Dell used to be really good quality....
  • dobber
    • Jul 2008
    • 83
    #41
    Re: Dell used to be really good quality....
    Well, I know how that goes with the Dell's. I cant hardly get my customers to buy any of the used ones I get it trade. But I can say that about Gateways to and I worked there for over 7 years. I paid 3000 for my first new pc a Gateway g6-300 XL. most of my repair work is on thoughs 2 brands. At my day Job I only buy HP Business products, and have had great luck with them. But I went out on a Limb and gambled on a New Samsung RV511 from Best Buy for my home Laptop. Oh ya, I told them that if they open the box I would not buy it. I hate our local geek squad, bunch of complete tards. I get more rework from customers that have had them look at there PC's then just about anything else.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by Scenic
      still.. USFF boxes still cook caps.. even rubys..
      this might not be too terribly bad of a problem with the much cooler running CPUs we've got nowadays though.. (compared to the P4 hotplates those older Dells used)
      ~ALL~ USFF & SFF boxes cook caps. - That's not a "Dell issue" either...
      Mann-Made Global Warming.
      - Dr Seuss
      • mockingbird
        • Dec 2008
        • 5484
        #43
        The GX150 SFF with the Rubycons only (They're rare 1 out of ten of them let's say) are always fine. Mind you, there are only seven big caps total on the whole motherboard 7 x 6.2 2200uF MBZ/HM/KZG class. The HMs always fail and the KZGs are hit and miss.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I don't think Dell is any worse than anyone else.
          They sell MORE so you see them more often.
          - Dr Seuss
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Also, I would watch out for Conroes, too.
            65nm Core 2 Duos tend to run hot. I can see them heating up easily in a crammed case.
            seems like you never had a Pentium 4 or Pentium D if you call a C2D hot-running..
            (or you're using crappy coolers lol)
            • c_hegge
              • Sep 2009
              • 5219
              yeah, core 2s run cool. On my one, the temp. control never even turns the fan on for anything but heavy load stuff like gaming (and even then, it runs quite slow like 500RPM), although my case does have excellent ventilation.
              EDIT: That's with an overclock from 3GHz to 3.6GHz, so it would probably run a bit cooler without the overclock.
              • RJARRRPCGP
                • Jul 2004
                • 6301
                Mine is hard to cool, even with a better heatsink and low Vcore.
                Reminds me of "Bloomfield" chips!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • gerg
                  • Nov 2010
                  • 278
                  I think Dell has gone downhill trying to keep production costs low so they can sell a 299$ computer. I also believe that alienware which is owned by dell now has gone downhill i have repaired two of the laptops in the last month and one about 2 years old had bad memory and the other had a bad motherboard. I love it when people buy the cheapest computer they can find then they complain that it is slow and after two years parts begin to fail.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    Yours is a 45nm. I think those do better.
                    Arc A770 16 GB
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      So who is doing better then?
                      - Dr Seuss
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        there's virtually no difference.. maybe 1-3°C .. it's not like they run 10+°C cooler or something lol
                        my 65nm Core 2 Quad Q6600 overclocked from 2.4 to 3.6 currently idles at 33°C with a 92mm fan at roughly 950rpm. (old cpu-z validation with lower multiplier)
                        and my old Core 2 Duo E4300 which was OCed from 1.8 to 3GHz wasn't really hot-running either.. (same cooler.. Arctic Freezer 7 Pro in the old revision (black fan blades & not i3/i5/i7 mounting compatible))
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          With the exception of mobile versions, some Xeons, and those branded 'Extreme' all the 45nm & 65nm '2-Core' 'Core architecture' CPUs are 65 watts TDP.
                          [The 45nm 2-core is no different than the 65nm 2-core in that aspect.]
                          As a point of reference:
                          The fastest P4 [Netburst] with less TDP is a 2.6/512/400 or a 2.53/512/533.
                          - And unlike the 'core' CPU's, those P4's have no form of 'Speed-Step' so the 'core' CPUs actual power use [and heat dissipation] is much less than their TDP implies when comparing then to a P4 Netburst.
