Dell used to be really good quality....
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Dell used to be really good quality....
    Originally posted by TheLaw
    The PWs would go in places deemed as "general purpose" by Mockingbird, but it would also be used for 16V 2200uF low-ESR cap.
    As is shown in the earlier post
    https://www.badcaps.net/forum/showpo...7&postcount=88
    [and previously discussed] PW -IS- a low ESR cap comparable to FC, both of which are on the low end of low ESR but they are still low ESR caps. In fact both of those are highly regarded series' of caps.
    And, as was already said several times by several people..
    You can use entry level low ESR caps in place GP caps just fine.
    Amazingly...
    Good brand entry level low ESR caps are good to replace bad brand entry level low ESR caps too.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Well perhaps I am not as competent in this subject as all of you seem to be. I'm sorry for seeming ignorant. I read spec sheets. I make a judgement. I ask you guys for confirmation, but I guess I don't know exactly how to "ask" correctly.
      And it's not completely out of the blue...
      Thanks for the info.
      You aren't expected to know what you are doing yet.
      You do need to be more clear as to specifically what you are asking about.
      WHAT "the 16v" - you've asked about more than one cap.
      [Starting a thread for each project would help with that.]
      -- If you want 'specific' answers you need to ask 'specific' questions.
      -- Otherwise you get a general answer.
      And, you keep asking the same questions over and over which gets annoying. For example you've asked what to use for this same G-Luxon 2200uF 16v HM several times spread over more than a week. It's getting old..
      Lacking tone of voice:
      - This is intended as -constructive criticism-.
      - If I can get you to ask better questions then it's easier for us to help and you won't be chasing your tail so much because the answers from different people will be more consistent.
      - Dr Seuss
      • TheLaw
        • Jan 2011
        • 477
        #143
        Amazingly...
        Well thanks PCBONEZ (and everyone else). I'm sorry if if bugged you out...for over a week. I'll order em and recap, make a new thread, and put some pictures up for reference (assuming it works).
        • TheLaw
          • Jan 2011
          • 477
          #144
          I've never fixed a power supply before and there is an element of uncertainty to a first time you do something. The reason I asked about the 2200uF 16V so much is because a.) I originally was going to use a 10mm form factor, b.) then I decided 12.5mm was going to fit. c.) there was no ESR listing in the G-Lux datasheet, so how am I supposed to know which to use? d.) I was confused as to how low you could go in ESR, or if you should stray.
          There were reasons why I asked so much, but I'll forget about it now. It's over. Thanks to all who had to "deal with me". I'm sorry it was that painful for you.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            That was explained too.
            When you have a GP cap go by just the ripple.
            Using a GP cap with at least that much ripple is fine.
            Using an entry level low ESR cap [with at least that much ripple] is fine and usually better because low ESR caps are usually better quality than GP.
            -THAT- GP cap though should not have been a GP cap to start with.
            Someone was 'costing down' a bit too much that time.
            [PSU probably had lots of noise in the output.]
            I suppose it's possible it was recapped sometime in the past using crappy caps.
            But:
            If it at least ran with a GP cap there then any entry level Low ESR cap would be an improvement.
            - Dr Seuss
            • TheLaw
              • Jan 2011
              • 477
              #146
              It all comes down to bean counters.
              I'll try to take everything you've told me into consideration. I'm seriously trying. Thanks.
              • mockingbird
                • Dec 2008
                • 5484
                #147
                PCBONEZ, keep in mind his computer is an old socket370 coppermine...
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Should still have low ESR in the PSU. - Especially the OP filters.
                  - Dr Seuss
                  • TheLaw
                    • Jan 2011
                    • 477
                    #149
                    I bought FCs for the low-ESR, some FCs for the "GP" as well as some PWs and one PJ.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Sounds like a good plan.
                      - Dr Seuss
                      • TheLaw
                        • Jan 2011
                        • 477
                        #151
                        We'll see how it goes.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          #152
                          got a vostro 200 desktop tonigh (windows fix)
                          dell got it right, use rubycons! but wait, every cap is a rubycon...except vrm...all kgz, and vrm for ram too
                          but all the smaller-medium caps are ALL rubycon
                          fail
                          • TheLaw
                            • Jan 2011
                            • 477
                            #153
                            Kind of like my Optiplex. OSCONs and Chemi-Cons on the board and the power supply is G-Luxon.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Dell doesn't build their own stuff, they OEM.
                              Their mobos are from Intel [who sometimes outsources to Foxconn].
                              Their PSUs can be from a number of different companies - even in the same Dell model.
                              - Dr Seuss
                              • TheLaw
                                • Jan 2011
                                • 477
                                #155
                                I think Intel is exclusively Foxconn these days. I haven't see an Intel board made by any other OEM in a while.
                                • TheLaw
                                  • Jan 2011
                                  • 477
                                  #156
                                  I think they have a little bit control over the general quality of the machine. Like whether they want OSTs or Rubycons. Could be making things up again.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    They [Dell] seems to on mobos but they seem to ignore it in PSUs.
                                    Dell GX270 boards were labeled Intel up until the bad HM/HN fiasco where GX270 were blowing caps right and left,,, then suddenly those boards said Foxconn,,, they were the same boards otherwise.
                                    - Dr Seuss
                                    • TheLaw
                                      • Jan 2011
                                      • 477
                                      #158
                                      Got home today expecting to see a Mouser box in my door. Checked the tracking. Departed from Fortworth Texas 4/6/11 (today) @ 4:48PM...wtf. Ordered on Monday. =P
                                      • ncovert
                                        • Feb 2011
                                        • 291
                                        You know, the Dell Dim4600 uses DDR RAM not PC4200
                                        • RJARRRPCGP
                                          • Jul 2004
                                          • 6301
                                          Originally posted by seanc
                                          The Vostro 200 series are all cheap and nasty
                                          They seem fine to me. One that was given to me works good. Looks typical to me.
                                          I cannot say that they're flat out cheap-and-nasty.
                                          And the Inspiron 530S is related, looks like it's just a year-newer version of the Vostro 200.
                                          ASRock B550 PG Velocita
                                          Ryzen 9 "Vermeer" 5900X
                                          Arc A770 16 GB
                                          eVGA Supernova G3 750W
                                          Alienware AW3423DWF OLED
                                            DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:44 PM
                                            DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
                                            This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                            09-12-2024, 03:36 PM
                                            09-12-2024, 03:30 PM
