Which nVidia mobo chipsets are bad?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Which nVidia mobo chipsets are bad?
    Originally posted by mockingbird
    That's because you don't have the right drivers. nForce 4 is solid, except for the LAN when you have the hardware-based firewall enabled. This was known to cause crashing.
    I've tried it in XP with the latest Nvidia drivers, and without. On an affected board it doesn't make one bit of difference which drivers it's running.
    How is one supposed to install Windows then?
    How is one supposed to run Linux?
    A man convinced against his will is of the same opinion still.
    • mockingbird
      • Dec 2008
      • 5484
      Don't use "latest" official nVidia drivers. There's a forum out there with much better drivers. I don't remember off-hand where it is, try the laptopvideo2go forums, they also have later drivers.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        And who the **** is supposed to know that?
        OBTW, it happens in Linux too.
        If one needs to use special drivers that exist only on an internet forum something is seriously wrong.
        • retiredcaps
          • Apr 2010
          • 9271
          I recall seeing someone mention Omega drivers.
          http://www.omegadrivers.net/
          --- begin sig file ---
          --- end sig file ---
          • mockingbird
            • Dec 2008
            • 5484
            Haha, Omega.... I haven't used that for ten years...
            • yyonline
              • Jul 2009
              • 692
              If I recall correctly...when installing the official Nvidia drivers, it presents you with a prompt as to whether or not you want to enable active armor, which is the buggy firewall.
              • mockingbird
                • Dec 2008
                • 5484
                #27
                You have to give them props for their audio back in the day though... The only integrated audio where you could pass through DTS.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  When you lost the file [bad CRC] were you using PRM drives?
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • acstech
                    GrumpyModerator
                    • Jul 2007
                    • 1432
                    Possibly. It's been at least a couple years since I messed with it. Even if I was PRM, why would it work fine on a different board (with a different chipset) using the same drive?
                    At the time, I had the same thought, that it might be the drive. In fact, that's the first thing I tried, that being to swap out drives.
                    IIRC, it was a 250GB Samsung Spinpoint P series drive.
                    • dobber
                      • Jul 2008
                      • 83
                      #30
                      Originally posted by PCBONEZ
                      And here I thought Gateway had packed their bags and headed back to the Cow patties.
                      Ya they have, but I had a great 7 years working there.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #31
                        I saw a Gateway Netbook/Notebook hybrid a couple of years back.
                        • NxB
                          • Feb 2009
                          • 1595
                          #32
                          Reflow is worth it, reball is not. Reball hurts the eyes unless you buy all the stencils and a real reflow machine.
                          If you're just heatgunning it, some fix permanently the first time. Some are trouble makers and fail every 30 days or reflow once and then never come back.
                          • mockingbird
                            • Dec 2008
                            • 5484
                            #33
                            I don't know what kind of madman would attempt a reball without the stencils and the reflow station. Placing each ball by hand and then heatgunning it, while possible, is like trying to count grains of sand.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              For the same reason RAM will work well on one board but not another.
                              - Dr Seuss
                              • acstech
                                GrumpyModerator
                                • Jul 2007
                                • 1432
                                Just trust me that I narrowed it down to the board in each instance. It did not happen on just the one board either.
                                "What has been seen cannot be unseen."
                                Remain skeptical if you want. I really don't care, nor do I have any point to prove here on the internet. I don't get anything for it. You asked, I shared. Period.
                                • Rulycat
                                  • Apr 2010
                                  • 724
                                  #36
                                  My Realtek 889 does DD Live.
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    #37
                                    By the way, there are two versions of the 889, one that has more digital output features, I think it's called the 889D, but anyways, there's a new one out 892 which has it.
                                    • Rulycat
                                      • Apr 2010
                                      • 724
                                      #38
                                      The 889A on my board is basically the 889DL or whatever it's called but only shows up on Gigabyte boards.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        FWIW, My solution to defective nVidia chipsets is to put a fan over the heatsink. It may not fix the defect, but it will probably prolong it's life somewhat.
                                        • NxB
                                          • Feb 2009
                                          • 1595
                                          #40
                                          How about soldering the balls by hand, there are youtube videos but not on anything as big as a chipset/gpu.
                                          Generic stencils are more along the lines of what I'm talking about.
                                            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                            10-02-2024, 08:52 AM
                                            NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                            The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                            10-02-2024, 07:51 AM
                                            NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                            The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                            10-01-2024, 01:54 PM
                                            HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:30 PM
                                            Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) boardview and Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz,...
                                            09-07-2024, 03:10 AM
