WD 120GB drive making sounds
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I got it on video:
    http://youtu.be/FEYVvKx_fhY
    I don't know much about hard drives..
    The question is whether this is a controller board or disk problem.
  • dumpystig
    • Jul 2011
    • 485
    Re: WD 120GB drive making sounds
    Whatever it is it sounds pretty well fucked to me
    System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
    • larrymoencurly
      • Oct 2004
      • 960
      You may want to find Franc Zabkar in WD's forums or ask at HDDguru.com. If that's a JB series drive, apparently there have been issues with it.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Pretty sure that's the spindle motor trying to start. Stick the drive in the freezer for a while and try again...
        Ludicrous gibs!
        • rop12770
          • Mar 2010
          • 22
          • Portugal
          Seems head problems..
          If you data is valuable, don't mess with it and don't freeze it.
          Ask for a pro.
          • lti
            • May 2011
            • 2557
            The heads might be stuck to the platters. I managed to unstick the head in a laptop drive and get my data off of it, but your drive probably has more than one platter. That will make the process more difficult.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              My guess as well. Although the "wheee" sound at the end of the vid seems to indicate something else.
              Do you feel any continuous vibration on the drive? If so, the motor is running and it's the heads making that noise.
              A working TV? How boring!
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                I didn't own that drive, so I don't care about the files.
                How long should I put it on freezer?
                And how long I should wait after I take it out before I test it?
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  At least a few hours so it cools down properly. And you should test it as soon as you take it out, otherwise the magic will be gone. Put the drive in a ziploc bag when you take it out, close the bag around the cables (easier with SATA ), to prevent condensation (to some degree at least).
                  I'd advise you to put the drive in the bag before you put it in the freezer - otherwise the drive's metallic surface will stick HARD and it'll be damn near impossible to take it out afterwards.
                  • mariushm
                    • May 2011
                    • 3799
                    I don't advise people to resort to this method unless everything else didn't work. I suspect something on the PCB board is messed up, like a diode or something like that.
                    It would be safer to just search for another broken drive on eBay and switch the pcb boards first... or at least use a multimeter to test the voltage and amperage going to the motor first (see if it dies when motor reaches a certain speed or not)
                    Don't put it in the freezer.
                    Get a couple of plastic jiffy bags (the ones that can be sealed) and a few of those baggies with silica (that absorb humidity).
                    Seal the drive in a bag with a bunch of those silica baggies then seal the bag in a second jiffy bag. (you should use two because air and humidity goes through the plastic)
                    Put the drive in the fridge or freezer only if you can get the freezer to cool only up to -5-0C - freezers are usually -20-30c or something and that can damage surface mounted components on the pcb.
                    Once the drive is for a while at -5-0C, take it out of the fridge, pop open the bags connect the cables then try as best as you can to close the bags again but use a needle or something like that to punch a few holes in the bags.
                    The reason for this is you don't want a big opening because as drive warms up it water in the air will condensate on it and you may get shorts on the board but at the same time the drive needs some air (the drives and the disk head floats on air cushion and it needs air pressure from outside to work right)
                    If it works start copying and hope it lasts - you won't get a second chance to make it work.
                    With more recent drives, you may not be able to make them work with this method, simply because in the first seconds of operation, due to the high rpm speed and friction with the air inside,the platters warm up and expand so the drive needs to recalibrate the disk heads on the tracks.
                    With such low temperature, the drive's firmware may not even be able to calibrate the heads.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Have you ever done that? Because i know both online or in real life, people who have been searching for a compatible PCB for their drive for more than an year, AFAIK, board swaps only work if the drives are from the same batch, unless you own some specialized (and expensive) equipment which allows you to override the head calibration data.
                      • mariushm
                        • May 2011
                        • 3799
                        I was lucky enough to not have hard drives failing on me yet so no. Yes, I would assume they have to be the same series or something like that,m if the firmware can't be swapped.
                        I think the recovery companies usually just open them up and mount the platters in other drives. They may even have some quality optics to read the platter surface using lasers or some stuff like that.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          Not always. They do things like head swaps though. They have a combination of hardware/software tools that understand how data is written on a drive with more than one platter, so if only one head is bad, they force read the drive with the good heads, and only then swap out the bad head and read the remaining side. Then the software reconstructs the data.
                          • dood
                            Deputy dood
                            • Mar 2004
                            • 2462
                            It's magnetic media... can't read it with lasers.
                            Ludicrous gibs!
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              I just tried the freezer trick but it didn't work....
                              • madura2010
                                DAY11AM6E0 hard disk drive and optical disk drive not detected
                                by madura2010
                                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                i checked the connectivity of ribbon=good communication with hard and motherboard
                                changed hard disk and checked=3f0 error persist
                                sata power=+5v available
                                Then checked data capacitors=all good
                                Then checked data lines path connectivity to pch=all good
                                reflashed...
                                03-12-2023, 09:09 AM
                              • federalhouse
                                **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                by federalhouse
                                I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                **Background:**
                                I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                **What I've Tried So Far:**
                                1. I accessed
                                08-01-2024, 07:03 PM
                              • reformatt
                                Intel iMacs, 3rd party SSD failures and Fusion setups
                                by reformatt
                                I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                12-18-2024, 10:34 PM
                              • perfm2
                                HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                by perfm2
                                So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                Steps taken in my usual process.
                                Reset security settings in the BIOS
                                Ensure existing HD comes up into the OS
                                Shut down the laptop and disconnected the main battery
                                Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                Replace battery connector and close up the laptop
                                Insert my USB drive with my Windows 10 image I've...
                                03-21-2023, 08:45 PM
                                HP EliteBook 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                09-06-2024, 08:50 AM
