Do 1999 brand-new-nerver-used quality caps get old?
  • Calchaqui
    • Oct 2005
    • 112
    Greetings from Argentina, I have 5 BRAND NEW never used Asus p2b-f mobos, they have Sanyo 1500uf quality caps. I needed quality caps and de-capped 2 mobos, but ive found that most of the caps behave weird, few capacitance, short circuited.
    Would Have been being the motionless electrolytic fluid for 11 years ruined the caps?
    Have anyone had any similar experience?
    I LOVE WWW.BADCAPS.NET
  • NxB
    • Feb 2009
    • 1595
    Re: Do 1999 brand-new-nerver-used quality caps get old?
    Strange. Did you measure ESR? Maybe somehow they dried out because of conditions or desoldering. I just pulled a bunch of SHIIIIITTTYY luxon 1000uf/10v caps that still have low esr and not shorted. Board was socket 7.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      thats very odd, I have similar old caps in an old psu and on a few old mobos... I have a dual pIII AMI EATX board that has old sanyo caps on it... works fine.
      sigpic
      (Insert witty quote here)
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        yeah but was it used rat? I think lytic chemical will dry out if its not used
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i would have thought the opposite, due to heat and whatnot.
          sigpic
          • brethin
            • Dec 2008
            • 1907
            Maybe they need reforming if they have never been used and sat for that long.
            • brethin
              • Dec 2008
              • 1907
              I would have just bought new caps and sold the boards (if they are new in the box) to cover it.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                probably ok.reform on power up at the worst.
                higher voltage caps like i use in plate supply for big amplifiers i reform.
                i have bought nos boards older than that and simply fired them up without issues.crapcaps got replaced after i made sure it ran.
                • Calchaqui
                  • Oct 2005
                  • 112
                  I think that is what happened. Those mobos were never powered on. Right now some of them are beginning to work o.k, after put some voltage on them for about 1 hour, i'm getting 1500uf and fast charge discharge rate with my capscheck
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                    by momaka
                    03-15-2023, 10:17 PM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • link626
                    damn. I'm disappointed these high quality caps made my power supply worse
                    by link626
                    I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
                    But today it caused my tv to have a flickering spasm again.
                    what a letdown.
                    I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
                    Sometimes these high quality caps just don't make things better.
                    09-01-2021, 11:02 AM
