Which Power Supply Is Best ????
  • colormebad
    colormebad
    • Dec 2010
    • 114
    Their is a big differance in price here ' but wondered which is realy the best...Or would they be close to the same....The 1080 is dirt cheap compaired to the other 1....thanks
    http://www.newegg.com/Product/Produc...82E16817182188
    http://www.geeks.com/details.asp?inv...-G1080&cat=PWR
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Which Power Supply Is Best ????
    the first. the second is gutless junk.
    95% of the PSUs from geeks.com are trash... it's like they have a contract with hongkongflyapart, LLC
    sigpic
    (Insert witty quote here)
    • c_hegge
      • Sep 2009
      • 5219
      http://www.newegg.com/Product/Produc...82E16817207011
      I'd go with that one. It's a similar price to the others, is made by Seasonic and has Japanese capacitors. 1KW is overkill for any PC (unless you want 3 GTX295s in SLI or something like that)
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        The coolpower is a leadman built unit. Stay far away from it.
        The rosewill is a good performing superflower unit. It's quite a bit of psu for $130. The XFX is a bit cheaper, probably a slightly better performer, but 150W less.
        It would depend on how much power you need. If you truley need a 1000W psu, the rosewill will do fine, otherwise I would go with the XFX.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i think i found the 5% of geeks.com power supplies that are not trash...
          http://www.geeks.com/details.asp?inv...S-NLB9&cat=PWR
          seasonic made?
          sigpic
          • mariushm
            • May 2011
            • 3799
            The XFX core one looks good.
            This one is also very good for the money:
            http://www.newegg.com/Product/Produc...82E16817139012
            http://www.amazon.com/Corsair-Profes...0&sr=8-2-spell
            I have this one and it's excellent:
            http://www.newegg.com/Product/Produc...82E16817151088
            Don't go for high wattage - it doesn't mean everything. THe quality of the insides matters a lot too.
            • c_hegge
              • Sep 2009
              • 5219
              Any of those two would also be good, although I think that the XFX 850W one I suggested offers the best value for money. It's a seasonic built unit, but its a bit cheaper than the Seasonic branded 650W.
              It looks like a sirfa/sirtec/high power from the top, although both superflower and sirtec are good manufacturers
              • Scenic
                o.O
                • Sep 2007
                • 2642
                guesstimating what PSU is best is kinda pointless if you don't know what system it's going to be used in IMHO.
                What if it turns out he wants a 1kW PSU for a quadcore with a single graphics card or something..?
                No matter which one you chose, they'd all be total overkill and sub-optimal (bored to death) for a system like that.
                • colormebad
                  colormebad
                  • Dec 2010
                  • 114
                  I dont care about all the lights' but like the specs on this one....Just wish it was on sale...
                  I will post my m-board & CPU here in a few....I bought a bare bone kit to start with...Just traded for a Antec nine hundred tower...
                  http://www.newegg.com/Product/Produc...82E16817182239
                  Here is the PS thatcame with the kit....
                  http://www.newegg.com/Product/Produc...82E16817182200
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    https://www.badcaps.net/forum/showthread.php?t=15305
                    Impressive for a Leadman, but that's not saying much
                    • colormebad
                      colormebad
                      • Dec 2010
                      • 114
                      Here is whats going inside below...Maby it will give a better clue what size ps to go with...Im not a gammer' just do alot of downloading/movies/burning software & stuff/ while surfing at the same time..Just alot of multi tasking off and on' not all the time....
                      Asus Motherboard Link
                      http://www.asus.com/Motherboards/Int...155/P8Z68V_LE/
                      Memory Link 16 Gigs
                      http://www.newegg.com/Product/Produc...82E16820233170
                      Intel Processor Link
                      http://www.newegg.com/Product/Produc...82E16819115070
                      PS that came with kit
                      Ps: I have read where most are going with single rail over multi rail...Some says not any differance...
                      • mariushm
                        • May 2011
                        • 3799
                        The power supply you received in the kit is good enough for your needs, no need to pick another one.
                        Your system doesn't use more than 200-300 watts of power... for reference here's each part:
                        50-60 watts the processor - up to 100-120w when encoding videos, playing games
                        20-40 watts motherboard components
                        4-8 watts per memory module
                        12 watts for each hard drive
                        Single rail vs Multi rail makes absolutely no difference in terms of quality of power sent to the system.
                        Multiple rails on a low wattage power supply can sometimes hamper overclocking - for example a 550-600w power supply may advertise 4 rails with 18 amps each but that value is peak power - continuously each rail can do only 10-12 amps. If the power supply is badly designed and uses one rail for the cpu connector and one of the video card's extra power connectors then when you're overclocking, that rail could be overloaded and the power supply will shut down itself.
                        It may be preferred to have multi rail when going with a 1000w+ power supply because if there's some short circuit in the case, you basically have a welding machine - the power supply may not stop itself until the short cables burn up. But this almost never happens.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3113
                          Not many psu's rate their multiple rails at peak values. Most are set at continuous ratings, peak is usually 5-8A higher. Some antecs set the OCP 15A or higher above what they rate the rails at (such as the HCP-1200, some have pulled up to 1800W from it well in spec without tripping the OCP)
                          You are right on lower wattage units, but again, a 500W may have 2 20A rails, which typically may have OCP trip points at 25A each, but combined can only put out 36A. They do this as to not "trap" as much power.
                          • colormebad
                            colormebad
                            • Dec 2010
                            • 114
                            This would be the bigger & better one if i ever upgraded you have listed...I will run the one i have and if i see this one drop even lower ' grab it for a backup....thanks
                            • colormebad
                              colormebad
                              • Dec 2010
                              • 114
                              How much differance if any ' does it make where it list the power as Maximum Power Or continuous power on PS's
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                maximum is like peak power. doesn't mean crap. this term has no established standard or meaning... sure, a 250W unit could do 500w for a few milliseconds before gong boom... therefore, some brands would call that the peak power.
                                continuous means more... assuming the company is being honest. (cheap brands like to slap high numbers on lower units).
                                like people have said, read the reviews before you buy... good ones will do a load test with an oscilliscope to measure ripple...
                                sigpic
                                • colormebad
                                  colormebad
                                  • Dec 2010
                                  • 114
                                  Thanks for the info...Thought that was right but wanted to make sure...
                                  You know anything about the supply here at newegg...I have a code to get $30 off that price....
                                  http://www.newegg.com/Product/Produc...82E16817121090
                                  • mariushm
                                    • May 2011
                                    • 3799
                                    It's an OK power supply using a new design that's almost identical with the one in Superflower's Golder Green series of power supplies.
                                    You can compare that 1000w psu with this 800w psu: http://www.jonnyguru.com/modules.php...Story&reid=229
                                    So yeah, if you get that for 100-110$, it's worth the price.
                                    But as I said above, you DON'T NEED another psu with that system you have - you're barely reaching 300 watts now.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      That Kingwin is a very good unit made by SuperFlower.
                                      • colormebad
                                        colormebad
                                        • Dec 2010
                                        • 114
                                        Check out the rating on this badboy....wish it was half the price with a 30% discount on top,,,LoL
                                        http://www.jonnyguru.com/modules.php...Story&reid=264
