$100 capacitor
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    $100 capacitor
    see pic.
    no whining about the cost of itty bitty mobo caps!
  • tiresias
    • Feb 2006
    • 489
    Re: $100 capacitor
    334 Joules fully charged too... planning on building the first ATX-compatible linear power supply, kc8?
    After all, while it wouldn't be small, or light, or particularly efficient, it sure could offer some very tight voltage regulation...
    • tiresias
      • Feb 2006
      • 489
      Re: $100 capacitor
      Apologies for my stupid statement above. Linear PSU? 450V Input capacitor?
      I hadn't had my coffee yet - yes, that's a good excuse.
      • CaysE
        • Feb 2006
        • 40
        Re: $100 capacitor
        So does your hand get vaporized if you accidently bridge the contacts on that one?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: $100 capacitor
          if it were charged and you got across it hand to hand you likely wont live to tell about it.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: $100 capacitor
            what about on the balls?
            can you explain a bit about what it is installed in and the function of the equipment. i am sure everyone is interested.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: $100 capacitor
              its from a large motor control from a mill.
              as for the other comment it would likely eliminate the ability to reproduce.
              • stretch0069
                Screwed Up Super Moderator
                • Oct 2003
                • 2662
                • oooo ess aaaaaaaaa
                Re: $100 capacitor
                anyone that would put it across their balls probably shouldn't reproduce anyway.
                "Its all about the boom....."
                Guns kill people like spoons made Rosie O'Donnell fat.
                We now return you to your regularly scheduled drinking.
                "Fear accompanies the possibility of death.....calm shepherds its certainty"
                Originally posted by Topcat
                AWD is just training wheels for RWD.
                • LLLlllou
                  • May 2011
                  • 201
                  Re: $100 capacitor
                  see pic.
                  Mmmmmmm what fun I could have with a few dozen of those . . . .
                  • severach
                    • Aug 2007
                    • 1055
                    Re: $100 capacitor
                    Afrotechmods has some nice videos like Fun with ultracapacitors.
                    http://www.youtube.com/watch?v=EoWMF3VkI6U
                    sig files are for morons
                    • MORETTIGIAN
                      by MORETTIGIAN
                      Title:
                      Description:
                      Procedure performed:
                      - Removed backplate
                      - Reapplied thermal compound
                      - Reassembled card
                      09-18-2025, 12:14 PM
                    • Agent24
                      Dick Smith Q-1760 linear power supply filter capacitor question
                      by Agent24
                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                      It has at least one problem.
                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                      I have already ordered a replacement potentiometer, so that's not an issue.
                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                      All are CapXon...
                      10-21-2025, 05:39 PM
                    • Prolog
                      by Prolog
                      12-01-2024, 08:27 PM
                    • chth96
                      by chth96
                      12-22-2023, 04:34 AM
                    • chth96
                      by chth96
                      06-02-2024, 07:31 PM
