Curious... replaced the only 2 caps (220uf/25v 8x12mm-ish G-Luxon's) in a WRT54G v2 with Samxon GT's that I had laying around, and the two main chips on the board run hot to the touch. Out of curiousity, I put the G-Luxon's back in, and the chips then run slightly warm to the touch.
Is this a normal result? I'm guessing not a good choice for replacement, but I've read many posts where Panasonic FM were recommended, so figured a "Low Impedance" GT would be just fine.
The ripple on the originals was right around 200-300mA (exact size not on data sheet) and the GT is 640mA, so that shouldn't be a problem...
Help me learn
Help me learn
