Factory Tours
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Factory Tours
    Gigabyte Factory Tour
    http://www.hardcoreware.net/reviews/review-217-1.htm
    ECS Factory Tour
    http://www.anandtech.com/mb/showdoc.html?i=1891
    http://www.hexus.net/content/item.ph...8&redirect=yes
    ABIT Factory Tour
    http://www.anandtech.com/mb/showdoc.aspx?i=2080
    http://techreport.com/etc/2004q2/abit-tour/index.x?pg=1
    http://www.tweaktown.com/articles/6/...our/index.html
    ASUS and AOPEN factory tours
    http://www.digit-life.com/articles/m...ies/index.html
    MSI Factory Tour
    http://www.hardwarezone.com/articles...?cid=1&id=1758
  • Rainbow
    • Aug 2005
    • 1375
    Re: Factory Tours
    What about GSC factory?
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Factory Tours
      its probably more impressive than you think.
      i spent a few hours reading tours like that. what i noted was lots of women working in the factories. apparently women are also used exclusively for quality control because they are better at concentrating? they are also cheaper. Some of the factories have dormitories as well so people come to work like hell for long periods sleeping there and then periodically return to their villages. interesting to see that labour is used more intensively rather than machines where possible because it is cheaper and faster/cheaper to retrain for different product runs.
      the factories are quite impressive. i liked also the machines which make automatic visual checks of the soldering etc.
      regarding capacitors though, they make burn in tests of the products and periodically take samples for more extensive testing. sadly, even the most crappy capacitor can probably pass a 24 hour burn in.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: Factory Tours
        i remember some pics of the inside of a chungwha crt plant.
        dirty floors and chickens running about.
        cleanliness is critical with a crt.
        seems samsung is the king of crap crt's.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Factory Tours
          its funny that...i consider samsung to be the king of TFTs. although we get them made in Slovakia. The king of CRTs must be either Shamrock or Pine. die old crt dammit die........
          • Rainbow
            • Aug 2005
            • 1375
            Re: Factory Tours
            I like CRT more - but only the better ones (I have ADI and Iiyama). I really hate craps like AOC, Relisys and Belinea. A 15" monitor from these crap brands often can do max. 1024x768@60Hz which is unusable. I use 1024x768@85Hz on my ADI 15"... I've fixed an older (about 1995) "no-name" 15" monitor (branded TEH GmbH, JEAN on PCBs) and it worked fine at 1024x768@75Hz...
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: Factory Tours
              when i say crt i mean the tube itself.
              samsung often uses other mfr's tubes in their own branded units.
              oem units like dell,gateway,ect get the crap samsung tubes.
              i think samsung is tied with zenith when it comes to crap tubes.
              • Chris1992
                • Apr 2005
                • 561
                Re: Factory Tours
                I have Dell 21" with Sony FD Trinitron tube, does 1600x1200 at 85Hz but I use 1280x1024 at 85Hz.
                The great capacitor showdown!
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: Factory Tours
                  Isn't that true that many workers are women in Europe too? (especially Ireland?)
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Re: Factory Tours
                    Nopie
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Re: Factory Tours
                      Nopie
                      LOL. I just was wondering, because in Ireland, you even have a woman for a president. I have yet to see that in USA!
                      In fact, I have read about the fact that women had priority over men in Celtic societies.
                      Arc A770 16 GB
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        Re: Factory Tours
                        microsoft mac lab tour
                        http://davidweiss.blogspot.com/2006/...s-mac-lab.html
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          Re: Factory Tours
                          does anyone have links to any more factory tours?
                          i really enjoyed reading these again
                          • gdement
                            • Jan 2007
                            • 690
                            Re: Factory Tours
                            I found a couple quotes in the ABit article interesting:
                            "At Rolly, we noticed that if a motherboard failed, it was immediately retested. Occasionally, these boards would fail continually, but after several tries, the components would usually pass inspection. Abit representatives explained to us that this procedure was because Rolly purposely sets inspection tolerances too tight and compensates for the extra manpower to test and retest (and retest again) by relying on its relatively cheap workforce."
                            I'm not sure I understand why they waste time testing at overly tight tolerances, unless they intend to sell some of the boards as "Ultra High-Test" models for more money. As far as I know they don't do that. Maybe it's just useful to have that extra detail when they trace back a QC problem.
                            "Abit's total volume is much less than that of ECS, but at the same time, quality control seemed much higher and more deliberate."
                            This is what bothers me about ABit now having their boards made by ECS. It's like having Ferraris manufactured by Ford. ABit is a smaller, enthusiast oriented brand and so their production requirements are different from a mass volume manufacturer like ECS.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              Re: Factory Tours
                              well dont believe everything they tell the journalists. anyway that statement sounds odd. its true about the manpower though. for 100 bucks or so a month it would be difficult to get a machine to work for that money....
                              lol if ferraris were manufactured by ford they would be more reliable.....anyway abit had bad financials what could they do....
                              edit : thinking about it more, are abit boards made in USI factories now, since the merger?
                              • pentium
                                • Mar 2006
                                • 2778
                                Re: Factory Tours
                                Fremont NeXT Factory
                                Find Nedry!
                                Check the Vending machines!!
                                • willawake
                                  Super Modulator
                                  • Nov 2003
                                  • 8457
                                  • Greece
                                  Re: Factory Tours
                                  Supertalent Factory Tour
                                  Kingmax Factory Tour
                                  Kingston Factory Tour
                                  Corsair Factory Tour
                                  Intel FAB18 Factory Tour
                                  Ferrari Factory Video Tour
                                    HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                    This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                    09-12-2024, 02:20 PM
                                  • RRice25541
                                    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                    by RRice25541
                                    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                    the color is all outa wack, like the settings have been corupted,
                                    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                    so
                                    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                    when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                    05-13-2022, 10:44 PM
                                  • masterm
                                    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                    by masterm
                                    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                    Problem with TV:
                                    - Netflix stopped working so i tried to do factory reset from the TV menu.
                                    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                    - After waiting for some time, the TV went into a boot loop.
                                    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                    04-30-2024, 03:03 AM
                                  • alimohebiyan
                                    ASUS TUF506IU Factory BIOS
                                    by alimohebiyan
                                    My laptop has been recently repaired, and it currently needs the default factory BIOS. If anyone has it, please share it, or guide me on how I can obtain the BIOS.
                                    Motherboard Model: DABKXBYBAC0 REV : C
                                    Serial Number: L8NRCX03847534D
                                    Thank you in advance for your help!...
                                    08-13-2025, 06:29 AM
                                  • Amber TC
                                    [NOT A RESCUE BIOS] Dell Latitude E6530 Rare Factory BIOS (Revision A86)
                                    by Amber TC
                                    ⚠️ Not a Rescue BIOS. Flash at Your Own Risk. ⚠️
                                    This is not A17.
                                    This is not listed on Dell's support site.
                                    This is an unreleased internal firmware revision recovered from a university loaner Latitude E6530... and it possibly bricked the system it came from.
                                    It is from the 8 MB Winbond W25Q64 chip. Could be nothing burger but given the anomalies this is a very interesting firmware dump.
                                    Firmware collectors and reverse engineers might find this useful, It contains certs, modules, and DXE drivers not present in A17. This is likely...
                                    04-17-2025, 03:54 PM
