Itching to put together another computer..opinions?
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Ok....I'm getting bored again. Besides...Mom and Dad need a newer PC so I'm giving them my single P3 box.
    So...to that end, I just did a quick throw together. I want something that is good at crunching numbers....whether they be huge spreadsheets, F@H, SETI@home, large audio/video rendering, or whatever else. It should be good for games too.
    Is this too much or not enough??? Any problems that I don't know of with any of this???? Comments needed....
    SONY 16X DVD±R, 5X DVD-RAM Write DVD Burner With Black front panel Beige E-IDE/ATAPI Model DRU820A - Retail
    Model #: DRU820A
    $71.99
    Antec LifeStyle SONATA II Piano Black Steel ATX Mid Tower Computer Case 450Watt SmartPower 2.0 ATX 12V V2.0 for AMD & Intel systems Power Supply - Retail
    Model #: SONATA II
    $99.99
    Western Digital Caviar SE WD800JD 80GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
    Model #: WD800JD
    $102.00 (for two)
    ATI 100-435705 Radeon X1800XT 512MB GDDR3 PCI Express x16 Video Card - Retail
    Model #: 100-435705
    $389.00
    CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Unbuffered Dual Channel Kit System Memory Model TWIN2X2048-6400 - Retail
    Model #: TWIN2X2048-6400
    $272.00
    ABIT AW8-MAX Socket T (LGA 775) Intel 955X ATX Intel Motherboard with Onboard 1394b - Retail
    Model #: AW8-MAX
    $204.99
    Intel Pentium D 920 Presler 800MHz FSB LGA 775 Dual Core Processor Model BX80553920 - Retail
    Model #: BX80553920
    $252.00
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Itching to put together another computer..opinions?
    Yea, buy a LG GSA-4167B DVD drive instead and spend the savings on beer
    Either that or buy a "real" DVD drive like one of Plextors... And don't forget the floppy drive :P
    Also I'd buy a Raptor HDD instead, the speed difference is really tremendous, atleast for the kind of usage I give my computer...
    I'm also a little out of the loop regarding the Intel vs AMD battle nowdays but a while ago atleast AMD gave you more bang for the buck so to say... And looking at the reviews at Anandtech the P4 is still struggling to keepup...
    • stretch0069
      • Oct 2003
      • 2658
      yeah...I know AMD is cheaper, but I've still got this old heartburn over their cooling requirements. Not sure if it still holds true, but back in the P3 days, the equivilant AMD would fry if it lost CPU cooling. The Intel would just shutdown with no damage to the CPU.
      I agree on the Plextor issue. The money saved would be small and besides....I don't need any more beer. I'm already paying for past contributions to the delinquency of my belly
      I'll look into the Raptor HDs. I might move the video editing to the new machine and it requires fast HDs to keep up with the digital video capture.
      • tiresias
        • Feb 2006
        • 489
        Hi Stretch,
        Following up on what Per mentioned regarding the choice of hard disks - I've found it depends tremendously on what you're mostly using the machine for. The WD Raptor is certainly very fast as an OS/boot/applications drive, its very low access time being the key here. On the other hand, if you're going to be doing anything involving long sequential reads of huge files (as would be the case with video encoding/manipulation), the I've found nothing beats a striping array - indeed my main machine has two WD1600SD drives set up in RAID 0 for this purpose.
        As for the CPU, if you're not in too much of a hurry, consider waiting for a decent Core Duo supporting motherboard to become available. Those Yonah CPUs are turning out to be very good performers, and astoundingly energy efficient.
        PS. If you're really looking for trouble , you could wait until either the Supermicro X6DLP-EG2 or Tyan i7520SD hit the 'retail shelves', and marry them to two Xeon LV Sossamans, for an affordable, extremely low-power-consuming, quad-core system!
        OK, I confess, that's what I'm secretly planning to use for my next (long-awaited) computer 'build'.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          AMD included a thermal sensor chip in the Barton revision of the Athlon XP, since then all AMD has supported overheat protection...
          If you compare one AMD CPU to one Intel CPU that have equal performance the AMD CPU will need less cooling because it both dissipates less heat and draws less current than the Intel equalient
          As tiresias hinted this will probably change with Intels "Core Duo" chips... But AMD will probably not sit by and watch as Intel dethrones them as the best performance per watt chip, leaving the customer with even better chips in the end...