                          Short of bad cooling or a poorly designed motherboard I can't see any way for a Core based 2-core to be considered as one that 'runs hot'.
                          Now, some of the 4-cores run hotter.
                          - But AFAIK there is no -practical- use for a 4-core outside of an Enterprise Class server or a 'serous' workstation. [And I mean 'Workstation' by the industry definition.]
                          Outside of those situations the extra cores just don't do much so there is really no point in having them in a PC. [PC = PERSONAL Computer.]
                          - Dr Seuss
                          • TheLaw
                            • Jan 2011
                            • 477
                            #53
                            Originally posted by mockingbird
                            They're a nightmare. Very tough to get into all the crevices. I think the caps are LTEC and Teapo last time I checked.
                            Oh really....well seeing that I don't use this computer much, maybe I'll give it a look. Eww Ltec and Teapo? Teapo is usually alright. Not the best, but Ltecs. Shame shame.
                            • TheLaw
                              • Jan 2011
                              • 477
                              #54
                              Pentium D...Two P4s on one chip. Wtf were they thinking? What was the TDP on those bad boys? 200W?
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #55
                                [scotty]Laddie, don't you think you should rephrase that?[/scotty]
                                I must disagree strongly with you here.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Go right ahead. - I really don't care.
                                  And I'm standing by what I said.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    95 to 130 watts.
                                    - Dr Seuss
                                    • TheLaw
                                      • Jan 2011
                                      • 477
                                      #58
                                      Getting back to the Dell thing. I just decided to pop open the GX150's power supply. Mockingbird, you were almost dead on. It had two Teapos on the primary/PFC circuit. There's no active PFC so there's a 115/230V switch on the back, and hence the two caps. Could be making that up...believe I'm right.
                                      Anyway, two Teapos and the rest are G-Luxon. I'm starting to regret making this thread now. Enterprise workstations with G-Luxon? Yeah aaaight.
                                      There are in fact two swollen G-Luxons in the PSU which makes me think that perhaps the computer is running like shit because of some faulty ripple suppression or something. The others don't look all that hot either. They aren't swollen but I doubt they've stood up to 8 years of wear and tear too well.
                                      So if a PSU has bad caps, can it harm your motherboard etc.? What I am trying to say is: If I replace the caps for a new bucks, would it be pointless "now that the damage has been done"? Or would it be an okay idea. I don't use it much anymore, but it was actually quite zippy (for an 833MHz computer) up until about 2 years ago.
                                      The KZGs the GX150 is being accused of seems to be either a false accusation or I just have a lucky model. I have around 3 OSCONs, and around 4-5 UCC LXYs. So no KZGs in sight.
                                      Anyway, here are some pictures. (Still working on my photography, don't hate!) Since all the Chemi-cons were conveniently placed that I could not fit the camera lense to snap a photo of the printing, you just get the date codes etc. However, trust me when I say they were LXYs.
                                      Za pictures...
                                      UCC LXY:
                                      Teapos (these look swollen to you guys?):
                                      G-Luxon:
                                      Swollen:
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        #59
                                        1) Yea looks like you have an older GX150. The GX150s I work on all have the Pentium 1.13 chips and they have two 6.2 2200 HM/KZG/MBZ on the VRM which sticks up from the board, and 5 more HM/KZG/MBZ on the board.
                                        2) That Teapo primary does look bulged. I would replace every last capacitor in the PSU, except for the coupling capacitors (Though I don't know how to identify a coupling capacitor).
                                        If you need help, I can point you in the right direction regarding which replacements to get.
                                        • TheLaw
                                          • Jan 2011
                                          • 477
                                          #60
                                          I think I can get the right replacements. But Low-ESR, High Ripple Current? Any series you like in particular? Almost anything has to be better than this crap.
                                          I think I'm going to do a full recap...
                                          Are coupling capacitors electrolytic? And what is the reason behind not replacing them?
                                          Thanks for all of the help.
                                            DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:44 PM
                                            DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:36 PM
                                            09-12-2024, 03:30 PM
