drive and diskette containing DOS boot disk, flashing tool and updated BIOS.
    I was wary of hot flashing, so I checked out flashrom, the Linux tool.
    I installed it on this machine from Synaptic. It lets you use a 3com ethernet card in a PCI slot, as a programmer. Unfortunately, the 3com card only works with 128kb bios size, not too useful as modernish bioses run from 256kb .
    I learned the chips I am working on are DIP32. I find there is a ZIF socket you can use which means you can easily do a hot flash without prying out the chip to be flashed on a running mobo.
    There is also a DIP32 to PLCC32 adapter that you could mount in the ZIF DIP32 socket, so you could theoretically flash later model BIOS chips using an old motherboard.
    See the attached pic of the 3com card and ZIF socket.
    http://flashrom.org/File:3com_prog.jpg
    So I ordered a pair of the ZIF sockets for future hot flashing adventures
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: What I learned about BIOS Flashing
    Depending on what you regard as old motherboards ....
    ... I found some old Gigabyte boards to be significantly slower with their final BIOS
    One I particularly remember was a GA-686DLX which corrupted when I tried to reflash the second-last BIOS after it was updated to the final BIOS
    Seeing that board uses a DIP40 Intel 2megabit BIOS chip, it was quite a challenge to recover
    But with the second-last BIOS it runs a pair of Celeron 466 with acceptable performance for XP, whereas the same hardware with the final BIOS took a couple of hours just to do an XP install
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • bigbeark
      • Jan 2010
      • 661
      So pfrcom, are you running those 466 celerons in Slockets? If so, which ones?
      I tried dual slockets in my GA-6BXDS and it FRIED my 370-DL slocket, although the board was undamaged.
      I had set the slockets to 1.8v in hope of using dual coppermine 750s
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Yes they are in Slockets
        IIRC one is an early revision MS-6905, and the other is a Brand X, possibly PC Chips
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          slokets eh?
          I have a bunch of those... in a van full of free computer crap, i guess i found 4 NOS slockets... 3 MSI, one ASUS.
          they also had multiplier jumpers...
          yay free stuff? (they still are in the boxes, LOL)
          sigpic
          (Insert witty quote here)
          • bigbeark
            • Jan 2010
            • 661
            Ratdude, what model is the ASUS Slocket? If it's 370-DL I might be interested.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              not sure... it was in a red box.
              next time i am at my old house, I'll take a look.
              sigpic
              • dumpystig
                • Jul 2011
                • 485
                Slocket...
                System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Originally posted by dumpystig
                  Slocket...
                  it lets you use socket 370 CPUs in slot 1 mainboards. essentially a slot 1 cartridge with a 370 socket in place of a CPU die.
                  rare ones exist that have socket 8 in place of socket 370
                  http://en.wikipedia.org/wiki/Slocket
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    the asus is a s370-133
                    the msi cards are MS-6905
                    all the cards (both asus and msi) support coppermine and lower cores. both have adjustable vcore jumpers, from 1.5v to 2.6v (asus) or 1.5V to 2.0V (MSI), in increments of 0.05v.
                    if interested, PM me, as my only use is if I ever dug out my EATX dual slot 1 cumine board (AMI megadual) and if that, I would only need 2 slockets (unless I used slot 1 cpus, like the 733s I used to use in it).
                    sigpic
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      The 6905s are moddable to run Tualatin too.
                      A working TV? How boring!
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        and i have 3 of them...
                        and I have a dualie board
                        but all i have for tualies is a 1200 and a 1300, both celerons
                        and the board is an eatx monster (and I no longer have a case that fits)
                        (the board is an AMI megadual if you wanted to know).
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          TSee the attached pic of the 3com card and ZIF socket.
                          Where did you get those ZIF sockets?
                          <--- Badcaps.net Founder
                          Badcaps.net Services:
                          Motherboard Repair Services
                          http://folding.stanford.edu/
                          Team : 49813
                          Join in!!
                          Team Stats
                          • bigbeark
                            • Jan 2010
                            • 661
                            Topcat:
                            http://www.ebay.com/itm/180729475520...84.m1439.l2649
                            I'll let you know how well they work when they arrive..
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              Apparently they're out of them...but I found some more that had them. These will be interesting to try in some car ECU's for quick eprom changes.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Timeeez
                                X270 - Bios flashing help
                                by Timeeez
                                I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
                                Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
                                11-30-2022, 05:17 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
                              • Flyview
                                Flashing ASUS UX51VZ with correct bios
                                by Flyview
                                Hi!
                                Happy to be part of this forum for my first post!
                                Short story:
                                I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
                                1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
                                03-31-2024, 11:56 PM
                              • Bloodhoundje
                                by Bloodhoundje
                                03-16-2024, 03:12 PM
