vmod simple help
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    vmod simple help
    im about to do this vmod on this page (first one listed). and im wondering why he needed to use GND for the capacitor?
    was this needed? im planning on having it go 5V source => Choke => rubycon 1000uf 6.3v cap => mosfet leg.
    is there a problem in doing this and having the volts go straight through the cap? id like to have the volts cleaned up a bit before feeding them to my ram.
    also, would it be benificial to use 2 of the caps in parralel instead of one?
    im planning to solder all of this stuff onto some old pcb that i will be cutting down.
    http://forums.techpowerup.com/showthread.php?t=4751
    Specs
    DFI AM2 LANPARTY UT NF590 SLI-M2R/G
    X2 3800+EE AM2
    2x1GB OCZ PC2-6400 Platinum XTC
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Mushkin HP-550(Cap/Filter Modded)
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    Re: vmod simple help
    here is what i made, its pretty poor soldering job i know.
    5V+ source => Choke => 2x 1000uf 6.3v capacitors in parrallel => to MOSFET leg
    seems the upload isnt working here. so look at this thread for photos.
    http://xtremesystems.org/forums/show...92#post1332292
    Specs
    X2 3800+EE AM2
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the cap is to ensure vdimm is clean.its - lead needs to go to a ground foil to do that.
      it needs to be as close as possible to input of the vdimm regulator.
      • Chris1992
        • Apr 2005
        • 561
        Oh yes, and Welcome to Badcaps Forums!!!!!
        The great capacitor showdown!
        • WeStSiDePLaYa
          • Mar 2006
          • 63
          Would that not create a short circuit?
          or do i connect the negative lead solely to ground, and then connect the positive lead to the source wire, and then the wire to the mosfet leg?
          will the choke be much benefit to this?
          looks like i will be creating another version. could anyone help me to put in some diodes or resistors to lower the volts about .7v? i just need a laymens diagram.
          Specs
          X2 3800+EE AM2
          XFX 7900GS
          Maxtor 6L250S0
          Maxtor 6V300F0
          Cooling
          Swiftech Apogee
          Swiftech MCW-60
          Swiftech MCP-600
          • davmax
            • Dec 2005
            • 899
            You certainly have an interesting challenge. Personally I would not attempt this.
            Anyhow you asked about the choke. Well it is best left out because there are several issues. 1. the 5volt supply is basically DC with some ripple as is the 3.3Volt supply so there would be not much gain . 2. To insert a choke into a circuit with a heavy DC current can be rendered pointless if the DC current causes the choke to saturate, so the choke must be chosen to match the conditions of the circuit.
            I have modified your pic. The negative connection to the capacitors must connect directly to the ground plane close to the MOSFET/transistor that is regulating the DIMM supply.
            Diodes should be connected to the points shown so that the +5 volt supply passes through to the + side of the caps. The challenges are 1. Where to mount the diodes. 2. How many? 3. What current rating? 4. How to keep them cooled? The picture supplied with the mod instructions shows two dual diodes(4 diodes total) we have to presume that they are all connected in parallel. I cannot make a precise recommendation because the load current is unknown. If the current is 10 amps it would need to be shared between about 4 diodes particularly if there is vitually no heatsink to remove the heat generated.
            Hope this helps.
            Gigabyte EP45-DS3L Ultra Reliable (Power saver)
            Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
            160Gb WD SATAII Server grade
            Nvidia 8500GT 256Mb
            160Gb WD eSATAII Server grade for backup.
            Samsung 18x DVD writer
            Pioneer 16x DVD writer + 6x Dual layer
            33 way card reader
            Windows XP Pro SP3
            Thermaltake Matrix case with 430W Silent Power
            17" Benq FP737s LCD monitor
            HP Officejet Pro K5300 with refillable tanks
            • WeStSiDePLaYa
              • Mar 2006
              • 63
              i think im gonna make this easy on myself untill i get some better skills. and just do 2 caps in parrelel and thats it.
              but now i have a question, do i have to worry at all about the current that this will be drawing? 2x512mb sticks have to be drawing a decent amount of current.
              Specs
              X2 3800+EE AM2
              XFX 7900GS
              Maxtor 6L250S0
              Maxtor 6V300F0
              Cooling
              Swiftech Apogee
              Swiftech MCW-60
              Swiftech MCP-600
              • Chris1992
                • Apr 2005
                • 561
                if you trust the PSU calculators out there, 10 watts per stick assuming ddr. thats 20 watts.
                • WeStSiDePLaYa
                  • Mar 2006
                  • 63
                  i dont think those calculators take into account 3.3v+ vdimm, and 260+ mhz. :
                  Specs
                  X2 3800+EE AM2
                  XFX 7900GS
                  Maxtor 6L250S0
                  Maxtor 6V300F0
                  Cooling
                  Swiftech Apogee
                  Swiftech MCW-60
                  Swiftech MCP-600
                  • Chris1992
                    • Apr 2005
                    • 561
                    Watts are independent of voltage iirc, and with the OC maybe 15W/stick.
                    • WeStSiDePLaYa
                      • Mar 2006
                      • 63
                      well, i finished the mod. and everything is working great so far. my vdimm is rock solid, i already can see it has improved oc at same vdimm as before, most likely the caps help there.
                      mosfets in the area seen about 25C increase in temps, but they still only peak around 50C, so they good to go.
                      ill get some pictures of the final project when i upload the pictures.
                      Specs
                      X2 3800+EE AM2
                      XFX 7900GS
                      Maxtor 6L250S0
                      Maxtor 6V300F0
                      Cooling
                      Swiftech Apogee
                      Swiftech MCW-60
                      Swiftech MCP-600
                      • harp
                        simple win network with optimization issue
                        by harp
                        simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                        06-23-2025, 11:01 AM
                      • Nevillet
                        Simple PIR sensor circuit to drive a small motor
                        by Nevillet
                        Hi All,
                        I'd like some help designing a simple circuit for driving a small DC motor.
                        The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
                        I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
                        Can somebody design me a simple circuit for me using something like a 2N3904?
                        I'm happy to include a relay if that makes sense.
                        Many thanks.
                        https://www.badcaps.net/forum/attachment.php?attachmentid=3...
                        07-09-2023, 10:48 AM
                      • FZG
                        Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
                        by FZG
                        Hello there, helpful forum people!
                        I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
                        On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
                        The original part...
                        05-10-2023, 11:54 AM
                      • CG2
                        LED uplighter dimmer burnt resistor
                        by CG2
                        I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                        02-14-2024, 09:23 AM
                      • bauto601
                        KDM 480W PSU upgrade succes! (opinions?)
                        by bauto601
                        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                        A "nice" YoungYear unit? - Badcaps
                        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                        12-26-2023, 03:05 PM
