Linux and whatnot
  • weirdlookinguy
    • Sep 2007
    • 1638
    Linux and whatnot
    This post is not intended to bash Linux. I am simply sharing my recent experiences with it.
    I realized having an install of XP 32-bit on my computer would be nice, so I formatted my hard drive and proceeded to install XP 32 and Windows 7 64 for some dual-boot action. Then I realized: well shit, if I'm going to go through all this trouble, might as well get some Linux triple-boot going.
    I tried Fedora 15. Install was very fast, about the only positive in this story. It had some newfangled interface that made no sense to me and drove me up the wall. Icons on the right side of the screen and it was hard to tell what was running. I had no graphics acceleration and no resolutions past 800x600. I googled how to install ATI drivers and all I found were a bunch of scattered, incompleted guides for older versions of Fedora or for NVidia graphics. After 5 minutes of fucking around with terminal I felt a massive migraine coming on so I gave Fedora the finger and decided to try Ubuntu instead.
    Ubuntu was also easy to install. It has that same newfangled interface. Why does Linux have to change so drastically every time I go to use it? The GUI was perfected with the introduction of Windows 95 and does not need to be changed. Why does Linux always insist on re-inventing the wheel?
    I liked Ubuntu better than Fedora but still just could not get those damn ATI drivers running. I tried to do the auto-install and after 20 minutes of waiting it told me that installation was unsuccesful.
    At this point I was done with Linux, my blood pressure was rising, and a headache was about to set in. I hit the reset button and booted into good ole' Windows 7. Ubuntu will stay installed on the off chance that I need access to a Linux system, but Windows 7 remains my main OS.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Linux and whatnot
    with fedora, that is gnome shell. most hate it but i like it. it takes some getting used to.
    the old interface was looking dated and gnome shell was the attempt to fix that.
    however, ubuntu said no and decided to use the poorly designed interface from the netbook remix for the desktop release. it is worlds different than gnome shell.
    if you want the oldskool gnome, try linux mint.
    sigpic
    (Insert witty quote here)
    • weirdlookinguy
      • Sep 2007
      • 1638
      I just might try Mint.
      I want to like linux, I really do. It just always and without fail drives me up the wall when I try to give it a chance.
      • lti
        • May 2011
        • 2553
        I don't like Linux because I haven't seen good clones of certain programs (like Microsoft Office) and it is too difficult to configure.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Qft
          • bigbeark
            • Jan 2010
            • 661
            The best idea is to download Ubuntu 10.04.3.LTS from the Ubuntu site.
            LTS means long-term support. Count on at least three years IE til 2013.
            If you download this version, you get the traditional GNOME desktop.
            You can check for proprietary ATI drivers by going to System->Administration->Hardware Drivers. Ubuntu will find the recommended ATI drivers and prompt you to install the recommended one.
            The newfangled Desktop is called UNITY and is supposed to appeal to people used to mobile phone users.
            There is a way to install the GNOME desktop on the latest Ubuntu release but it is a PITA.
            The previous version 11.04 allowed you to select the GNOME desktop, but the new version (11.10) does not.
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              I tried Fedora 15 recently it seem stable, which seem unnatural to me. I had trouble with the ati drivers turns out there's a nasty bug when using the ATI provided driver that when you install the driver it will crash the kernel hard forcing people to wipe and reload.
              The only one you should use is the akmod version from rpmfusion, add it to the YUM repositories and install it. But unity likes to scramble the windows and tilt text in them, it's better then crashing tho.
              I would not use ubuntu 11 series at all, tons of problems with unity and few stuff is still broken.
              Stick with 10.04 or .10
              Go debain or mandriva
              • mockingbird
                • Dec 2008
                • 5484
                Anyone who uses 10.04 is insane..... unless it's in a server environment, you should use Oneiric Ocelot for desktops...
                I recently upgraded to Kubuntu 11.10... It's fantastic!!!
                They really polished things... The Network Manager has really been nearly perfected, Plymouth is finally working for me, eventhough I had to install Grub in block mode, because I boot Kubuntu from the XP boot menu. (Actually, I submitted this bug to the tracker, the dev fixed it for me). The only quirk was that I had to force install grub, because the graphical setup doesn't do it for you properly, no big deal.
                The drivers have been updated, the RTL8185 driver works great out of the box, they finally updated the lousy driver from 11.04 and earlier... The Ralink wireless drivers were also great out of the box (RT2870 in case anyone is interested)...
                I updated to the latest nVidia drivers for my 6600 from some backport PPA, works great. Layer acceleration in Firefox is slow, even with acceleration forcibly enabled, but that's because Firefox needs its own layer engine in Linux, and it doesn't have one. I'm gonna see if Chrome/Chromium is any better... Flash and HTML5 performance isn't that great in Linux with my 6600 (It's a bit of a tradeoff... I could try the older drivers for this relatively old card, like I do in Windows, but in Linux, I actually need the latest ones to take advantage of the new 3D features)...
                I _still_ would be hesitant to use Linux on any laptop, because Linux doesn't seem to be able to properly read ACPI fan settings from most laptop BIOS... and this is even after a custom DSDT is hacked into the kernel... So far, very impressed. It's getting nicer and nicer after each release (albeit more bloated too)...
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  I was also forced to wipe and reinstall everytime I tried to install Nvidia drivers with Arch.
                  It was guaranteed that on reboot, I get an error message about the root FS not even existing and dropping me to the initramfs shell! -> That's worse than fucking Windows ME, even in the worst case!
                  I had much better results with Arch, when using Intel graphics.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    That's also a nasty bug where installing the Nvidia drivers from the SliTaz's own repository, it causes X.Org to refuse to use anything other than the software rasterizer!
                    You can see this in the X.Org log. This means 3D is always borked!
                    With SliTaz, you're *required* to get the Nvidia drivers from Nvidia's web site!
                    3D support wasn't borked anymore since I did that.
                    Arc A770 16 GB
                    • ivtec
                      install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                      by ivtec
                      Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                      01-17-2025, 12:54 PM
                    • tsavpyn
                      Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                      by tsavpyn
                      Dear all,
                      I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                      Now I have a problem that I am unable to dump my BIOS into bin file.
                      My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                      I searched for FPT but there is no Linux version and none of them work.
                      I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                      I would really appreciate it if anyone...
                      05-28-2024, 11:18 PM
                    • abajor
                      Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                      by abajor
                      I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                      I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                      The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                      Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                      04-23-2024, 11:43 PM
                    • claws77
                      FX553VE-DM318T(FX553v) not POSTING
                      by claws77
                      Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
                      Gpu - nvidia geforce 1050ti
                      Ssd orion o700
                      Hdd hgst721010A9e630
                      See images
                      What's not working right?
                      The system does not even POST, display is black,
                      LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
                      When did the problem happen?
                      My laptop had dual boot setup, ubuntu and windows 10.
                      It already had a moklist error, that would occur when i tried to boot ubuntu.
                      05-17-2025, 04:09 PM
                    • japlytic
                      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                      by japlytic
                      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                      Tried (only with keyboard/mouse connected):
                      • BIOS + database update
                      • Using latest Windows 11 image built with official image creation tool
                      • Previous setup version for Windows 11 installer
                      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                      06-19-2025, 04:59 PM