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            imho you should wait for conroe in Q3. conroe will kick presler's ass.
            http://www.anandtech.com/tradeshows/showdoc.aspx?i=2713
            http://www.hexus.net/content/item.php?item=4843&page=1
            http://www.bit-tech.net/hardware/200...tecture/1.html
            i have not been happy with sony drives but dont have experience with their high end ones, will you be using DVD-RAM? that will limit your choices if you need that. the LG is a good drive, i have it at home. be careful if you want a plextor, some models were not "real" plextor's they were rebadged. i have been doing a lot of backups with my plextor 716 in the office, it seems a good drive also but expensive.
            the hard disks are small though. i agree with the raptor choice but i would get an additional big drive also.
            you will get an antec case and antec psu for your best system? imho it would be better to get a lian li or Akasa Eclipse 62 without psu and add a seasonic, pc power and cooling or whatever. it will add a lot to the cost though.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Sorry for hijacking the thread a little, but is Antec ragarded as being very high quality, in the likes of Seasonic and Fotron etc, but just with badcaps? I.e. is it when recapped just as good as the other PSUs in it's pricerange?
              • tiresias
                • Feb 2006
                • 489
                Experiences vary, of course - but in general Antec-branded PSUs, which are almost invariably made by Channel Well, are no worse than other equivalently-priced consumer-oriented units, such as those made by FSP or Enermax.
                PS. There is, however, a worrying thread on this very forum regarding Antec PSUs "Post your bad experiences with...". Whether this means that reliability-wise, the CWT PSUs fall somewhat short, will be up to you to decide.
                In any case, they're certainly not atrocious quality, like recent Powmaxes or other junk that will reliably fail at 30% of its rated load, often disastrously with regard to any attached components.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Yes I know, I was wondering if this was because they cheaped out on the components like Deer etc or just due to badcaps...?
                  • Galvanized
                    • Mar 2006
                    • 468
                    Shooting from the hip (Dillon reloader )
                    No expert but after modding several cases, two Lian Li PC-60s amoungst them, I too would recomend the Akasa Eclipse 62. It can be had cheaper as a GlobalWin(the OEM for Akasa) but the Eclipse is better finished.
                    All cages and panels are removable, leaving a free standing aluminum frame=a modder's paradise, a fitters dream. The cages are also anodized in black It accepts eATX boards and is 45mm wider than most ATX cases. Google reviews. Two members at Anand's did mini-reviews on them, one a long time builder and he said it was his best case ever. It'll be my next case.
                    For a good cheap case w/door(dislike doors) provantage.com has the Antec SLK3000B for $31+ship. Thi$ would leave buck$ for a better PSU. It's caused no RMA problems that I've heard of but most Antec cases w/PSU have the warrenty sticker cut. Odd but true. P150 & P160s included.
                    http://forums.silentpcreview.com/viewtopic.php?p=231813
                    The Higher end AMD CPUs come with a retail HS that has 4 heat pipes and 80x15 fan that rivels the XP-90 w/80mm fan as per testing at madshrimps.be. I'm hooked on Intel and await the Conroes after the initial feeding frenzee is over.
                    Though rarely used all three builds here have a FDD. I don't remeber the brand but FDDs are being offered now that also read cards, maybe 4 types not 8~9 like a fully dedicated reader.
                    I'll blame it one you folks for cluing me into the build quality of Enhance. The Enhance units that end the part number in GH are 80plus.org certed. eWiz.com did have a number of them for sale cheap but most are sold. The ENP-5150G there is worth a look. buildtoorderservers.com has the Zippy HP-2 6460P w/o thermal fan for $85 and the HG-2 6400P for $89 with thermal fan (gotta open mine up for some tight pics to post).
                    ...Galvanized
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      As far as i know, some of Antec`s desings are good, but most are very inefficient. The main problem is, that Antec is selling many diffrent products, probably from many diferent vendors. Some are junk, some are not. I suggest Amacrox Free Earth or "frei Erde", a decent FSP unit or Seasonic S12. They are in all cases very efficient desings (more than 80%) with good endurance and proven good performance in any respect.
                      And in my opinion, you get more for your money than from Antec.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        Frei Erde AX650-GLN
                        sounds like a Fortron FSP650-GLN
                        both teac and mitsumi do floppy's with 7 in 1 card reader usb 2.0. in black also.
                        talking about legacy stuff though, they will get rid of the ide connectors some time so its time to be thinking about sata optical drives. i recall the plextor which was the first had problems. is there any ones now that work?
                        • Galvanized
                          • Mar 2006
                          • 468
                          Mitsumi is to be eschewed, so say most of the old timers say when asked. Teac has generally been a trusted brand afaik.
                          The only opticals I've used are LiteOn and Plextor and heard of some issues with the first Plextor that was SATA. At this point in time a SATA optical has bragging rights and thinner cabling. About the time Dell starts using SATA opticals the price for one will fit my budget. I like Plextor but buy older model types for cheap.
