BIOS Flashing Fears
  • bigbeark
    • Jan 2010
    • 661
    BIOS Flashing Fears
    OK, I confess to never having the guts to flash a BIOS. I've never worried about recapping anything, but I've always taken seriously the warnings that bad things can happen when flashing the BIOS.
    So I've got a number of ancient candidates that I can experiment on. Various old P2 and P3 boards.
    All of these involve use of a floppy drive, I've got lots.
    I'm tempted to try the pure Linux method using DOSMENU program.
    Other alternative to consider is using FREEEDOS. Then theres DRDOS or pure DOS. I find the instructions a bit cryptic, maybe some one here could shed some light.
    I know modern boards have more user-friendly stuff, but I want to learn the old-school way.
    I'm interested in fail-safe techniques of updating the BIOS. I'd rather not brick a board if I can help it.
    I have a some ASUS P2B and CUSL2-C , an ABIT BX6 and a FIC KA-6130. I also have some Shuttle and QDI Slot1 boards, but finding the BIOS updates might be problematic.
    All suggestions gratefully accepted!
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: BIOS Flashing Fears
    get the "Driver Free Disk For BIOS Flashing" from here
    http://bootdisk.com (use the second link.. the first one is the now defunct (or is is just that slow?!) abit ftp server)
    open that tool and let it write the image to a floppy, then add the bios flash tool and the bios file itself manually and your should be good to go.
    note that the flash utility will show you all the available commands (sometimes even with examples) when using the /? parameter (in DOS)
    like "awdflash /?" from the command prompt.
    • b700029
      Banned
      • Sep 2010
      • 640
      If you're not afraid of recapping then it probably means you can solder. In that case you can always desolder the EEPROM and put it in a programmer or solder wires to it to write to it if anything goes wrong. A simple EEPROM programmer can be built out of little more than a serial/parallel port connector and some discretes (if you have a 3.3v parallel port, it can be as simple as a few lengths of wire.)
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        get a UPS, and hook the target computer to it, make sure the floppy drive is good and the disk is good, preferrably tested or new
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I'd ditch the floppy drive and make a USB boot stick instead, much more reliable than floppies...
          Attached to this linked post you will find both the "HP USB Disk Storage Format Tool" and the Win98 boot files
          Just make a USB stick using FAT32 (or FAT16 if you wanna be extra sure) and you will be merrily on your way.
          It will require a BIOS supporting USB support though of course, but I find most computers nowdays does...
          http://forum.corsair.com/v3/showthread.php?p=432257
          • Scenic
            o.O
            • Sep 2007
            • 2642
            take a look at the list of boards in the first post ...
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Jajaja
              It will still make for a good "flashing stick" in his future
              -When moving away from the "test boards" to more recent things...
              • Timeeez
                X270 - Bios flashing help
                by Timeeez
                I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
                Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
                11-30-2022, 05:17 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • Flyview
                Flashing ASUS UX51VZ with correct bios
                by Flyview
                Hi!
                Happy to be part of this forum for my first post!
                Short story:
                I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
                1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
                03-31-2024, 11:56 PM
              • Bloodhoundje
                by Bloodhoundje
                03-16-2024, 03:12 PM
