SCSI fun and questions.
  • Wizard
    • Mar 2008
    • 2296
    I troll through ebay often and I see reasonable 10K and 15K SCSI drives like 18GB to 57GB range.
    Some drives needs a cage with backplane (80pin), also I don't mind using 68pin (used it once and that was cool but let down was PCI limited the bandwidth). Some use fibre-channel interface, I did not see any fibre-channel controller on ebay?
    Be aware that I might not want to buy adaptec controller card. If it is PCI-X that is fine since I can find cheap socket 370 or xeon motherboard.
    Cheers, Wizard
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: SCSI fun and questions.
    don't nessaccarly need a backplane
    http://shop.ebay.com/?_from=R40&_trk...All-Categories
    heres your controller
    http://shop.ebay.com/i.html?_nkw=fib...nel+controller
    • Wizard
      • Mar 2008
      • 2296
      Is there better documentation for fibre channel particularly for storage?
      I'm not sure this how is this done at hard drive end. Controller card easily understood.
      Thanks and cheers, Wizard
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        yeah, wikipedia and google
        fiber channel is like connecting hard drives directly to a network, or directly to a controller, depending on how you configure it
        • NxB
          • Feb 2009
          • 1595
          FC has about 1/4 of the 80pin scsi connector on the drive. The fiber cables connect to the jbod/backplane and the drives connect to that. IMO the controllers are too expensive for the performance.
          • bigbeark
            • Jan 2010
            • 661
            Fibre channel is always implemented as an array of drives in a separate case.
            You can get "T-cards" to hook up a single drive, but once you add up the cost of the controller card, the FC optical or copper cables and the T-card, you will be north of $100, not counting the FC drive itself.
            Lots of FC adapters and drives available cheaply on Ebay.
            Check this site http://www.cs-electronics.com/fibre-...l-adapters.htm
            or for more personalized service try this guy:
            http://store.ckcomputersystems.com/i...dex&cPath=1_67
            I never pursued fibre-channel, I already had lots of SCSI on hand.
            I have lots of SCSI controllers, adapters, cables and drives. It is my default setup for assembling machines. I use single SCSI drives because they are way faster than IDE.
            The only thing I would advise is ALWAYS use a terminator on your SCSI cable. Lots of times I have been able to get away without one, but whenever the system has trouble detecting the drive adding the terminator fixes the problem. Also, avoid the white-label refurbs. I get my drives from a local recycler. I once bought 5 Hitachi 36GB drives for $20. They all work well.
            I use HD coolers on all my drives, SCSI drives run pretty hot - especailly Seagate. Quantums are cool-running but noisy. I prefer Fujitsu.
            • Wizard
              • Mar 2008
              • 2296
              Thank you all very much about FC SCSI stuff. I'll just give it a pass and look at true SCSI stuff.
              For some reason, I find Adaptec line kinda of slow brain, what is good makers of SCSI cards these days?
              Cheers, Wizard
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                berk what about terminating a chain with a scsi drive, i've seen drives with terminator options. I only use scsi on workstations and servers, regular joe desktops always ide or sata
                adaptec, lsi, areca are the big ones, but now a days SAS (Serial Attached SCSI) is on its way to replacing Parallel scsi altogether.
                before you wonder or ask, SAS controllers are compatible with SATA (physically an logically) drives, but not the other way around. I actually have just ONE sas adapter (Dell PERC-6). but I have numerous scsi adapters, most of them crap a few perc's with a memory stick and one with a backup battery
                when it comes to servers, I usually try to use linux raid instead of a scsi raid, linux manages it better then the older cards I have
                • studdy05
                  Bricked HP Probook 450 G7 Bios questions
                  by studdy05
                  Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                  Ive got...
                  07-08-2025, 09:24 PM
                • electronx
                  Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                  by electronx
                  I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                  1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                  According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                  If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                  06-26-2025, 03:27 AM
                • UL161
                  Need Help Identifying Parts on a crossover and a few other newbie questions
                  by UL161
                  Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
                  1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
                  2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
                  09-29-2024, 03:17 PM
                • cloghin
                  newbie questions
                  by cloghin
                  Apologies if I am asking the wrong questions , but not sure how else to start:
                  I have an A2251 / 820-01949 Mac book pro with no power, 20 v on USBC meter and 0.05 Amps. Following this link ( below)
                  * Do I need to remove the board from case so I can access its other side ? The link calls for measuring PP3v3_S5 ( I suppose this is in diode mode with positive probe on ground) , but I don't know how to do that without removing the board from case.
                  * I have the FlexBV board , are the values displayed in volts diode mode only ? Because my etekcity multimeter shows...
                  09-26-2024, 11:48 AM
                • KYBOSH
                  Samsung UN50TU8000 - Dead Panel Forensic Questions
                  by KYBOSH
                  I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                  When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                  When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                  Later I checked for shorts on the panel PCB boards but could not find anything.
                  When I took a look with the FLIR i noticed the 2 resistors...
                  08-10-2024, 08:39 AM
