Does size matter?
  • cropduster
    Does size matter?
    Dang it!! It was late and I didn't catch it, I ordered the 1800uF 6.3v 10mm MCZ Series instead of the 8mm. As long as there aren't any clearance problems and I just tweak the leads over a little to fit I'm thinking I'll be OK right???
  • seanc
    • Nov 2008
    • 1319
    Re: Does size matter?
    As long as they fit in the space you're working with, it will be fine.
    • cropduster
      GREAT!! I appreciate the response. I was 99% sure but I hate to go through the whole procedure just to have to re-do it. Thanks again.
      • mockingbird
        • Dec 2008
        • 5488
        You'll get higher ripple suppression, lower ESR, and a longer MTBF, so yes, if you can fit thicker caps, do it!
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          When you "tweak the leads" do it such that there is no pressure on the rubber bung from the leads both while bending and as installed.
          If you pull against the rubber to bend,, or install them with sideways tension on the leads,, you may create a path for a leak.
          Mann-Made Global Warming.
          - Dr Seuss
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            I was about to move this to the VIP section... glad I opened it first :p
            Ludicrous gibs!
            • cropduster
              And............. success!!
              I only had one I had to leave a little tall to clear but it"ll be fine. I actually replaced this motherboard 8 months ago and then my son told me it was getting flakey again. Opened it up and 9 TK caps were bulging again. I"ve soldered stuff all my life but nothing as intricate as this. Damn those traces are close together!! Really glad I found this site. Ordered the caps from here and checked the tutorials to make sure there wasn't anything wierd I had to know. Thanks guys for the help!!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yeah, I was gonna respond with my wife's opinion on the matter but I figured I'd behave this time.
                - Dr Seuss
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • m1ch43lzm
                    by m1ch43lzm
                    Hi everyone
                    09-06-2025, 05:47 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • dragometin
                    Hitachi 40HYC42
                    by dragometin
                    TV Model: Hitachi 40HYC42
                    Power Supply: 17IPS71
                    MainBoard: 17MB95M
                    Panel: VES400UNDS-2D-NO3
                    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                    Is there any variants on 17IPS71 power supply's?
                    UART output pins 10 and 12 on scart connector:
                    Code:
                    12:24:04.595
                    08-08-2024, 05:53 AM
                  • jm1234
                    Solder joints on heat sinks matter?
                    by jm1234
                    solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                    I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                    04-28-2024, 04:38 AM
                  • schematic_jack
                    ASUS TUF B450-PLUS II motherboard schematics, or does this 60B SMD resistor even matter?
                    by schematic_jack
                    I think it would be dumb to toss a "modern" motherboard just because a resistor got scraped off, so here I am. I am hoping to find the right schematic so I can see if the motherboard can live without 1 of 3 60B SMDs in series likely scratched off by the backplate of a PCI-E card install or removal. It could be related to a functionality that is not needed or critical, or it could fry anything I plug into it and power on. If I could find a replacement, I could likely pop in on the board, but if I don't need to, then screw it, I don't mind leaving something dark that doesn't matter....
                    07-06-2025, 02:00 PM
