Looking for long-lasting thermal interface material
  • lti
    • May 2011
    • 2547
    I want to find thermal interface material that does not need to be reapplied regularly. Arctic Silver Ceramique only lasts a year before the chip I am trying to cool starts overheating.
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Looking for long-lasting thermal interface material
    How about that clay-like stuff that turns to liquid at about 60C, like Loctite PowerStrate or Bergquist Hi-Flow? I have no idea where to buy them cheap, but some people have gotten pieces for free from AMD by saying they messed up the installation of the heatsink of their retail boxed CPU.
    • brethin
      • Dec 2008
      • 1907
      I use Arctic Silver 5 and have never needed to reapply it. In fact it seems to better with age as it cures.
      • yyonline
        • Jul 2009
        • 692
        Ditto. Ceramique will dry up as it ages, but it should still transfer heat. I've never had to reapply it... If you're having to reapply it, I'd check to make sure that your heatsink mounting is secure. Perhaps the heatsink might be vibrating or shifting a little, which would cause dried up Ceramique to fail.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I've always used Arctic Silver 5 and I've never had it dry out.
          • weirdlookinguy
            • Sep 2007
            • 1638
            I've got a C2D that has been running for 2 years now. Never re-applied the Artic Silver 5 I used and the temps are the same.
            • lti
              • May 2011
              • 2547
              I have some Arctic Silver 5. I thought it should last longer than the Ceramique. The Ceramique still transfers some heat after a year, but it is only slightly better than nothing.
              • ThePCDoctor
                Retired Tech.
                • Sep 2011
                • 59
                Long before there was Arctic Silver, I got a 2oz container of Thermal Compound 120-2, from Wakefield Engineering, Co. (Wakefield, Mass.) Circa, 1980.
                I still have and use it whenever I clean up a heatsink and need to re-grease it.
                Even at 30 years old, it still works great!
                Just like "Brylcreem"......... A little dab'll do ya!
                Cheers Mates!
                The Doctor
                Experience is truly the best teacher.
                Backup! Backup! Backup! Ghost Rocks!
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  i have the same but it has hardened in the jar.reconstituted it with paint thinner but that flashed off in 6 months.maybe silicone oil?
                  Cheers Mates!
                  The Doctor
                  • Longbow
                    • Jun 2011
                    • 623
                    Standard Zinc Oxide thermal compound works as well as any of the fancy expensive products that are sold for computer CPU's. Unless you have access to a study showing remarkable differences in thermal transfer rates, save your money. I have never had to remove a device to re-apply thermal compound. It is good until you need to replace the device bolted to your heat sink. Either your device is being operated too close to its thermal capacity, or your heat sink is too small (or both). You do not have a thermal compound problem.
                    Is it plugged in?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      I'll have to disagree. Arctic Silver and similar products actually work as advertised. There are places to get bigger quantities for a lot cheaper but that's a different story.
                      The problem with zinc oxide compound is that a lot of manufacturers use cheap formulas that dry up in a couple years. Unless you got a reputable source, it is worth investing in better quality grease.
                      A working TV? How boring!
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        you mean the white stuff?
                        I know that that crap baked into sludge in my old dell latitude d400... changed it 6 months ago, when I opened it up it was, ahem, sludgy. like the consistancy of bread dough... I switched to whatever the silver stuff cooler master includes with its coolers ( I had leftovers from a cooler upgrade)... the temps are a lot lower and it works better...
                        maybe I will change the thermal pads and compound in my d630 over fall or winter break... I used the white crap in it and I am a bit worried it may bake as well (not good for the nvidia graphics)
                        sigpic
                        (Insert witty quote here)
                        • Gcnewbie
                          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                          by Gcnewbie
                          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                          I opened the...
                          03-29-2024, 06:55 AM
                        • Veyron7887
                          Laptop overheating after replacement thermal paste
                          by Veyron7887
                          Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                          11-24-2024, 05:08 AM
                          ALIENWARE Aurora R7 i7-8700K Specification for Upgrade or Repair
                          This specification for the ALIENWARE Aurora R7 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aurora R7 boardview and Aurora R7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Aurora...
                          09-12-2024, 03:36 PM
                          09-12-2024, 03:28 PM
                          ALIENWARE Aurora R7 i7-8700 Specification for Upgrade or Repair
