Dell used to be really good quality....
  • TheLaw
    • Jan 2011
    • 477
    #81
    Re: Dell used to be really good quality....
    The 0.47 is out of stock on mouser so I'm going to use this as a replacement: http://www.mouser.com/ProductDetail/...2bMQv4vywJM%3d
    Any reason on using KME vs another cap. Since its LC...maybe there is a better more modern alternative? I'm probably sounding ignorant and dumb. Just tell me if so....How about a Panny FC or a Nichicon RZ or something? Just tell me if I'm sounding stupid.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      FC are better than KME and just fine to use.
      You can basically use FC, PW, LXZ, or even KY or HE in place of anything in that list except for the first 3.
      Mann-Made Global Warming.
      - Dr Seuss
      • TheLaw
        • Jan 2011
        • 477
        #83
        Impedance wise, that's okay? To use pretty low ESR caps in place of even the General Purpose?
        • TheLaw
          • Jan 2011
          • 477
          #84
          I'll take that as a yes.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Yes
            Caps like FC, PW, LXZ are 'entry level' low ESR caps.
            They ARE low ESR but not drastically low ESR.
            The benefit to using them in place of GP is they are usually higher quality caps.
            Also, since you aren't buying GP + [like "FC grade"] caps you can take advantage of the qty discounts. [Buying one kind for both applications.]
            An example is 220uF 16v. They are used like EVERYWHERE and it's a mix of GP and 'entry level' low ESR.
            Rather than stocking two kinds of 220uF 16v caps I buy 'entry level' low ESR 100pc [or more] at a time which cuts the cost per-each significantly.
            - Dr Seuss
            • TBoneit
              • Jun 2010
              • 70
              #86
              Originally posted by Scenic
              reminds me of my P4C800-E Deluxe.
              new caps, new BIOS, checked for shorted or open mosfets (every single one)... nothing.. dead as a rock..
              POST code card always shows FFFF.. ie dead..
              edit: talking about FFFF...
              Strangely enough I have the exact same motherboard here. Other than that a nice computer. It posts and then gives a GPF when trying to install any windows. Sometimes no post but a message about a Bios failed checksum.
              I'd love to fix it but i don't see anything looking bad.
              Anybody?
              • TheLaw
                • Jan 2011
                • 477
                #87
                Originally posted by PCBONEZ
                Yes
                Oh alright. I mean the price differential between GP and low(ish) ESR caps is pretty negligible. So if I do FCs in place of GP, that would be good? Theoretically, would FMs work for the low-esr caps, or is there something more power supply oriented. Mockingbird never got back to me on that. >.<
                I've been looking around...and is it just me, or do FMs absolutely destroy other caps spec-wise? I'm looking at Nichicon PMs/ UCC KY among others. Seriously FM is like off the charts. Comparing exact case size and values. ESR is almost half as low, and ripple current is doubled in some cases. The only competitor I see is UCC KZE which looks pretty darn decent as well.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  UG!
                  I really need to put up a web page on this so I can link to it instead of writing it out every time..
                  The tiers go:
                  [xxx][xxx] = ESR(or ESR range) at [8x20mm][10x20mm]
                  HZ, GA -- [.009][.007]
                  KZJ, GC, HN, MCZ -- [.012][.010-.011]
                  FJ, FL, WGL2, NRSJ -- [.016][.013]
                  MBZ, HM, WG, GD, KZG, NRSK -- [.018-.019][.013]
                  KZG, ZLG -- [.020-.021][.013-.014]
                  GE -- [.025][.016]
                  FM, FR -- [.030][.018-.019]
                  HV, ZLH, KZM, KZH, NRSH -- [.029-.033][.019-.020]
                  ZL, KZE, WX, HD, GK, NRSG -- [.041][.023]
                  ZT (125C - Low ESR & High Temp) -- [.054][.030]
                  PA, FK -- [.044][.035]
                  HE, KY, YXG, YXH -- [.069][.046]
                  JXA, FC, PW, NRSX, NRSZ, and others --[.065-.080][.044-.054]
                  LXZ, PM, and many others... - [.080-up]-and-[.050-up]
                  There are a few not included because they are newer than when I made this or I simply had a brain fart.
                  The ones that are in bold are simply the ones seen most often and/or that usually come up in conversations.
                  - Dr Seuss
                  • mockingbird
                    • Dec 2008
                    • 5484
                    #89
                    Very nice! Bookmarked.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      UG!
                      the number on the post counter (at the right.. where it says #87, #88, #89, ...) is actually a link to view a single post.
                      like so
                      https://www.badcaps.net/forum/showpo...7&postcount=88
                      • TheLaw
                        • Jan 2011
                        • 477
                        #91
                        Great list, but which are suitable for power supply use?
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #92
                          FM, FR -- [.030][.018-.019] and below...
                          • TheLaw
                            • Jan 2011
                            • 477
                            #93
                            Thanks.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              What goodpsusearch said is usually the case but it's best just to look up the specs on the old ones because PSU's do have ringers now and then just like mobos.
                              [ringer = non-typical & unexpected value]
                              Also mfr#1 might use one great spec cap where mfr#2 uses a pair of lesser caps in parallel to achieve the same thing.
                              It's just better to look them up.
                              - Dr Seuss
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                like so
                                I know that but bookmarks are only useful when you are on the same PC every time.
                                - Dr Seuss
                                • SuperDuty
                                  • Mar 2011
                                  • 299
                                  • France
                                  #96
                                  But it's a pleasant surprise when you open one of these up and get some really lovely stuff. HP on the other hand....We won't get into that.
                                  Just wanted to bump on this. I've picked up a semi-dead HP Vectra from 1999 at the dump (I find amazing stuff there), the computer did start but the graphics card did not work. I took it apart and I was pleasantly surprised to see Sanyo 6.3V 1200uF and Nichicon 10V 1000uF capacitors on the motherboard. Needless to say I desoldered them all for further use.
                                  Same for Acer, which doesn't have a great reputation in terms of durability of their hardware. I've found the remains of an Acer eMachines from 2008, and to my surprise, the processor (IIRC) capacitors on the motherboard are all Sanyo ! I did the same and removed the caps
                                  • yyonline
                                    • Jul 2009
                                    • 692
                                    Make sure you search the forums for some of the pitfalls of reusing used capacitors. It's not always a good idea as capacitors reform to the voltage of the circuit they are on. For 12 year old used capacitors, I wouldn't even consider it...Even reliable caps have a finite life.
                                    • SuperDuty
                                      • Mar 2011
                                      • 299
                                      • France
                                      #98
                                      Good to know, thanks ! I have repaired stuff with used capacitors with no problem though. I'll make a search.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        #99
                                        Using used caps is a risk I take.
                                        • TheLaw
                                          • Jan 2011
                                          • 477
                                          #100
                                          Say I used HNs for the caps that need to be low-ESR, would that work? They also have good specs. High ripple current/low ESR.
                                            DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:44 PM
                                            DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:36 PM
                                            09-12-2024, 03:30 PM
