Today I recapped my AX34 PRO II, the caps that I have exchanged ar all Lelon 6.3V 1000uF and they where all bulging and leaking. I bought 7 new Rubycon ZL 6.3V 1000uF and now the motherboard is working again.
Resurrected AOpen AX34 PRO II
by sam_sam_samHere is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...-
by frannyjunkHi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
Any thoughts if OK to use these higher voltage capacitors? -
1000uf 120v 46mmx18mm or something close, Thanks3 Photos
by awdrifterI just bought some 1000uF 10v capacitors from eBay to fix my Samsung 2220WM, but it seems like they are already bulging? Are they ok to use? Thanks....
by amijimHello Badcapers ,I am Amijim and I am about to change the caps on two ancient socket 370 dual motherboards from 2001 and I would like to you if the Lelon RXW low ESR caps I can find locally is a good replacement part.Also i would like to ask you what wuld be better ,change the original 2700μf caps to 3300μf or 2200μf? Thank you....
04-02-2022, 12:09 AM -
- Loading...
