strange beeps...
  • kiddznet
    • Jul 2010
    • 176
    strange beeps...
    Another one I cant find an answer for GA-IPE1000 g starts ok single beeps normally then while posting gives rapid clicking beeps until post finishes
    Tried all the usual suspects ram, vid card even changed CPU
    Everything is working fine except for this clickng/beep on start
    Hah--- found something I disabled hyperthreading thats shuts it but I using an 800fsb penty???
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • kiddznet
    • Jul 2010
    • 176
    Re: strange beeps...
    THINK KEYBOARD DUMMY
    hee...hee the only thing I hadnt swapped over....
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      you need to get you smilies right.
      = to agree
      = to want to hump (or do more ) something
      you just said you humped your keyboard. fail.
      sigpic
      (Insert witty quote here)
      • retrorepair2
        HP Z820 Workstation 4 beeps (sometimes)
        by retrorepair2
        I've got an issue with my Z820 that I'm having trouble working out the root cause of.
        More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
        What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
        Another oddity is the fans. Before the 4 beeps...
        09-24-2025, 08:05 AM
      • ktmmotocross
        Old hp compaq nc6320 weird beeps after low bios battery
        by ktmmotocross
        Hello.
        Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
        i attach record of beeps...
        04-27-2025, 12:48 AM
      • KappaDev
        HP ENVY x360 15m-dr0011dx 8 Beeps
        by KappaDev
        I have an HP Envy x360 15m-dr laptop which sometimes beeps 8 times on startup and sometimes gets no beeps at all (both with no picture).
        Power button light comes on, fans spin and stop after a few seconds, then screen stays black with no picture. If the machine decides to beep 8 times, it shuts off immediately after. According to what I could find, 8 beeps was corrupted BIOS.
        Made backup of original BIOS (attached). Attempted to flash BIOS with extracted bin file from HP BIOS update. Screen showed "Updating boot block", rebooted and immediately back to 8 beeps and...
        01-09-2023, 11:18 AM
      • nobbnobb1
        BASH Subwoofer Amp No Sound, Power Ok (Atlantic Technology 642eSB)
        by nobbnobb1
        I have a really nice Atlantic Technology 642eSB subwoofer that I would love to get working. The problem is that the power appears ok (LED light is on), but there is no sound. I don't believe it to be the audio input board or anything wrong with the power as when in standby mode (LED = red), I can play a source and the LED turns green suggesting the input is being detected ok.
        The amplifier is a common BASH design, my interpretation of the layout based on Picture #1:
        - Top most hanging board is the audio input section. Note I accidentally broke the crossover...
        09-30-2022, 03:46 PM
      • tahirkhan1983
        Hp prodesk 400 g5 3 long beeps and 2 short beeps
        by tahirkhan1983
        My Hp prodest 400 g5 having no display with or without ram 3 long beeps and 2 short beeps. many bios tried but the problem is same. please help thanks in advance.
        07-26-2023, 06:43 AM