                          I've read a number of posts where the ham-fisted have broken SATA ports, both power and cables. They are quite fragile. A redesign is in order for both HDDs and opticals.
                          I'll see if I can find it, one of the HDD providers offers a plastic bridge that holds both cables to the drive. Kind of a retro-fix.
                          • stretch0069
                            • Oct 2003
                            • 2658
                            Thanks for all the input y'all.
                            I would wait for some of the item described, but I need to get this ordered by like Monday. That way it'll be here in time to put it together before heading back to school. (BTW...I wish someone would have told me that my chosen profession pretty much guarentees that I'll keep going to schools until I die. ) Oh well.
                            Ok...since AMD seems to be a good option......what about this?
                            AMD Athlon 64 X2 4200+ Manchester 1GHz HT 2 x 512KB L2 Cache Socket 939 Dual Core Processor - Retail
                            Model #: ADA4200BVBOX
                            $355.00
                            but what to put it on???? I thought about this:
                            ABIT AT8 32X Socket 939 ATI CrossFire Radeon XPRESS 3200 ATX AMD Motherboard - Retail
                            Model #: AT8 32X
                            $174.99
                            .... but its out of stock and I'd need different RAM.
                            Ugh.....decisions decisions.......
                            • Fatal0E
                              • Jan 2004
                              • 252
                              I'd would definetly take the X2 over the Pentium D. Not a fan of of netburst chips at all. Had great luck with modern Abit boards. For the case I have used several Antec P180's lately, not the easiest case to put stuff in, but damn its quiet and cool. Doesnt come with a PS so you can get what you want, but have to make sure and get a power supply with long cables.
                              • stretch0069
                                • Oct 2003
                                • 2658
                                Yeah...I'm partial to Abit boards. I was looking at the AN8 Fatality SLi board, but the place I was going to get it is out of them too.
                                Damn.....I didn't think it would be this difficult.
                                • linuxguru
                                  • Apr 2005
                                  • 1564
                                  If you can still get them, go for the Socket-939 Toledo Opteron 165, 170, 175 or 180 dual core instead. They have 2 x 1M L2 cache and are supposed to be excellent overclockers.
                                  http://www.anandtech.com/cpuchipsets...oc.aspx?i=2591
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Yes, the dual core Opteron are nice processors...
                                    The Asus A8R32-MVP Deluxe is a good match for your GFX card, if you want to run crossfire you need a mobo that does not have a nVidia chipset, because it is not supported... (there are hacks to make it work but no one know how long they will work before nVidia disables them via their drivers)
                                    IMO there is not much need in buying very expensive RAM, sure, quality RAM but not RAM that can OC very high, because if you have a AMD system it already has enough bandwidth as it is, and if you OC you will probably need to run on a divider anyway because they OC like crazy and I don't know of many memories that are affordable and does 300mhz
                                    However with the AMD and Intel route comes a problem, AMD is switching to socket AM2 on 06/6/6, there will not be any faster Socket 939 CPU's released after that date I have heard...
                                    A similar cenario with the Intels, the Netburst arcitecture has seen it's last CPU, there will not be a faster CPU introduced than the 3.73Ghz P4...
                                    • stretch0069
                                      • Oct 2003
                                      • 2658
                                      Why does this have to be so difficult???? I checked a couple different places for the top two boards I want, but everyone is out of stock.
                                      Choice#1 - ABIT AT8 32X Socket 939 ATI CrossFire Radeon XPRESS 3200 ATX AMD Motherboard
                                      Choice#2 - ASUS A8R32-MVP Deluxe Socket 939 ATI CrossFire Radeon XPRESS 3200 ATX AMD Motherboard
                                      So....what does everyone thing about this:
                                      DFI Lanparty UT CFX3200-DR Socket 939 ATI CrossFire Radeon XPRESS 3200 ATX AMD Motherboard
                                      I'm getting to the point where my head is spinning and I haven't had anything to drink.
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        I've heard many complaints about the cousin to the CFX3200-DR... I was going to get the DFI crossfire at first and a X1900XT but "settled" for a DFI Expert (nFoce4) and a 7900GT instead...
                                        IMO unless you are into overclocking and tweaking you should not get a DFI, they can be tricky to get to run well with different kinds of memories etc etc... Of course when you do know what you are doing and get a good board it is the best board money can buy...
                                        And don't take my word for it, have a look on DFI Street...
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • ashrf2023
                                          "HP RP5 Retail System Model 5810"
                                          by ashrf2023
                                          please iwant bios "HP RP5 Retail System Model 5810"
                                          03-16-2023, 09:42 AM
