Model HY554 USB 3D SOUND
  • Maartas
    I bought the Model HY554 USB 3D Sound (external sound card to the USB), because I have a 3.5 mm jack s broken, and BP would need to include someone throwing a link to the driver for this device because it says my device was not detected " I cant find driver pls help
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Model HY554 USB 3D SOUND
    Those things do not need a driver. If it says it's not detected, it is faulty. Go get it exchanged.
    PS. Don't expect it to sound good. I bought one out of curiosity and it works but it sounds like ****.
    A working TV? How boring!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      unless you're running like windows 98, I dont' think there is a generic usb audio processor driver in 98
      • nickgronk
        iMac PowerPC G4 very low sound • Sunflower Model
        by nickgronk
        Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
        I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
        I cannot find any schematics...
        08-05-2024, 07:04 AM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • RossMoodley1967
        HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
        by RossMoodley1967
        Hello
        Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
        Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
        03-01-2024, 06:07 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
