Which nVidia mobo chipsets are bad?
  • gixie
    • Feb 2011
    • 14
    #61
    Re: Which nVidia mobo chipsets are bad?
    Originally posted by mockingbird
    I indicated with an arrow what needs to be replaced. Please confirm that they are all 8mm in width. They should be either 16V 1000uF or 6.3V 1500uF.
    For the 16V 1000uF:
    http://www.mouser.com/ProductDetail/...E4E2mSMph7c%3d
    For the 6.3V 1500uF:
    http://www.mouser.com/ProductDetail/...LJ%252bKVJk%3d
    Hi mockingbird,
    Thanks for the reply (actually thanks to everybody that replied to my post...
    There's a place between the VR and the CPU where it looks like there's 1 missing capacitor... I remember reading somewhere (just brew it was the poster, I think) that it would not hurt putting a cap there too...
    What do you think?
    Is the website you suggested good (i'm referring actually to shipping; oh, btw, I'm Canadian)? I usually buy from ebay.
    Thanks in advance!
    • delaware74b
      • Apr 2009
      • 628
      gixie - 3-in-1 oil is a brand name of lightweight oil sold in the US. Here is the link to their page:
      http://www.3inone.com/products/multi-purpose/
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • gixie
        • Feb 2011
        • 14
        #63
        Yeah, I imagined that much... I am Canadian, so I am wondering what my options are here... I think Jig-a-loo is one, the second being the usual lubricating oil (like the one used to lubricate sewing machines).
        What do you think?
        Thanks again!
        • mockingbird
          • Dec 2008
          • 5488
          #64
          Originally posted by gixie
          Hi mockingbird,
          What do you think?
          Thanks in advance!
          Canadian? Oh well, it's not your fault.
          No, don't add anything. As my father always tells me "Don't make a doctorate out of it".
          Regarding Mouser's shipping:
          You have to specify USPS shipping and not UPS shipping. The USPS shipping is only $8 to Canada but there is a risk that it will get stuck at the border and it will take a week to get to you. I had no problems with it though.
          I would love to make a group buy at Newark with other Canadians on this forum. Their shipping is outrageous ($20), but I really need some 10mm Panasonic FK caps.
          • Pyr0Beast
            • Feb 2009
            • 406
            #65
            Originally posted by Scenic
            ^ those stupid fans killed a lot of those A8N series boards.
            i've seen tons of them where the fan was seized solid or just barely moved..
            chipset runs at 90+°C if the fan fails.. kills the chip pretty quickly
            And if you try to remove it, to put some oil on it... bummer, have to remove the whole fan assembly from the bottom !
            Then unscrew the top and only then get to the fan !!
            I was so pissed, had to remove the whole board to get there ...
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              #66
              my boss takes the dv's apart, puts tin foil across everything but the gpu die itself, then takes a small blowtorch and quickly drags the flame across the gpu die. then artic silvers a copper shim in place of the heatpad, and then silvers the shim to the gpu. it works, for a few days
              • Pyr0Beast
                • Feb 2009
                • 406
                #67
                A shitty repair IMHO
                • gixie
                  • Feb 2011
                  • 14
                  #68
                  @ mockingbird
                  I just received part of the caps for this repair, the ones around the cpu and VR.
                  I bought them off ebay and they are Philips, 10mm. I chose them because they were the cheapest and you know, in case the mobo has another defect I did not want to lose to much $.
                  I read that you wanted to buy Philips caps off Newark...Why don't you try ebay? I admit, it takes waaaay longer to get them, but...I think shipping was free for me.
                  Just my 50 cents!
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    philips doesn't make low-ESR caps suitable for motherboard use..
                    • gixie
                      • Feb 2011
                      • 14
                      #70
                      @Scenic
                      That's weird...there are a lot of caps on the same mobo that are made by Philips, and there was a comment that said they are reliable... What gives?
                      Should I order Rubycons or should I give it a try...
                      • mockingbird
                        • Dec 2008
                        • 5488
                        #71
                        Gixie,
                        Are you sure you have Phillips caps? Maybe you're refering to Sanyo or Panasonic?
                        • gixie
                          • Feb 2011
                          • 14
                          #72
                          I am sorry all of you...they're Panasonic...
                          • gixie
                            • Feb 2011
                            • 14
                            #73
                            So, are Panasonic good?
                            I would hate it if they weren't
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              depends on the series.
                              panasonic/matsushita caps in general are great, but if the series aren't suitable for motherboard use, it's not gonna work out..
                              FM, FL and FJ would be what you're looking for..
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                And KG, FC, FK, GA, and FR depending on the application.
                                GA and FR are new.
                                GA replaces KG. [I sometimes use KG for the 50v under 6.8uF in PSUs.]
                                FR is almost an exact match to FM for ESR/ripple but has more hours endurance.
                                Mann-Made Global Warming.
                                - Dr Seuss
                                • gixie
                                  • Feb 2011
                                  • 14
                                  #76
                                  Mine are FJ, so from the "approved" list...Whew, that's a relief...
                                  I'm waiting for the other ones, next to the chipset, to start the re-capping job.
                                  Fingers crossed
                                  • gixie
                                    • Feb 2011
                                    • 14
                                    #77
                                    All the caps were replaced, however, the motherboard refuses to boot
                                    I have a diagnostic card and I checked the code in the booklet. The code is FF which means: Flash ROM programming was successful. Next restarting the system BIOS.
                                    What does it really mean?
                                    Also there's a LED that's always on, the RESET LED, in which case the booklet says: When in reset period, this lamp display. If it is lit all the time, check the following:make sure that the reset pin is plugged properly, or the reset circuit is broken.
                                    What does THIS mean?
                                    Should I call it quits and recycle the mobo?
                                    I am tired of this mobo, but I still have some 4 socket 939 cpus lying around (that nobody is interested in on Kijiji)
                                    Ideas anyone?
                                    • Scenic
                                      o.O
                                      • Sep 2007
                                      • 2642
                                      if it always says FF and nothing else, the board is basically dead.
                                      this will happen if the BIOS is bad (wrong BIOS flashed to it or bad BIOS chip) or if the board itself it just ..well.. dead/FUBAR
                                      as for the reset LED.. this probably means that the board is stuck in a reset loop (as if you held down the reset button all the time)..
                                      overall, this kinda sounds like a bad BIOS to me..
                                      • gixie
                                        • Feb 2011
                                        • 14
                                        #79
                                        So, recycle, right?
                                        Do I salvage the capacitors I just soldered on it? Anyone wants them
                                        • Scenic
                                          o.O
                                          • Sep 2007
                                          • 2642
                                          if the BIOS chip is socketed, you could try hotflashing it in another board.
                                          (boot the other board up into DOS with its original bios chip, swap the chip with the dead one, and flash the correct BIOS for the dead board onto the chip.)
                                            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                            10-02-2024, 08:52 AM
                                            NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                            The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                            10-02-2024, 07:51 AM
                                            NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                            The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                            10-01-2024, 01:54 PM
                                            HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:30 PM
                                            Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full...
                                            09-07-2024, 03:10 AM
